cjan
Re: Tutorial: Compile VLC with HW acceleration - Jessie, RPi
Sat Mar 19, 2016 10:24 am
gkreidl wrote:
cjan wrote:one question,
SDL --vout : software YUV SDL output, so which video codec using?
Selected automatically by VLC.
ok, try vlc --vout sdl 720p.mp4 and it work. which codec?
gkreidl
Sat Mar 19, 2016 10:59 am
Open the message window and watch the messages. You will also see a lot of error messages (lost frames, it's not perfect).
Minimal Kiosk Browser (kweb)
cjan
Sat Mar 19, 2016 11:56 am
gkreidl wrote:Open the message window and watch the messages. You will also see a lot of error messages (lost frames, it's not perfect).
play about 5 min, perform very well no error messages except ' Failed to set on top '.
btw, had build ffmpeg --enable-mmal, was it matter ?
[email protected]:~/Downloads $ LC_ALL=C vlc --vout sdl videoplayback.mp4
VLC media player 2.2.2 Weatherwax (revision 2.2.2-0-g6259d80)
[018fb250] core libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[6f20acc8] core vout display error: Failed to set on top
^Cpi @Rpi2:~/Downloads $
RandyOo
Mon Mar 21, 2016 4:12 pm
I followed the tutorial and got it working, but after enabling the new (beta) OpenGL driver, it no longer worked, until I changed the preferences to use OpenGL as the output, instead of "OpenMAX IL". Now it works nicely using OpenGL acceleration!
In other words, it might not even be necessary to compile VLC as per this tutorial, if you just install VLC from the normal Raspbian package repo, enable the beta OpenGL driver (in raspi-config), and then select OpenGL as video output in VLC. I might give it a try myself, and report back here if it works...
gkreidl
Mon Mar 21, 2016 4:17 pm
RandyOo wrote:I followed the tutorial and got it working, but after enabling the new (beta) OpenGL driver, it no longer worked, until I changed the preferences to use OpenGL as the output, instead of "OpenMAX IL". Now it works nicely using OpenGL acceleration!
OpenGL does NOT accelerate video!
You may get it to work with low resolution video (software decoding), but try a 720p or 1080p video and you will see that it does not work.
nautilus27
Mon Mar 21, 2016 7:20 pm
gkreidl wrote:
nautilus27 wrote: I just tested it and you are correct. Well, you know what gkreidl? Screw these, let's code our own OpenMAX based GUI player and kick ass, WAIT FOR ME!!! I'm gonna make UI look shinier than iTunes!
You seem to have no idea how complex this is. Have a look at the omxplayer source code. And it doesn't even have an UI.
But there do exist at least three GUIs for omxplayer now. Why do you want to want to invent the wheel again?
I don't need a "shiny UI". And iTunes is one of the worst software products I've ever encountered, IMHO.
gkreidl you seem to be having trouble in spotting sarcasm. You work on that, try watching Bill Maher on YouTube.
Yeah there are some OMX player GUIs but honestly they look like 16bit applications from Win95 era with very limited capabilities. Also, what's the use of a GUI if OMX player still launches full screen and no control buttons appearing on the video?
KTWS
Tue Mar 22, 2016 2:37 am
nautilus27 wrote:Yeah there are some OMX player GUIs but honestly they look like 16bit applications from Win95 era with very limited capabilities. Also, what's the use of a GUI if OMX player still launches full screen and no control buttons appearing on the video?
A bit of shameless self promotion here but Ubeify Media Player might be the the kind of OMXplayer GUI you're looking for. It has control buttons, even in full screen, and it doesn't look like it's from the Win95 era, despite being coded using the Tkinter Python toolkit:
Ubeify Desktop Media Player For Raspberry Pi Zero, 1, 2 & 3
http://www.ubeify.co.uk/
gkreidl
Tue Mar 22, 2016 2:56 am
This is complete nonsense. All (3 that I know of) omxplayer GUI programs can play videos inside a a window (or multiple windows) with a set of controls.
BTW, this is getting off topic.
RandyOo
Thu Mar 24, 2016 3:12 pm
I actually did try with numerous HD videos, and it worked nicely on my Pi3, except for one video, which may have been encoded "high profile", with codec features not supported by hardware decoding. Anyway, even if OpenGL doesn't accelerate the decoding, it must relieve enough of the rendering burden to achieve smooth playback on the content I've tested, at least.
And by the way, I just tried using the version from the Raspbian repo, rather than my self-compiled version, and it also works nicely on HD content.
gkreidl
Thu Mar 24, 2016 3:41 pm
I'm not sure what you call HD content.
OpenGL cannot be faster than OpenMax, because decoding and rendering are both done on the GPU. It may be faster when rendering software decoded video though.
