"Segmentation fault cups: unable to reload scheduler."Code: Select all
sudo /etc/init.d/cups startno, it's just no one knows how to do that and you provided too little information.caffeinepizza wrote:Does this need to be moved to another forum?
My real question is how do I install a version newer than 1.5.3 on the raspberry pi. Version 1.5.3 has a bug that makes it incompatible with newer versions of cups ipp.bubbl wrote:no, it's just no one knows how to do that and you provided too little information.caffeinepizza wrote:Does this need to be moved to another forum?
try this tutorial. if no luck, let me know http://www.bartbania.com/index.php/cups ... y-printer/
sudo dpkg-reconfigure cupsbtw, what bug are you talking about? can you provide link to official bug documentation?caffeinepizza wrote:I couldn't get cups 1.7 to work after compiled, but 1.6.4 installed and started, I'm testing and will provide results
https://wiki.archlinux.org/index.php/CU ... nt_packagebubbl wrote:btw, what bug are you talking about? can you provide link to official bug documentation?caffeinepizza wrote:I couldn't get cups 1.7 to work after compiled, but 1.6.4 installed and started, I'm testing and will provide results
No worries. I've used arch on pc tons.bubbl wrote:Good luck with Arch, especially if you are a beginner Linux user
