brrmatteo
Errore durante installazione gui archlinux
Wed Nov 06, 2013 5:06 pm
Salve a tutti. Oggi ho provato ad installare arch linux. Fino a qui tutto ok però quando ho provato a installare lxde e avviarlo mi ha dato errore:
[root@alarmpi ~]# startx
X.Org X Server 1.14.4
Release Date: 2013-10-31
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.34-1-FARM armv6l
Current Operating System: Linux alarmpi 3.6.11-16-ARCH+ #1 PREEMPT Tue Aug 20 19:25:48 CDT 2013 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1776 bcm2708_fb.fbheight=952 bcm2708.boardrev=0xd bcm2708.serial=0x2087b775 smsc95xx.macaddr=B8:27:EB:87:B7:75 sdhci-bcm2708.emmc_clock_freq=100000000 vc-cma-mem=0/0x11800000@0xd400000 mem=0xc400000@0x0 mem=0x11800000@0xd400000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  ipv6.disable=1 avoid_safe_mode=1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=noop rootwait
Build Date: 01 November 2013  02:18:25PM
Current version of pixman: 0.30.2
        Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov  6 10:05:30 2013
(==) Using config directory: "/etc/X11/xorg.conf.d"
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
/root/.xinitrc: line 1: exec: ck-launch-session: not found
xinit: connection to X server lost
waiting for X server to shut down (EE) Server terminated successfully (0). Closing log file.
[root@alarmpi ~]#
sdjf
Re: Errore durante installazione gui archlinux
Thu Nov 07, 2013 2:43 pm
pacman -Q pixman
Le mie scuse, non so italiano. necessario assicurarsi di avere le versioni recenti di pixman e altri pacchetti con il comando di cui sopra.
Se non lo fai, poi eseguire "pacman-Su pixman", o meglio per aggiornare tutto il sistema con "pacman-Syu"
Xorg molto difficile da installare, perch ci sono un sacco di file di configurazione che dobbiamo fare noi stessi. Non so quale potrebbe
essere mancante.
ls /etc/X11/xorg.conf.d/*
Ci potrebbe anche mancare i pacchetti che sono necessari anche. Ci dovrebbe essere un xorg
e una pagina wiki archlinux che potrebbe aiutare.
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
Return to “Italiano”
