DiscoChoir
SD requirements
Sat Nov 09, 2013 5:58 am
The starter guide asks for a 4GB class 4 sd. I believe (though I am new to this) that SD cards can behave odd if they exceed the abilities of the port they are in. I'm looking to run a minecraft server and already have a 16GB UHS-1 45mb/s SD card. I'm hoping to use this card for some extra juice, will that cause any problems?
Thanks for any help.
FTrevorGowen
Re: SD requirements
Sat Nov 09, 2013 9:30 am
DiscoChoir wrote:The starter guide asks for a 4GB class 4 sd. I believe (though I am new to this) that SD cards can behave odd if they exceed the abilities of the port they are in. I'm looking to run a minecraft server and already have a 16GB UHS-1 45mb/s SD card. I'm hoping to use this card for some extra juice, will that cause any problems?
Most good quality, "known brand", SDHC (or micro-SDHC + adapter) 4 - 16Gb, class 4 to class 10 cards should be O.K. There is little or no "apparent" speed improvement (for most "tasks") above class 10**. More detailed info. can be found at:
http://elinux.org/RPi_SD_cards
and, FWIW, the cards I've used, so far, are shown here:
http://www.cpmspectrepi.webspace.virgin ... cards.html
Trev.
**Those cards being highly optimised for "camera use".
