andrewdobrowolsky
raspberry don't have ip addres
Sat Nov 30, 2013 12:39 pm
My raspberry has been working very well long time and everything was ok. Yesterday I tried run my raspberry and it didn't get ip. I rebooted my router, nothing help. I checked another sdcard with my raspberry and it works. I plugged my sdcard to computer and file /etc/network/interfaces is good. I use raspbery only by ssh . What is possible problem ? It very care me of this :(
Re: raspberry don't have ip addres
Sun Dec 01, 2013 4:05 am
Are you using wired or WiFi?
Can you cut and paste the output from
lsusb
ifconfig -a
cat /etc/network/interfaces
profwamba
Sun Dec 01, 2013 6:59 am
maybe your sdcard is corrupted
You can add the ip (until next reboot) with sudo ip addr add 192.168.0.100/32 dev eth0
You can also give your raspberry pi an IP address by adding 'ip = 192.168.0.4' at the end of cmdline.txt Do that using the command: sudo nano /boot/cmdline.txt Make sure you nothing else, not even a space or a return. After that, reboot your pi and type hostname -I to see if the ip address is set.
Rugby is great. The players don't wear helmets or padding; they just beat the living daylights out of each other and then go for a beer. I love that.
