- Contact: Website
Xorg, configuring bpp (defaults to 16)
I installed Xorg with LXDE. By default it runs without any xorg.conf, but I noticed some colours weren't correct and I suspect that the bpp defaulting to 16 causes this. However, `man xorg.conf` states the default bpp is 24, so why would the RPi choose 16? Did I miss something, is this easy to configure or is the bpp not to blame?
Re: Xorg, configuring bpp (defaults to 16)
The framebuffer on boot-up (which is what the console device is drawn on) is in 16-bit mode. X detects this and uses this mode. Even when changing the framebuffer mode to 24/32 bit for the console, I can't yet make X work on it.
EDIT: on the fixes to-do list
Note that 16bpp will be faster....
- Contact: Website
Yeah, I just noticed the same thing, and was looking for a way to change that. Thanks for the confirmationteh_orph wrote:The framebuffer on boot-up (which is what the console device is drawn on) is in 16-bit mode. X detects this and uses this mode. Even when changing the framebuffer mode to 24/32 bit for the console, I can't yet make X work on it.
Can you confirm that omxplayer actually runs in > 16 bpp? I was trying to compare that to Xorg, but omxplayer segfaults when you pass it a simple imagejamesh wrote:Note that 16bpp will be faster....
I get wrong colors when I use freerdp, would it be the same problem?
It's fine in rdesktop
- Raspberry Pi Engineer & Forum Moderator
@felix123
What image/firmware are you running?
Try updating firmware to latest GitHub (Hexxeh's updater tool is one way). There has been a fix to RGB ordering in 32bpp mode.
I'm using the arch 29-04-12 image and I did a pacman -Syyu. I just did an update with Hexxeh's tool but the result is the same.
Also I notice if I drag the icons on the desktop around, then the correct color will show beneath the positions I drag.
- Contact: Website
I am pretty sure that those problems are not related to the RPi booting in 16 bpp
It is very odd. "fbset -depth N" appears to work, but then Xorg switches back to 16 bits when it starts. "startx -- -depth N -fbbpp Z" switches the framebuffer into the requested mode, but either displays black or segfaults.teh_orph wrote:The framebuffer on boot-up (which is what the console device is drawn on) is in 16-bit mode. X detects this and uses this mode. Even when changing the framebuffer mode to 24/32 bit for the console, I can't yet make X work on it.
The following undocumented settings in config.txt do appear to work, however. This probably requires recent firmware:
framebuffer_depth=32
framebuffer_ignore_alpha=1
I can only make it work if I start the fb console in 32-bit mode - changing at run time won't do it. Append to you kernel command line "bcm2708_fb.fbdepth=32" and reboot the system. Make sure you are using the new start.elf and have "framebuffer_ignore_alpha=1" in your config.txt.
Then start X, and it'll pick 32-bit mode. You won't need the -fbbpp option. No need for fbset.
X is not too much slower in 32-bit versus 16.
(this is what I'm doing in Arch with a hand-compiled git Xorg)
Just using the undocumented config.txt settingsteh_orph wrote:I can only make it work if I start the fb console in 32-bit mode - changing at run time won't do it. Append to you kernel command line "bcm2708_fb.fbdepth=32" and reboot the system. Make sure you are using the new start.elf and have "framebuffer_ignore_alpha=1" in your config.txt.
