What he said.
I also run a full backup (create a img file) with the below script which I found on the forums here:
I think I might have added a mod or two. It creates a img file and then transfers it to my linux server via a nfs mount. I've uncommented the tar lines as the compression doesnt safe much and takes too long.
#!/bin/bash
# Setting up directories
SUBDIR=raspberrypi_backups
DIR=/mnt/disk2/$SUBDIR
echo "Starting RaspberryPI backup process!"
# First check if pv package is installed, if not, install it first
PACKAGESTATUS=`dpkg -s pv | grep Status`;
if [[ $PACKAGESTATUS == S* ]]
then
echo "Package 'pv' is installed."
else
echo "Package 'pv' is NOT installed."
echo "Installing package 'pv'. Please wait..."
sudo apt-get -y install pv
fi
# Check if backup directory exists
if [ ! -d "$DIR" ];
then
echo "Backup directory $DIR doesn't exist, creating it now!"
mkdir $DIR
fi
# Create a filename with datestamp for our current backup (without .img suffix)
OFILE="$DIR/backup_$(date +%Y%m%d_%H%M%S)"
# Create final filename, with suffix
OFILEFINAL=$OFILE.img
# First sync disks
sync; sync
# Shut down some services before starting backup process
echo "Stopping some services before backup."
#service apache2 stop
#service mysql stop
#service cron stop
# Begin the backup process, should take about 1 hour from 8Gb SD card to HDD
echo "Backing up SD card to USB HDD."
echo "This will take some time depending on your SD card size and read performan ce. Please wait..."
SDSIZE=`sudo blockdev --getsize64 /dev/mmcblk0`;
sudo pv -tpreb /dev/mmcblk0 -s $SDSIZE | dd of=$OFILE bs=1M conv=sync,noerror if lag=fullblock
# Wait for DD to finish and catch result
RESULT=$?
# Start services again that where shutdown before backup process
echo "Start the stopped services again."
#service apache2 start
#service mysql start
#service cron start
# If command has completed successfully, delete previous backups and exit
if [ $RESULT = 0 ];
then
echo "Successful backup, previous backup files will be deleted."
rm -f $DIR/backup_*.tar.gz
mv $OFILE $OFILEFINAL
#echo "Backup is being tarred. Please wait..."
#tar zcf $OFILEFINAL.tar.gz $OFILEFINAL
#rm -rf $OFILEFINAL
#echo "RaspberryPI backup process completed! FILE: $OFILEFINAL.tar.gz"
exit 0
# Else remove attempted backup file
else
echo "Backup failed! Previous backup files untouched."
echo "Please check there is sufficient space on the HDD."
rm -f $OFILE
echo "RaspberryPI backup process failed!"
exit 1
fi
