FWIW, you may be interested in these measurements: http://www.cpmspectrepi.webspace.virgin ... rger_A1399 (esp. when compared with those for the "clone" that follows)Jozoguy39 wrote:I found it works using most USB to microUSB cables because the supply has 5v and 1a and I've tested It out
This page is cool! I think it should be added to RPi wiki.FTrevorGowen wrote:FWIW, you may be interested in these measurements: http://www.cpmspectrepi.webspace.virgin ... rger_A1399 (esp. when compared with those for the "clone" that follows)Jozoguy39 wrote:I found it works using most USB to microUSB cables because the supply has 5v and 1a and I've tested It out
Trev.
Thank you. As it happens, those PSU's whose loading characteristics I've measured and I've used to power a Pi or two have been added to the wiki by me (if they weren't already there) with a reference link.allfox wrote:This page is cool! I think it should be added to RPi wiki.FTrevorGowen wrote:FWIW, you may be interested in these measurements: http://www.cpmspectrepi.webspace.virgin ... rger_A1399 (esp. when compared with those for the "clone" that follows)Jozoguy39 wrote:I found it works using most USB to microUSB cables because the supply has 5v and 1a and I've tested It out
Trev.
