pablo808
rpi-update command
Wed Oct 23, 2013 6:18 am
I have some questions regarding the command rpi-update. My understanding is that it updates the firmware of the RPi.
I have a couple of RPi's and for the first 2, I used the provided RPi pre-installed SD cards which contain Raspbian OS. I ran apt-get upgrade, apt-get update and all is good. I then ran rpi-update but got a 'command not found'.
For a 3 RPi downloaded the 2013-09-25-wheezy-raspbian image and write it to an SD card, ran apt-get upgrade, apt-get update and was able to run rpi-update which completed sucessfully.
-What is the different between the pre-install Raspbian OS and the downloadable image?
-Is the rpi-update command 'new' which is why it was included in the latest image?
-How can I run rpi-update on my 2 RPi which current dont have it current installed?
Thanks.
texy
Re: rpi-update command
Wed Oct 23, 2013 6:35 am
earlier releases of raspbian didn't have rpi-update installed by default, later releases did.
If you have a system that does not have rpi-update installed just use the following to install it :
sudo apt-get install rpi-update
Hope this helps,
Texy
ShiftPlusOne
Wed Oct 23, 2013 7:19 am
Don't do it.
rpi-update was a quick hack made back in the day before the kernel and firmware was not properly packaged. apt-get upgrade is enough in 99% of the cases.
pablo808
Wed Oct 23, 2013 11:58 pm
Thanks for all the responses.
I'm confused, so should I or shouldn't I use rpi-update?
If I shouldn't, why is this command included on the later images?
I guess what I am looking for is an 'authorative' answer...
pmc
Thu Oct 24, 2013 12:30 am
As a newbee you haven't read into what was stated above.
You can use either rpi-update, or apt-get upgrade.
Use apt-get update first, followed by apt-get upgrade.
apt-get has other parameters including remove. See the manual for the command parameters etc.
pablo808
Thu Oct 24, 2013 12:57 am
Thank you for that input.
Do does apt-get upgrade upgrade the firmware?
From this post, it looks like there are different: http://raspberrypi.stackexchange.com/qu ... f-raspbian
OK I think I found an answer. Only run rpi-update if you need the latest bleeding edit updates.
ShiftPlusOne
Thu Oct 24, 2013 1:18 pm
pablo808 wrote: Only run rpi-update if you need the latest bleeding edit updates.
That's pretty much it. I would change that to "Only run rpi-update if you know you need a specific build of the firmware or if you were asked to do so by Dom."
Yes, apt-get upgrade WILL update your firmware to the latest stable version, and that MAY conflict with rpi-update. If you see something on the internet that says otherwise, it's probably outdated information.
pablo808
Fri Oct 25, 2013 5:33 am
Thats clear now.
Thanks.
rasppyuser
Sun Jun 22, 2014 12:04 pm
Hi, I have been using rpi-update for some months, but I want to move to the more stable package images (using apt-get).
I have found this comment that lists some packages affected by rpi-update and propose a command to override rpi-update updates with apt-get ones: https://github.com/raspberrypi/linux/is ... t-46278157
Is the comment right, or are there more packages affected, or do I need to do more things to go back to apt-get version?
Thanks!
AndrewS
Tue Jun 24, 2014 7:01 pm
rasppyuser wrote:Hi, I have been using rpi-update for some months, but I want to move to the more stable package images (using apt-get).
Thanks!
Yup, that's right, @asb is the maintainer of the Raspberry Pi build of Raspbian 8-)
