snlpnstslocn
E: Unable to locate package php-cgi
Sat Nov 09, 2013 3:57 pm
Hi All,
I am trying to install lighttpd on raspbmc.
When running the following commandç
sudo apt-get install php5-common php5-cgi php5
the command run but I get the following error message:
what is this due to?
Any help will be much appreciated.
Thanks in advance.
Re: E: Unable to locate package php-cgi
Sat Nov 09, 2013 6:37 pm
There is no package called php-cgi.
sudo apt-get install php5-cgi php5-common
should install everything you need.
snlpnstslocn
Sat Nov 09, 2013 7:55 pm
thank you DougieLawson I am totally new to linux command line your help is highly appreciated.
I re-run the command as you suggested and package got installed. 2 more things:
- when installing this other package I got the following:
sudo apt-get install php5-mysql
[....] Starting web server: apache2apache2: Could not reliably determine the server's fully qualified domain name, using ::1 for ServerName
(98)Address already in use: make_sock: could not bind to address [::]:80
(98)Address already in use: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
Unable to open logs
Action 'start' failed.
The Apache error log may have more information.
failed!
as I understand this is becauae I didn't assign a fqdn into apache configuration. Since I am doing this just to put up a test page for myself can this be the default loopback 127.0.0.1?
- when trying to get into the /www directory I always get the No such file or directory error. What am I missing here?
Sat Nov 09, 2013 10:45 pm
You don't need a FQDN, that's optional.
Unless you're doing something special Apache will bind to the 0.0.0.0:80 address/port so http://localhost or http://127.0.0.1 should pull up your index.htm, index.html or index.php page (or the default 404.html if those don't exist).
Have a look in your apache2.conf.
Add (or update) the errorlog directive
ErrorLog /var/log/apache2/error.log
That should mean any errors during startup get logged.
Then you need to use
sudo /etc/init.d/apache2 start
to get the web server started. (If you try that from a non-privileged user you'll get the errors you're reporting.)
