sharix
Exporting graphics on a headless Pi
Fri Nov 22, 2013 3:02 pm
Mathematica can not export any format of graphics witohut the front-end running. It will display these error messages:
In[3]:= p=Plot[Sin[x],{x,0,2 Pi}]
Out[3]= -Graphics-
In[4]:= Export["testplot.png",p]
Developer`LaunchFrontEnd::nxsrv: An x server is required for that operation.
Rasterize::nofe: A front end is not available; Rasterize requires a front end.
Out[4]= $Failed
To be able to export graphics on a Pi that does not run a front-end, for example on a headless server, you have to install Xvfb (or a similar program that emulates a display).
Then you start mathematica like this if you want 24 bit graphics:
xvfb-run -s "-screen 0 640x480x24" /opt/Wolfram/WolframEngine/10.0/Executables/math
or if you want 8 bit graphics:
xvfb-run -s "-screen 0 640x480x8" /opt/Wolfram/WolframEngine/10.0/Executables/math
And it will work:
In[1]:= p=DensityPlot[{Sin[Sqrt[x] + Log[y]]}, {x, 0, \[Pi]^2}, {y, 0, E^\[Pi]}]
Out[1]= -Graphics-
In[2]:= Export["testplot24.png",p]
(On my first-gen 256 MB model B it takes about 50 seconds to render the graphics with 24 bit colors.)
dennisw
Re: Exporting graphics on a headless Pi
Fri Nov 22, 2013 5:35 pm
I just ssh -X into my Pi. In other words, I use X forwarding. There shouldn't be any need for a virtual frame buffer or something like xvnc. Please let me know if the following doesn't work for you.
In /etc/ssh/sshd_config on the Pi, change X11Forwarding to yes in order to enable it.
For your PC, ssh -X works from the command line in Linux. In Putty on Windows, set Enable X11 Forwarding in Connection > SSH > X11
raspberrypi.stackexchange.com --- mathematica.stackexchange.com
Arnoud
Fri Nov 22, 2013 6:08 pm
I have been using tightvncserver to have the graphics rendered. The first time around it is a bit pokey, but subsequent graphics exports are better (usually about 1s or so):
pi@raspberry-wri2 ~ $ tightvncserver :42
New 'X' desktop is raspberry-wri2:42
Starting applications specified in /home/pi/.vnc/xstartup
Log file is /home/pi/.vnc/raspberry-wri2:42.log
pi@raspberry-wri2 ~ $ export DISPLAY=:42
pi@raspberry-wri2 ~ $ wolfram
Wolfram Language (Raspberry Pi Pilot Release)
Copyright 1988-2013 Wolfram Research
Information & help: wolfram.com/raspi
In[1]:= Export[ "test.png", Plot[0,{x,0,1}] ]
In[2]:= Export[ "test.png", Plot[0,{x,0,1}] ] // AbsoluteTiming
Out[2]= {1.056819, test.png}
In[3]:=
sharix
Fri Nov 22, 2013 6:10 pm
dennisw wrote:I just ssh -X into my Pi. In other words, I use X forwarding. There shouldn't be any need for a virtual frame buffer or something like xvnc. Please let me know if the following doesn't work for you.
This of course works, but is not practical if you want to run automated mathematica scripts that export graphics, which is what I wanted to do.
I will try with tightvncserver, some speedup from xvfb would be nice. However, xvfb also becomes faster if graphics are rendered more than once per session:
Out[1]= -Graphics-
In[2]:= Export["testplot.png",p]//AbsoluteTiming
Out[2]= {43.213339, testplot.png}
In[3]:= Export["testplot.png",p]//AbsoluteTiming
Out[3]= {8.626120, testplot.png}
In[4]:= Export["testplot.png",p]//AbsoluteTiming
Out[4]= {8.615019, testplot.png}
In[5]:=
edit: tried with tightvncserver:
Out[1]= -Graphics-
Out[2]= {143.703919, testplot.png}
Out[3]= {15.838517, testplot.png}
Out[4]= {4.204656, testplot.png}
In[5]:= Export["testplot.png",p]//AbsoluteTiming
Out[5]= {3.641392, testplot.png}
In[6]:=
It does get better eventually but for the first time xvfb is way faster.
rgall
Sun Apr 13, 2014 2:26 pm
I am trying output graphics from the command line from a remote shell .
I have executed the following script
sudo xvfb-run -s "-screen 0 640x480x24" -e /dev/stdout /opt/Wolfram/WolframEngine/10.0/Executables/math
The follow is output
  • [[dix] Could not init font path element /usr/share/fonts/X11/misc, removing from list!
    [dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing from list!
    [dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, removing from list!
    [dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, removing from list!
    [dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing from list!
    [dix] Could not init font path element /usr/share/fonts/X11/75dpi, removing from list!
    [dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType, removing from list!list]
    I enter the following.
    Out[1]= -Graphics-
    I still get the following:
    • Developer`LaunchFrontEnd::nxsrv: An x server is required for that operation.
      Out[4]= $Failed
Any Ideas?
hal8000
Fri Apr 18, 2014 10:12 am
If your Pi is running Rasbian then X forwarding is already enabled.
On your remote computer, start a terminal and type:
ssh -X pi@192.168.0.1
(Replace 192.168.0.1 with your Pi's LAN address or hostname if you modified /etc/hosts )
and it should allow remote access. My second Raspberry Pi is headless and I've posted
a screenshot on img mur
http://i.imgur.com/frBg6j1.png
Hopefully you should be able to see that it works without any additional commands except
ssh -X The client is an Acer Aspire 5734 laptop running Linux Mint 16 with native resolution
of 1366x768. The density plot shown took less than 1 second, not tried anything more graphic
intensive yet.
hal8000
Fri Apr 18, 2014 12:34 pm
Sorry, cant edit my previous post. On Rhasbian, running raspi-config and enabling SSH
enables X forwarding.
R61zt
Mon May 12, 2014 2:59 pm
I did things differently. The headless rPi was running a c program and top showed it to be less than 1% busy doing only that. So as not to disturb that critical process, I used cp <filename> <filename.bak> from the terminal of the ssh originating second rPi and then
scp <filename.bak> pi@192.168.xxx.yyy:~<path/filename.bak>
where 192.168.xxx.yyy is the ip address of the controlling rPi, path/ is some location on the controlling rPi and filename.bak is the filename to create there.
If you are not used to <example> brackets in computerish explanations then get a pen and paper and try working out the relationship between
I am not an <insult>
and
I am not an idiot
This does not fix your problem with getting a headless rPi to work as a renderer and then send you a screenful. It does though show one way of getting results off a headless rPi to do some display work with elsewhere.
dennisw
Tue May 13, 2014 5:23 am
R61zt wrote:I did things differently. The headless rPi was running a c program and top showed it to be less than 1% busy doing only that. So as not to disturb that critical process, I used cp <filename> <filename.bak> from the terminal of the ssh originating second rPi and then
and
I am not an idiot
A little less rudeness could go a long way.
Note that angle brackets have significance in redirection and can be ambiguous when used as template-style markers. It's true that lots of people do use them that way - even me sometimes I think. Your examples work fine without them and there are even code markers here that will set commands apart from other text:
cp filename filename.bak
alexatwri
Fri Aug 01, 2014 3:58 pm
It might be worth noting that the process of starting a VNC session and providing a FE on the headless Raspberry Pi has been automated in the latest release (using turbovnc):
In[1]:= Rasterize[Disk[]]
Out[1]= -Graphics-
The same limitations apply. It's slow when initializing the vnc session and FontEnd, but they then persist for the remainder of the session.
Return to “Mathematica”
