There is a menu item called Wolfram but that doesn't do a lot
Running mathematica from LXTerminal works though
regards
Simon
the correct path is "/usr/bin/mathematica".shijor wrote:I had the same issue. You can launch Mathematica as below
-> Open a terminal window
-> Run "/user/bin/Mathematica"
Now Mathematica will be opened!
sharix wrote:the correct path is "/usr/bin/mathematica".shijor wrote:I had the same issue. You can launch Mathematica as below
I had the same problem. Completely fresh & latest Raspbian on a 512 MB model B with 8 GB card, system apt-get updated and rpi-updated before installing Mathematica. Possible non-standard settings: auto-login user pi to desktop, CET timezone, en-gb wireless keyboard+mouse, nl-nl locale, custom hostname, custom password.alexatwri wrote:menu icon not being populated.