RandyOo
Thu Mar 24, 2016 3:46 pm
What I'm calling HD content is 720p and 1080p. (edit: after a bit more testing, it looks like only a few 1080p files play smoothly, but the vast majority of 720p work just fine)
I'm not calling it faster than OpenMax, but it's certainly a lot more convenient, and for me on my Pi3 (and possibly many others), it may be good enough. Unfortunately, with the beta OpenGL driver enabled, OpenMax isn't possible: VLC will crash. Switching back and forth between drivers is a hassle, and I don't have a lot of free time, otherwise I'd do some benchmarks.
gkreidl
Thu Mar 24, 2016 3:57 pm
I've got a lot of 1080i files, mostly recorded TV streams. Using software decoding it's not possible to play any of them (using SDL output, not OpenGL, which blocks about everything I'm running on my RPis).
cjan
Sun Apr 03, 2016 10:27 am
my system mess, can not build any more.
can someone share .deb?
cjan
Tue Apr 05, 2016 9:46 am
cjan wrote:my system mess, can not build any more.
ok, enable VC4 driver and --vout gles2 can play *.avi + *.srt, not mp4 or mkv.
gkreidl
Tue Apr 05, 2016 10:04 am
If you don't set Video to "OpenMax IL" you will only get software decoding. It may work with many SD videos, especially on a RPi3, but not with full HD.
kenerly
Re: Compile VLC with HW acceleration - complete tutorial
Thu Apr 07, 2016 4:03 pm
[quote="cjan" only one problem, no-frame full screen like omxplayer, so can not control or dont know how to control? anyone can help fix this?[/quote]
Some problem for me, any fix?
Everything else is working fine, as far as playing videos.
gkreidl
Thu Apr 07, 2016 5:20 pm
kenerly wrote:
cjan wrote: only one problem, no-frame full screen like omxplayer, so can not control or dont know how to control? anyone can help fix this?
VLC has a rich set of keyboard controls (editable).
cjan
Tue Apr 12, 2016 10:21 am
ok, mess up again
[004e2a58] core libvlc error: No plugins found! Check your VLC installation.
set all links with no luck.
scarf
SMB/Samba support, window
Wed Apr 13, 2016 5:56 pm
I have a few issues i'm trying to resolve:
1.) SMB/Samba support. With the VLC in the repositories, I could just install the SMB plugin so i could open files directly from an SMB share. Trying to figure out how to compile VLC with SMB support. When i followed the guide in the first post, i added the option "--enable-smbclient" to the configure command. While the configure command was running, i saw the output "checking for SMBCLIENT... yes". However, after installing i am unable to open files from the SMB share, VLC saying things like "permission denied" (these were the same errors received when the SMB plugin wasn't installed)
2. Window. When i play a video, the VLC window disappears and so I can't easily use any of the playback controls or access the VLC options. This is what you mean by "overlay"? Isn't there a way to make it fit in the window so it is usable? Also in this mode, for videos that are not the size of my screen, instead of black bars added to the sides (or top/bottom) of the video, i can see the Raspberry Pi desktop and other windows that are in that area
gkreidl
Re: SMB/Samba support, window
Thu Apr 14, 2016 6:09 am
scarf wrote:I have a few issues i'm trying to resolve:
1) I have mounted all samba shares to local directories (for different reasons).
2) Yes, that is the overlay method; and if the video doesn't fit the screen the desktop or parts of the player will shine through.
If you want to have a player that combines the overlay method with true windows, get my omxplayerGUI (or some of the other GUIs for omxplayer).
cjan
Thu Apr 14, 2016 12:49 pm
off topic, maybe?
found this, libav.git openmax Rpi supported.
https://git.libav.org/?p=libav.git
InunoTaishou
Wed Apr 20, 2016 9:57 pm
I followed all the instructions in the first post and vlc is working. OpenMAX IL video output worked and did display video perfectly but it covered up the controls for vlc so I used Simple DirectVideo (I believe that's what it's called). Now, the only thing that's not working is trying to seek/skip forward/backward. The video will not display on the screen, but the audio works.
Anyone else had this issue or know how to resolve it? Or possible use OpenMAX and still be able to see the controls for vlc?
gkreidl
Thu Apr 21, 2016 6:55 am
InunoTaishou wrote:Hello,
SDL output only works for SD video (software codecs). OpenMAX IL overlay hides the controls; thats the way it is. In so far it is not better than omxplayer. But for omxplayer there are GUIs that play video "inside" a window (simulated) so the controls are available.
InunoTaishou
Thu Apr 21, 2016 8:16 pm
Thanks for the reply.
I love vlc so hopefully there comes a day when we have access to the controls and the video can be minimized and restored. If they can do it on android they'll do it on the RPI! At least that's what I like to believe.
I did try the omxplayerGUI and it would do what I want but it doesn't seem that I can hide the controls when I put the video in the full screen state. I'll just stick with vlc and use the key bindings to scroll through the video.
gkreidl
Thu Apr 21, 2016 10:19 pm
InunoTaishou wrote:Thanks for the reply.
Hiding the controls in omxplayerGUI ALT+h and then ALT+f to go to full screen during playback (same keyboard commands again to get back to window mode with controls).
Return to “Raspberry Pi OS”
