TenderLoins
DS18B20 + Camera module; modprobe breaks camera
Wed Nov 27, 2013 3:43 pm
Using this tutorial http://learn.adafruit.com/adafruits-ras ... ng/ds18b20, I hooked up a DS182B0 sensor to my rpi and I can read from it successfully.
I had raspistill running on a loop previously, and also collected the temperature from the rpi, then I ran rpi-update, something strange happened and I figured I'd just format everything and start again.
Now I do the following:
[email protected]:~# raspistill -o /mnt/server/images/image9.jpg <--- works and saves image
[email protected]:~# sudo modprobe w1-gpio
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
If I restart, I can use raspistill all day long, until I run modprobe. Anyone know whats going on?
TenderLoins
Re: DS18B20 + Camera module; modprobe breaks camera
Thu Nov 28, 2013 8:59 am
Verbose output:
[email protected]:~# raspistill -v -o /mnt/server/images/image912.jpg
raspistill Camera App v1.3.5
Width 2592, Height 1944, quality 85, filename /mnt/server/images/image912.jpg
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled  no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Opening output file /mnt/server/images/image912.jpg
Enabling encoder output port
Starting capture 0
Finished capture 0
Closing down
Close down completed, all components disconnected, disabled and destroyed
[email protected]:~# modprobe w1-gpio
[email protected]:~# modprobe w1-therm
[email protected]:~# raspistill -v -o /mnt/server/images/image9123.jpg
Width 2592, Height 1944, quality 85, filename /mnt/server/images/image9123.jpg
Opacity 255
Thu Nov 28, 2013 9:29 am
Looks like something is using one of the GPIO's used for the camera. Can you file a bug report on github please (although probably the driver for the HW you have added will need to be changed).
theoriginalxbrav
Sun Dec 01, 2013 9:53 pm
I can confirm this issue. It is due to the camera sharing GPIO 4 with the 1-Wire devices. Is there any way to change the w1-gpio config's pin?
Projects:
Raspberry Pi Weather Camera and weeWX: http://reboot.us.com/local-weather/
Daily Timelapses: https://www.youtube.com/playlist?list=PLi1er5S-VzV8d2t21zT0U_aBInl1_Ojkf
midnight1111
Tue Dec 10, 2013 3:22 am
I am having the same problem. I have the RP with the HD camera. Any help is appreciated.
[email protected] ~ $ !rasp
raspivid -n -t 2000 -vf -b 2000000 -fps 25 -o - > out
[email protected] ~ $ cat out
[email protected] ~ $ raspconifg
-bash: raspconifg: command not found
[email protected] ~ $ raspi-config
Script must be run as root. Try 'sudo raspi-config'
[email protected] ~ $ sudo raspi-config
[email protected] ~ $ raspivid -v
raspivid Camera App v1.2
Width 1920, Height 1080, filename (null)
bitrate 17000000, framerate 30, time delay 5000
Opacity 255
Saturation 0, ISO 400, Video Stabilisation No, Exposure compensation 0
Opacity 255
michaeljvdh
Thu Dec 12, 2013 7:23 pm
I am having the exact same issue.
Im using a temperature probe ds18b20 on GPIO4, luckily I did not automate "modprobe w1-gpio" I was in the process of first testing a few things before I automated this .. by chance I bought the camera and just happen to have been working on reading my temperature probe and testing the camera at the same time when I noticed that running "modprobe w1-gpio" was crashing the camera !!!
Im quite desperate to get this resolved, as I have a demo to deliver soon .. and having it in this handicapped state is not going to bring much glory to the pi. HELP.
3lackhawk
Fri Dec 13, 2013 5:59 pm
Same too.
My config is Pi model A+Cam module+DHT11sensor
First I set up to get temperature which is unstable (I have an another Pi where this sensor worked perfectly) sometimes get value sometimes not.
After that I set up motion and get same result, not working...
Get this error:
[0] [ERR] [ALL] [Dec 13 16:33:21] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
[0] [ERR] [ALL] [Dec 13 16:34:21] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
I found this topic and realized it is common problem.
I wanted to see my working cam that is why I try to disable all unnecessary modules like sound and i2c etc.
