bubbl
Linux terminal - copy progress bar
Sat Nov 30, 2013 6:18 pm
If you want to copy something using the command-line interface in GNU/Linux, then “gcp” is like the universal tool.
- lightweight and pretty user friendly.
- supports copying files and folders.
- you can copy single or multiple (lists) files & folders too.
- shows a nice progress bar, size of the file being copied, the current file copy speed, plus an “estimated time”. So you’ll know what’s happening at an any given time.
sudo apt-get install gcp python-progressbar
example:
coping file …
gcp source-file destination
coping folders …
gcp -r source-folder destination
We're not here because we are free. We're here because we are not free. There is no escaping reason. No denying purpose. Because we both know without purpose, we would not exist.
http://www.bartbania.com/
DeeJay
Re: Linux terminal - copy progress bar
Sat Nov 30, 2013 6:35 pm
bubbl wrote:If you want to copy something using the command-line interface in GNU/Linux, then “gcp” is like the universal tool.
But it seems to have dependency on running in an environment where X-windows is supported, even though it does not actively open a new window.
pi@raspberrypi ~ $ gcp try.sh dummy
  File "/usr/bin/gcp", line 678, in <module>
    gcp = GCP()
  File "/usr/bin/gcp", line 190, in __init__
    sessions_bus = dbus.SessionBus()
  File "/usr/lib/python2.7/dist-packages/dbus/_dbus.py", line 211, in __new__
    mainloop=mainloop)
  File "/usr/lib/python2.7/dist-packages/dbus/_dbus.py", line 100, in __new__
    bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
  File "/usr/lib/python2.7/dist-packages/dbus/bus.py", line 122, in __new__
    bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ExecFailed: /usr/bin/dbus-launch terminated abnormally with the following error: Autolaunch error: X11 initialization failed.
How To Ask Questions The Smart Way: http://www.catb.org/~esr/faqs/smart-questions.html
How to Report Bugs Effectively: http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
bubbl
Sat Nov 30, 2013 6:39 pm
    gcp = GCP()
    mainloop=mainloop)
huh. been running it on X-less machine for some time now and it works well... don't know why you get this error
bubbl
Sat Nov 30, 2013 6:42 pm
rsync -P as an alternative is close enough I think.
Return to “Beginners”
