Protecting files from unwanted deletion is very important security on the tasklist of Unix Administrators. On Linux boxes you can use the chattr command and that works ine on all my Ubuntu based servers.
Let’s give you some examples how chattr work under Linux:
To make a folder undeletable, run:
After that, you can’t delete, rename or do anything with this folder. But if you don’t need this folder anymore or you’ve got to apply some changes to it run:
To make a file undeletable, run:
To be able to change or delete the file, run:
We're not here because we are free. We're here because we are not free. There is no escaping reason. No denying purpose. Because we both know without purpose, we would not exist.
http://www.bartbania.com/
