Dany4k
Error on instalation
Thu Oct 24, 2013 7:09 pm
Just tried to install raspbian with noobs(lite version). Installation was successful and rebooted. Initial config screen appeared, I press Finish and Pi reboots.
Then upon loading screen only appears ERROR multiple times. Login is successfull but when Typing startx nothing happens.
What can I do to fix this?
FTrevorGowen
Re: Error on instalation
Thu Oct 24, 2013 7:26 pm
What version of NOOBS?
What make, size, type of SDHC card?
Did you use a built-in or external USB stick-like card reader/writer? (Some built-in ones on older laptops/netbooks are not fully SDHC compatible)
How did you format the SDHC card initially?
I suspect SDHC card formatting problems and suggest re-formatting the card using the SDA's tool (as per the quick start guide) and, perhaps, trying NOOBS 1.3.1 which includes a fix for issues with SanDisk Ultra cards and can be found here: http://downloads.raspberrypi.org/NOOBS/test/ and then report back.
Trev.
Dany4k
Thu Oct 24, 2013 7:41 pm
I assume its the latest version because I download it from raspberrypi.org.
SD Card: Transcend SDHC Class6 - 4GB
I used the built in SD card reader on my desktop. Formated with the reccomended tool.
Thanks for the help, gonna try that version. I also bought from amazon an Sandisk 16GB Ultra SD and suspect that link is gonna be usefull later on.
Dany4k
Thu Oct 24, 2013 8:14 pm
Well, just tried the 1.3.1 installation and didnt worked. Installed, rebooted. Then cant login. Not the same error I had before but still cant go to graphical environment? Any sugestion?
Im thinking this is an SD card problem, so I will probably just wait for my Sandisk card arrive and then try again.
FTrevorGowen
Thu Oct 24, 2013 8:50 pm
Dany4k wrote:Well, just tried the 1.3.1 installation and didnt worked. Installed, rebooted. Then cant login. Not the same error I had before but still cant go to graphical environment? Any sugestion?
Well it was worth a try. Your symptoms were/are different to the "Sandisk problem" but it's always worth checking with the most up to date version. Could be just an "iffy" SD card but I've had a "further thought" (triggered by your "can't login" comment) is it possible that your Pi's booting into "safe-mode" (http://elinux.org/RPI_safe_mode)? - the main clue is that you get a "#" prompt rather than a "$" prompt. That does not support the graphical environment!
Trev.
Dany4k
Thu Oct 24, 2013 8:56 pm
I actually had the "$" symbol in there so thats not the problem.
Just booted RiscOs and works really nice, so not an hardware problem.
FTrevorGowen
Thu Oct 24, 2013 9:18 pm
Dany4k wrote:I actually had the "$" symbol in there so thats not the problem.
Glad you've got one OS working at least. I guess just "wait and see" what happens when you try (Raspbian) with another SDHC card.
Trev.
