Absolutely loving the concept of Raspberry Pi, hoping to get a few for my birthday this November, although sooner would of course be preferable!
My dream application at present (among loads of others including NAT storage etc.) is to embed Raspberry Pis in solar/battery casings with handheld walkie talkies, and to use them as data relays between Nexus Cork in Cork, Tog in Dublin, MilkLabs in Limerick and 091Labs in Galway. An inter-Hackerspace, amateur-owned/operated internet backbone. Slow, but resilient.
My understanding is that the "soundmodem" software allows sound cards to encode digital information over anything that'll carry sound. A set of walkie talkies permitting two-way simultaneous communication, or at least VOX control, and some RPis on mountain-tops should do the job, right?
Setup for a relay, I imagine, would involve two walkie talkies (one for either "end" of the link), a Raspberry Pi, an extra sound card for communicating with both walkie talkies, and the Soundmodem Software.
If you were using radios that could handle real-time two way communication without using a "speak" button and without interrupting reception during transmission, you might be able to do away with having so many dedicated RPis and only use them as uplinks and downlinks, with wire-coupled walkie-talkies as the "dumb relays" on the mountaintops.
Legality: You'd have to ensure that the walkie talkies were European "PMR446" compliant, NOT American ones, and you'd be best off putting them in cantennas so that they're roughly directional at one another to avoid being a nuisance (and to avoid snooping). I'm not sure whether you'd be permitted to use encryption under PMR446, though I think that ridiculous restriction only applies to licensed HAM users.
If it were illegal or for some other reason impractical to use walkie-talkies for legal data transfer over long range, what are the odds of doing the above with precisely coupled lasers/photoresistors and RPi/Soundmodem? It'd be harder to set up but possibly lower power, lower signal noise?
Applications:
> Hosting mirrors of critical information resources in case of censorship or emergency failure.
> Offering free internet access to those who can't afford or access it otherwise.
> Proof-of-principal for countries with more urgent need of cheap communication infrastructure.
> Proof-of-principal DIY-provision of "last mile" internet access.
> Having a nice old natter between Hackerspaces in Ireland.
