The problem is that I cannot type the letter 's'. I see this when logged on via ssh from my desktop, the 's' key works fine elsewhere. I also see it with a screen and keyboard plugged directly into the Pi. I cannot even cut and paste it in. I have tested all of the other keys, just the 's' that is not working. Even upper case 'S' works!! (pity Linux is case sensitive
At bootup I do get several (15 or so) messages of the form -
/etc/init.d/triggerhappy:28: /etc/triggerhappy: \e[1~:: not found
where the 28 and the [1 vary between messages.
What can cause this? I have compared it with a running Pi, they both have /etc/init.d/triggerhappy with the same date and size and both have /etc/triggerhappy as a folder empty except for a folder triggers.d which is also empty.
I am running Raspbian installed from NOOBS_v1_3_2
I am happy to investigate further if you can make suggestions, but bear in mind that I cannot type 's' so sudo is out.