I put the following into /etc/modprobe.d/blacklist:
blacklist snd-bcm2835
blacklist i2c-bcm2708
Reboot and motion+cam got work at the first time! :)
I tried to get tempereature and work too! ;)
It is unstable still but work....
[email protected]:/opt/motion# /root/DHT.out 11 4
OK 17 [email protected]:/opt/motion# /root/DHT.out 11 4
I need to test more together I try to figure out why not get data sometimes from DHT11 :?:
starcraft04
Sat Dec 14, 2013 9:47 am
Hi all,
I have the exact same issue. Has anyone written a bug report yet? If not, how can I do that, I ve never done it before.
Thanks,
John.
Thicko_1970
Sat Dec 14, 2013 12:32 pm
This is strange, because I am using this sensor and running motion MMAL at the same time. It works flawlessly for me.
I notice that in dmesg, I see "w1_master_driver w1_bus_master1: Family 28 for 28.0000053a951e.55 is not registered.". However, the sensor is happily working. I have set up a Cron job to sample the temperature every 5 minutes and append it to a text file and all seems well.
The dmesg output would perhaps indicate that something is going on, that can cause a conflict in some cases.
michaeljvdh
Sat Dec 14, 2013 8:44 pm
What I don't understand is why the camera would have anything to do with GPIO pin 4.
Also from a standard stock install and doing the following breaks the cam.
$ sudo modprobe w1-gpio
$ sudo modprobe w1-therm
In fact it's just when you run mod probe w1-gpio ... Immediately after that if you try to take a picture form raspistill it fails and the camera just locks up with red led burning.
Anyone know how to UNDO modprobe w1-gpio ... Was thinking of only initializing it before my temperature measurement then unloading ... I don't know ... I really would love it to work concurrently.
Sat Dec 14, 2013 10:01 pm
michaeljvdh wrote:Anyone know how to UNDO modprobe w1-gpio
sudo modprobe -r w1-gpio
or
sudo rmmod w1-gpio
You might also need to remove the w1-therm, wire and cn modules too.
starcraft04
Sat Dec 14, 2013 11:01 pm
I just stried this but it is not working, same error even after unloading the module.
The only thing to make the camera work again is a reboot :(.
michaeljvdh
Sun Dec 15, 2013 4:12 am
Yeah Starcraft04 ... I just tested ... Same problem. I'm at a ski resort and should be concentrating on relaxing ... Only no one understands how relaxing electronics can be :)
Looking around on the net I found a few references saying it was working in an older kernel ... Unfortunately my first Pi is the latest .. And have no means for comparison.
Wonder if this is a memory addressing problem ... What annoys me is I went for the pi cam instead of the usb models to so I would have NO problems :) anyway hope someone comes up with a new idea.
Since they both work independently 1wire and the camera .. With both connected it has to be a resource clash.
gmartl79
Sun Dec 15, 2013 3:31 pm
Hi there,
does anybody know if there is any progress with this issue. I just ran into the same problem.
Was trying to have a PIR motion detection cam which is also logging the temperature.
Seemed to work quite ok for some time. Since the last sudo apt-get update, every time i call sudo modprobe w1-gpio in my script, the camera module stops working until reboot.
Quite annoying... so desperately looking for help! :)
cheers,
martl
dkossman
Fri Dec 20, 2013 5:47 pm
Same problem here - also using a couple of 1-wire temperature probes on GPIO7 (BCM GPIO4). It was all working fine up until a couple months ago, but must have broken in one of the updates.
If anyone finds a solution, please let us know...
thanks!
dom
Sat Dec 21, 2013 1:11 pm
There is a workaround posted here:
https://github.com/raspberrypi/linux/issues/435
michaeljvdh
Sun Dec 22, 2013 4:54 pm
Tried this all last night no go for me. Does anyone have experience in logging a formal ticket with the crowd who develop the kernel.
starcraft04
Tue Dec 31, 2013 2:43 pm
Hi all,
IT WORKS !!!!
