adnetag
wlan0 down after apt-get upgrade
Mon Nov 18, 2013 10:33 pm
As I've mentioned before I've run
apt-get update && upgrade
and my wlan0 isin't working anymore - please help. The details you've may be asking me:
uname -a
Linux pi.local 3.6.11+ #538 PREEMPT Fri Aug 30 20:42:08 BST 2013 armv6l GNU/Linux
lsusb
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 005: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Bus 001 Device 006: ID 04fc:0801 Sunplus Technology Co., Ltd
Bus 001 Device 007: ID 046d:c315 Logitech, Inc. Classic New Touch Keyboard
ifconfig & iwconfig
ifconfig
eth0      Link encap:Ethernet  HWaddr b8:27:eb:52:db:e1
          inet addr:192.168.0.182  Bcast:192.168.0.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:13098 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10478 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:8288713 (7.9 MiB)  TX bytes:4455841 (4.2 MiB)
iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
lsmod
xt_multiport            1582  8
iptable_filter          1493  1
ip_tables              11490  1 iptable_filter
x_tables               16962  3 ip_tables,xt_multiport,iptable_filter
snd_bcm2835            16432  0
snd_pcm                77728  1 snd_bcm2835
snd_seq                53482  0
snd_timer              20110  2 snd_pcm,snd_seq
snd_seq_device          6462  1 snd_seq
snd                    58744  5 snd_bcm2835,snd_timer,snd_pcm,snd_seq,snd_seq_device
snd_page_alloc          5169  1 snd_pcm
crc_ccitt               1530  0
rt2x00usb              11240  0
rt2x00lib              42342  1 rt2x00usb
mac80211              273979  2 rt2x00lib,rt2x00usb
cfg80211              184390  2 mac80211,rt2x00lib
rfkill                 18298  1 cfg80211
leds_gpio               2243  0
led_class               3570  2 leds_gpio,rt2x00lib
evdev                   9450  2
joydev                  9356  0
I've already try to reinstall drivers as a last time - this time it didn't help :(
pi@pi / $ cat /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
and finally
wpa_supplicant.conf
sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
#network={
# ssid="SKYA767C"
# psk="House!-01"
# proto=RSN
# key_mgmt=WPA-PSK
# group=CCMP TKIP
network={
ssid="SKYA767C"
psk="House!-01"
proto=WPA
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
Please note that above # are as I've try 1st and 2nd configuration and any of them didn't work.
What else I need to do?
Can anyone help to fix my wlan0 interface
