Yes, you are right. I have updated the original post. Thanks.futaris wrote:I think you mean the TP-LINK TL-WN725N ...
Traceback (most recent call last)
File "usr/local/lib/python2.7/dist-packages/cx_Freeze/initscripts/Console.py", line 27, in <module>
File "main.py", line 45, in <module>
File "main.py", line 17, in leased_ip_get
IndexError: list index out of range.
Thanks for trying the app. Three questions:davidte wrote:I have a problem!
When the smartphone are connecting to piracast, after of "Wireless display negotiation completed"
Tested with with nexus 4, xperita tablet z, lg g2, same error.Code: Select all
Traceback (most recent call last) File "usr/local/lib/python2.7/dist-packages/cx_Freeze/initscripts/Console.py", line 27, in <module> File "main.py", line 45, in <module> File "main.py", line 17, in leased_ip_get IndexError: list index out of range.
Thank for your work!
#The format of this file is documented in the dhcpd.leases(5) manual page.
#This lease file was written by isc-dhcp-4.2.2
read_all_sta:
read_all_sta:
read_all_sta:
Wireless display negotitation completed!
Leasd IP: 192.168.2.30
Reveived 'OPTIONS * RTSP/1.0\r\nCSeq: 0\r\nRequire: org.wfa.wfda1.0\r\n\r\n'
File "main.py", line 50, in <module>
File "sink.py" line 127, in source_connect
AttributeError: 'NoneType' object has no attribute 'group'
Uhm. I wrote the negotiation portion of the code based on the transaction with a Nexus 4. Seems like Xperia tablet may be returning a slightly different payload (and is causing the parsing to fail). I will attempt to include a transaction logger in the next release to help debugging these scenarios.davidte wrote:Now with Nexus 4 work fine.
With Xperia tablet z after "wps passed!"Code: Select all
read_all_sta: read_all_sta: read_all_sta: Wireless display negotitation completed! Leasd IP: 192.168.2.30 Reveived 'OPTIONS * RTSP/1.0\r\nCSeq: 0\r\nRequire: org.wfa.wfda1.0\r\n\r\n' [...] Traceback (most recent call last): File "usr/local/lib/python2.7/dist-packages/cx_Freeze/initscripts/Console.py", line 27, in <module> File "main.py", line 50, in <module> File "sink.py" line 127, in source_connect AttributeError: 'NoneType' object has no attribute 'group'
Thanks for the feedback.segator wrote:yesterday i was test your application, it works well, as you were saying in the video i test sometimes takes several times to work.
I found the following:
-The image sometimes has graphical glitches
-There are at least 2 second delay between nexus 4 actions and TV
- Sometimes error connecting jumps (need detail?)
The sound does not work (missing configuration?)
you're doing a great job! keep it up
if I can help in any way, I'm here
Increase rmem_default
Kill running applications
app: no process found
p2p_get_status...
Peer status: 0
Enable p2p ...
p2p_get_status...
p2p_status_get:
Peer status: 2
ad infinitumpiracast use Wi-Di(Wifi Direct)la_tristesse wrote:How do I connect the rasspberry pi to my network if the network is set to a static ip? Do I have to connect the pi with ethernet cable or do I have to setup something else?
Here's my terminal output after doing "sudo ./main"
Increase rmem_default Kill running applications app: no process found p2p_get_status... Peer status: 0 Enable p2p ... p2p_get_status... p2p_status_get: Peer status: 2 ad infinitum
So how do I connect my device (asus t100 windows 8.1) to the raspberry pi if they arent on the same network?segator wrote: This means that you do not use your router to connect your devices, this system conect directly the devices.
The configuration of the raspberry to your network is indifferent to piracast.
As indicated by segator, in a Miracast session the two wireless endpoints connect to each other 'directly' without going through a router (via Wifi-direct). Once a wifi connection is bridged between the two wireless endpoints, one of the wifi endpoints 'acts' as a router and issue IP address to another. In a Miracast session, the receiver (eg. Piracast) issues the IP to the sender (Asus T100).la_tristesse wrote:So how do I connect my device (asus t100 windows 8.1) to the raspberry pi if they arent on the same network?segator wrote: This means that you do not use your router to connect your devices, this system conect directly the devices.
Don't worry about the no process found errors - that was me being lazy and always kills relevant processes on start up. Since nothing is launched, the OS will report those errors.la_tristesse wrote:Thanks for your detailed answer. My sender (asus t100) doesnt find the the receiver (raspberry pi). I did everything as describes and watched the video tutorials serval times. Heres are screenshot from the terminal output after I started piracast.
https://dl.dropboxusercontent.com/u/118 ... G_1499.JPG
Maybe the issue is related to "wpa_supplicant: no process found" or "hoastapd: no process found"
Thanks for the feedback. Good to know that it works well for you.Exand_0 wrote:This project is really awesome. Works perfect with Nexus 10. I would appreciate, if you could extend time, when piracast is staying connected.
Also is it somehow possible to make piracast be avialable over wlan?
