I am only measuring about 3.5V across TP1 and TP2 on my RPi model A rev2. The voltage between TP2 and the polyfuse side towards the board edge is 3.75V. The voltage between TP2 and polyfuse side towards board inside is 3.5V. The polyfuse appears to be bad since the difference is > .1. However, why is the overall voltage only 3.5V? Shouldn't it be close to 5V? I tested with 2 different PSUs and mini USB cables which have been tested on a working RPi.
Thanks,
Vu
