dennisw
Mathematica on a 256MB Model B
Fri Nov 22, 2013 7:54 am
For those who may be wondering, Mathematica works on a 256MB Model B, although sluggishly. I don't have a 512MB one to compare it to yet though,
raspberrypi.stackexchange.com --- mathematica.stackexchange.com
Davespice
Contact: Twitter
Re: Mathematica on a 256MB Model B
Fri Nov 22, 2013 2:02 pm
Hi there, since using the X desktop doesn't use the GPU you could try changing the memory split in raspi-config.
Reduce the GPU memory to say 16 or 32 and see if that helps. That leaves more memory for Linux itself and Linux tasks to use.
sudo raspi-config
geev03
Mon Nov 25, 2013 12:14 pm
Yes, it helps. Reduced GPU memory to 16MB and Mathematica works better on this " 'headless' 256MB Model B "
256 MB Model B
thradtke
Mon Nov 25, 2013 2:01 pm
Would you mind testing wether W|A queries work? Just enter '==' (without quotes) and state your problem.
On my system, Wolfram tries to fire up Java for a minute or two, then stops with some error messages. I think this is due to too little memory.
Rocket Scientist.
geev03
Mon Nov 25, 2013 7:18 pm
Did a W|A query on Mathematica ( & Wofram ) ; they both appear to work on my 256MB Model B. ( http://goo.gl/tYSW2H
thradtke
Mon Nov 25, 2013 7:32 pm
Ok, thanks for reporting!
Edit: Just noticed it needs to connect to the internet for certain tasks. Wasn't aware of this :roll: . Still, have to figure out what's wrong with my Java setup. No problem compiling and running applications from terminal or Geany.
Rocket Scientist.
thradtke
Fri Nov 29, 2013 5:34 pm
Java starts up successfully with a GPU memory of 16MB, but is on the edge. I had one crash using Mathematica, and it was the first one in this Pi's life!
Fortunately a 512MB model is on its way to the german everglades :D.
Rocket Scientist.
Jim Manley
Location: SillyCon Valley, California, and Powell, Wyoming, USA, plus The Universe
Mon Jan 13, 2014 3:56 am
thradtke wrote:Fortunately a 512MB model is on its way to the german everglades :D.
There are alligators in Germany ... outside zoos??? Wow, global climate change has penetrated much further afield than I had ever imagined it could! :shock: Were you referring to somewhere North of Hamburg, e.g., the Nordsee area? Enquiring minds want to know! :lol:
thradtke
Mon Jan 13, 2014 5:52 am
Hi Jim. It's called the Emsland, basically a marsh. Somehow I stuck here :lol:. Oldenburg is the next civilized city, about 40 km away from me.
And we're still waiting for the global climate change, but with December and January more or less w/o temperatures below 273.15 K at sea level, there's a chance.
Rocket Scientist.
bobthechemist
Fri Mar 14, 2014 8:38 pm
For what it's worth, I performed some benchmarking of Mathematica on the RPi and posted the results here. I observed considerable improvements with overclocking; however, there were negligible gains on my benchmarking functions with changing the memory split.
Return to “Mathematica”