Increase rmem_default...
Kill running application...
p2p_get status...
p2p_status_get:
Peer status: 0
Enable p2p...
p2p_get status...
p2p_status_get:
Peer status: 2
p2p_get status...
p2p_status_get:
Peer status: 2
p2p_get status...
p2p_status_get:
Peer status: 2
p2p_get status...
p2p_status_get:
Peer status: 11
wlan0 Scan completed :
Cell 01 - Address: BE:F5:AC:DA:4B:68
ESSID:"DIRECT-"
Protocol:IEEE 802.11g
Frequency:2.437 GHz (Channel 6)
Encryption key:on
Bit Rates:54 Mb/s
IE: Unknown: DD760050F204104A0001101044000101101200020004103B0001001047001055B7F6F4E6B954F48721F61049794A74102100012010230001201024000120104200012010540008000A0050F204000510110015ED839CEC9881EC9790EC8AA4EC9794EC9790EC8AA41008000243881049000600372A000120
Quality=0/100 Signal level=96/100
p2p_get status...
p2p_status_get:
Peer status: 2
p2p_get status...
p2p_status_get:
Peer status: 8
Breaking out of loop
p2p_peer_devaddr_get:
peer_devaddr: BE:F5:AC:DA:4B:68
p2p_req_cm_get:
wlan0 p2p_get:
CM=pbc
p2p_wpsinfo:
p2p_status_get:
peer_status: 8
p2p_set_nego:
mac: BE:F5:AC:DA:4B:68
p2p_status_get:
peer_status: 10
Negotiation suceeded!
p2p_role_get:
Role: 2
p2p_opch_get:
wlan0 p2p_get:
Configuration file: p2p_hostapd.conf
drv->ifindex=3
l2_sock_recv==l2_sock_xmit=0x0x1a33630
Failed to request a scan of neighboring BSSes
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan0 with hwaddr 64:66:b3:1e:7f:9b and ssid 'DIRECT-RT'
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid_ops
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_key_ops
do_wps
Selected interface 'wlan0'
OK
wps passed!
read_all_sta:
read_all_sta:
read_all_sta:
1. Checkrtang wrote: If:
1. You are using this the exactly specified dongle dongle TP-LINK TL-WN725N
2. And you executed setup.py using sudo (have to be in superuser mode to install driver)
3. And you are using the September 25, 2013 raspberry Pi image (the driver ONLY works with this image. I had to re-compile the driver for this image due to kernel dependencies. I caught this when I tested against the image from May 2013. If you are using earlier image you may get 'unknown symbols table' or 'symbol insertion failed' or the likes during driver installation
Intel WiDi is intigated in Win8.1 no special Drivers needed.
Also Miracast is supported on Intel BayTrail Processors.
For me it works best with a Netgear PTV3000.
http://software.intel.com/en-us/articles/4th-generation-intel-atom-processor-based-tablet-overview wrote:Intel® Wireless Display benefits on Intel Atom processor
Intel® WiDi enables content-protected HD streaming and interactive usages between tablets and TVs. It supports full 1080p video and low latency gaming, and is Miracast compliant Intel® WiDi can be used to link health indicators as well. A few of the capabilities of Miracast-enabled apps are:
Share & Enjoy: use a big screen HDTV to enjoy and share media with family and friends
Wireless: quickly and securely connect with standard Wi-Fi to a TV without cables
Easy Set-up: simple user interface makes it easy to connect; no additional remote controls
Portable: adapter is small and light, so solution can move with you
I got Piracast to work at home!thtpark wrote:I have a LG G-pad (LG-V500) and I got the following output.
wps passed!
read_all_sta:
read_all_sta:
read_all_sta:
[/code]
For some reason, it doesn't successfully connect (but it does show "Piracast" under the Wi-Fi direct setting.
Any idea?
Yeah sorry, I don't know what it would be then.la_tristesse wrote:1. Checkrtang wrote: If:
2. Check
3. Check
I'm clueless. Must be related to the receiver device. Also the Asus T100 is confirmed to be miracast compatible: http://www.transformerforums.com/forum/ ... pport.html
For me it works best with a Netgear PTV3000.http://software.intel.com/en-us/articles/4th-generation-intel-atom-processor-based-tablet-overview wrote:Intel® Wireless Display benefits on Intel Atom processor
Thank you. That's a very valuable piece of information. I've been lazy and assumed there's only one Miracast enabled device present in the Piracast code. I'll incorporate this feedback into future revisions.Minz0r wrote:I got Piracast to work at home!thtpark wrote:I have a LG G-pad (LG-V500) and I got the following output.
wps passed!
read_all_sta:
read_all_sta:
read_all_sta:
[/code]
Any idea?
After several read_all_sta: messages my S4 got accepted.
But if I try this setup at the Office it gets not further than read_all_sta.
At the Office there were several Devices that are Miracast enabled, perhaps Piracast could not select the right Device to enable the Stream.
Users browsing this forum: No registered users and 5 guests
