dre1980
color depth
Sun Nov 03, 2013 8:10 pm
What is the highest color depth I can get from the camera board.
I would like to get:
Y = 8-bits
U = 8-bits
V = 8-bits
My current code is getting:
Y = 8-bits
U = 2-bits
V = 2-bits
Re: color depth
Sun Nov 03, 2013 8:35 pm
YUV420.
So 8 bits for Y, but subsampled U and V at 8 bit. (so one 8 bit value defines 4 pixels worth of U and V), so your 2 bits UV is a bit misleading - you've simply divided out the size by the pixels, missing out the subsampling.
dre1980
Re: color depth
Sun Nov 03, 2013 9:40 pm
Thanks I think I now get it.
My understanding is that there is 4 Y pixels that share 1 byte for U and 1 byte for V.
Is there any way to resize one of these frames so that there is 1 byte for Y and 1 byte for U and 1 byte for V.
If so, is there a name for this?
Re: color depth
Mon Nov 04, 2013 9:17 am
dre1980 wrote:Thanks I think I now get it.
Just write some image conversion code that does that - pretty simple. Get the buffer, create a destination buffer, copy from one to the other undo the subsampling. Or you can get RGB out from the camera ISP which is RGB888 IIRC.
wibble82
Re: color depth
Mon Nov 04, 2013 9:52 am
Hi
I'd recommend getting the RGB data out - the YUV420 format can be a little confusing - I found the buffer positions can be oddly aligned for some image sizes. If you want to get back to YUV from RGB there's a fairly simple algorithm to do it. This page goes over them:
http://www.fourcc.org/fccyvrgb.php
What are you using to extract the image?
-Chris
Re: color depth
Mon Nov 04, 2013 10:40 am
The alignment is standard for all YUV (and I think RGB)- widths and plane heights must be divisible by 16, so are padded to those values.
So if your height is not %16=0, there will be padding between the Y plane and the U plane, similar between U and V. If width is %16!=0 then there will be padding bytes at the end of each line to make it %16=0.
This is to improve RAM accesses by the VPU which works best at 16 byte boundaries (it's a 16 way SIMD unit)
sharix
Re: color depth
Mon Nov 04, 2013 12:04 pm
I assume this is directly connected to this bug :)
Re: color depth
Mon Nov 04, 2013 12:22 pm
sharix wrote:I assume this is directly connected to this bug :)
yup.
Return to “Camera board”
