Sat Nov 30, 2013 2:10 pm
Wiggle the mouse, does the cursor move?
If not, unplug the mouse, count to ten, plug the mouse back in. Wiggle the mouse to see if the cursor moves.
If not try a different mouse.
If not, then disconnect the power, reboot
If you can move the mouse you can operate the NOOBS menu system (it doesn't need any keyboard interaction)
If that doesn't work then take a step back, reformat the SDCard with the SD Formatter tool, check your NOOBS.zip download (or NOOBSlite.zip download) using sha1sum to ensure it's complete and a good copy.
NOOBS.zip should be 1,209,864,481 bytes in size (check that first before running sha1sum)
NOOBSlite.zip should be 20,918,392 bytes
Unzip it to the SDCard again and try again.
