asexton
Feedparse module on Raspbian
Sat Nov 23, 2013 7:03 pm
Hi All,
I'm a complete beginner to this and just got my Raspberry Pi today. I followed all the set up instructions available on the adafruit tutorial site, with no errors. I decided to try my first project which is the gmail notifier using LED's available here: http://learn.adafruit.com/raspberry-pi- ... are-python.
However, I'm having trouble installing the feedparser module and keep getting the error in the attached image. I have followed the instructions step by step multiple times and still get the same error. Anywhere I looked online I see people discussing feedparse errors but none of them have the same issue.
If anyone could be of any assistance I would really appreciate it as I'm excited to get my pi projects up and running and have come to a momentary stand still.
Re: Feedparse module on Raspbian
Sun Nov 24, 2013 12:23 am
It worked for me. I'm assuming you have a working Internet connection and can access things like http://google.com or http://news.bbc.co.uk from your RPi.
So we need to look at why you can't resolve and connect to pypi.python.org
Start with
ping pypi.python.org
Which should generate something like
root@pi ~ # ping pypi.python.org
PING global-ssl.fastly.net (185.31.17.184) 56(84) bytes of data.
64 bytes from 185.31.17.184: icmp_req=1 ttl=54 time=53.7 ms
64 bytes from 185.31.17.184: icmp_req=2 ttl=54 time=54.0 ms
^C64 bytes from 185.31.17.184: icmp_req=3 ttl=54 time=53.6 ms
--- global-ssl.fastly.net ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 10320ms
rtt min/avg/max/mdev = 53.672/53.833/54.084/0.322 ms
root@pi ~ #
Then try
lynx http://pypi.python.org/simple
or
curl http://pypi.python.org/simple
or
wget http://pypi.python.org/simple
If those work then lets look in /root/.pip/pip.log to see if it tells you what failed.
It could be a transient error so re-running the 'sudo pip install feedparser' make work second go.
asexton
Mon Nov 25, 2013 5:54 pm
Apologies for the delay in replying, despite my best efforts I didn't get a chance to try this at work.
The issue I had in accessing the pypi website was resolved once I ran the wget command. Thank you very much. I never predicted I'd get such satisfaction out of lighting up an LED