I managed to get it working on version 23+ by doing from url:
but you have to do what is at the end:
[email protected] / $ cat /boot/config.txt
gpu_mem=128
[email protected] / $ cat /etc/modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
# Parameters can be specified after the module name.
w1-therm
w1-gpio pullup=1
i2c-dev
i2c-bcm2708
spi-bcm2708
snd-bcm2835
[email protected] / $ cat /etc/modprobe.d/raspi-blacklist.conf
# blacklist spi and i2c by default (many users don't need them)
blacklist spi-bcm2708
And with that, I can use everything again...
michaeljvdh
Tue Dec 31, 2013 3:17 pm
Starcraft04 I'll try this again as you have I'll let you know. Thanks I might have done something silly being impatient with the problem.
Thanks man.
theoriginalxbrav
Tue Dec 31, 2013 5:18 pm
Gents,
I believe you've found the solution! The camera seems to be struggling with closing the connection, but(see below) I'm not encountering the ENOSPC error anymore. See below:
[email protected]:~# cd /sys/bus/w1/devices
[email protected]:/sys/bus/w1/devices# ls
28-00000484df4e  28-000004857c08  28-0000048e17a2  w1_bus_master1
28-00000484eb98  28-000004858afc  28-0000048e5899
[email protected]:/sys/bus/w1/devices# raspistill -v
Width 2592, Height 1944, quality 85, filename (null)
Opacity 255
Closing down
The closing delay may just be due to my cron job conflicting with my console commands.
*EDIT*
Yep, conflict with the cron job. Works great!
Projects:
michaeljvdh
Wed Jan 01, 2014 4:08 am
YEEEEEEEHaaaaaaaaaa working for me too. I see Starcraft04 you didn't add w1-therm for those using thermometer.
Anyway apart from opening blacklist here is my /etc/modules
w1-gpio
w1-gpio pullup=1
i2c-dev
i2c-bcm2708
spi-bcm2708
snd-bcm2835
w1-therm
dpenezic
Wed Jan 01, 2014 11:30 am
i dont understand way you call w1-gpio 2x ?
Regards,
Dubravko Penezic
michaeljvdh wrote:YEEEEEEEHaaaaaaaaaa working for me too. I see Starcraft04 you didn't add w1-therm for those using thermometer.
w1-gpio
w1-gpio pullup=1
i2c-dev
i2c-bcm2708
spi-bcm2708
snd-bcm2835
w1-therm
michaeljvdh
Wed Jan 01, 2014 4:59 pm
Guys my apologies I meant to hash that out ...
Enter only one w1-gpio instance like this.
w1-gpio pull-up=1
If you did enter it twice it causes no problem.
Sorry.
dpenezic
Wed Jan 01, 2014 9:10 pm
it is O.K. --- i just wonder if that is some fix .
My only issue is fact that i dont have camera to test all of that in real ... but i will try to help (I read some of comment and see information about memory issue) ... soon i will read all thread and maybe found/suggest some solution.
Regards,
Dubravko Penezic
michaeljvdh wrote:Guys my apologies I meant to hash that out ...
w1-gpio pull-up=1
Sorry.
theoriginalxbrav
Wed Jan 01, 2014 10:05 pm
Memory is fine as long as your split is adequate (I'd say do a 384/128 split for CPU/GPU).
Here's my config for future reference. I changed my 1-wire pin to GPIO 18. Also, I can confirm it works both with raspistill and w1-therm simultaneously.
/boot/cmdline.txt:
dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait bcm2708.w1_gpio_pin=18
/etc/modules:
w1-therm
w1-gpio pullup=1
i2c-dev
i2c-bcm2708
spi-bcm2708
snd-bcm2835
cuse
Back-to-back execution of running raspistill, followed by reading raw values of /sys/bus/w1/devices/28-XXXXXXXXXXXX/w1_slave:
[email protected]:/home/scripts# raspistill -v
Opacity 255
Closing down
[email protected]:/home/scripts# ./temperature.sh
Temperature1: 3250
Temperature2: -3687
Temperature3: -3812
Temperature4: 2937
Temperature5: -3687
Temperature6: 3312
Raspbian Version:
Linux raspberry-node05 3.10.25+ #616 PREEMPT Mon Dec 23 18:13:02 GMT 2013 armv6l GNU/Linux
Projects:
