redhawk wrote:As far as I'm aware HDMI audio is digital so it shouldn't be possible to get any buzzing or audio effects usually attributed to analogue.
Richard S.
true, but stranger things have happened. theoretically its possible to mangle/distort/wipe-out a digital signal periodically, 50 times a second, which may express itself as a "buzz". Especially if the distortion is caused by a 50Hz repeating small (millisecond duration) peak, caused by for example by a light dimmer.
but it probably should then also affect the image...
in any case it cannot harm to check the grounding.
