SnowLeopard
raspivid 2GB size limit
Thu Oct 24, 2013 5:20 pm
I ran into the 2GB file size limit when recording a melting ice cube a couple weeks ago.
I just ran a test with the latest version to confirm that raspivid has a problem recording over 2GB:
[email protected] ~/work $ raspivid -v -n -t 100000000 -b 25000000 -o size-test.h264
raspivid Camera App v1.3.4
Width 1920, Height 1080, filename size-test.h264
bitrate 25000000, framerate 30, time delay 100000000
H264 Profile high
Wait method : Simple capture
Initial state 'record'
Preview No, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera stills port to encoder input port
Opening output file "size-test.h264"
Enabling encoder output port
Starting video capture
mmal: Failed to write buffer data (8191 from 27709)- aborting
mmal: Failed to write buffer data (4096 from 65536)- aborting
mmal: Failed to write buffer data (4096 from 28655)- aborting
Finished capture
Closing down
mmal: Failed to write buffer data (4096 from 43772)- aborting
Close down completed, all components disconnected, disabled and destroyed
[email protected] ~/work $ ls -l size-test.h264
-rw-r--r-- 1 pi pi 2147483647 Oct 24 13:12 size-test.h264
I had tried adding the defines mentioned in an old thread somewhere for large file support, but when compiling I got warnings about already defined.
Re: raspivid 2GB size limit
Thu Oct 24, 2013 6:24 pm
Odd, that was fixed ages ago.
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
SnowLeopard
Fri Oct 25, 2013 12:00 am
-D_FILE_OFFSET_BITS=64 is missing. I tried adding it and the new build wrote 2.6gb in about 20 minutes.
I put the change in the main CMakeLists.txt with the LARGEFILE_SOURCE defines and I did my first git pull request to submit the fix. :)
[email protected] ~/work/userland-bug_fixes $ diff -u CMakeLists.txt.orig CMakeLists.txt
--- CMakeLists.txt.orig 2013-10-24 19:05:23.502029050 -0400
+++ CMakeLists.txt      2013-10-24 19:02:36.525742187 -0400
@@ -41,7 +41,7 @@
 add_definitions(-DUSE_VCHIQ_ARM -DVCHI_BULK_ALIGN=1 -DVCHI_BULK_GRANULARITY=1)
 add_definitions(-DOMX_SKIP64BIT)
 add_definitions(-DEGL_SERVER_DISPMANX)
-add_definitions(-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE)
+add_definitions(-D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64)
 # do we actually need this?
 add_definitions(-D__VIDEOCORE4__)
Fri Oct 25, 2013 8:35 am
Hmm. It is odd, I asked Dom to sort that about 6 months ago and I thought it had been done. Must have lost the settings at some point.
SnowLeopard
Fri Oct 25, 2013 3:58 pm
jamesh wrote:Hmm. It is odd, I asked Dom to sort that about 6 months ago and I thought it had been done. Must have lost the settings at some point.
Uhhh... my pull request was accepted and applied to the "next" branch, and I can see the updated CMakelists.txt, but I'm not sure that branch is of any use. (This branch is 3 commits ahead and 93 commits behind master)
First time I used github and I just followed the instructions that appeared on screen... guess it wasn't the right way.
EDIT: Resubmitted the change and looks like it will go on master branch properly this time.
EDIT-2: Change accepted and shows up on master branch.
dqpi
Sun Nov 10, 2013 2:33 pm
I was trying to record a 10 hour video using raspivid but it stopped at 2 GB. The first and only relevant Google hit lead me to this post. I've been struggling a bit with it but don't know how to use it.
Can you point me in the right direction?
Thanks in advance,
Sun Nov 10, 2013 4:37 pm
You can get the latest course code from the raspberry pi userland github. If that doesnt make any sense you'll need to research it a bit.
This should enable larger files. BUt, you can reduce files size for very long recordings by decreasing the bit rate and/or decreasing resolution.
dqpi
Sun Nov 10, 2013 6:09 pm
great, thanks that worked!
Return to “Camera board”
