xtr4nge
FruityWifi (wireless network auditing tool)
Sat Oct 19, 2013 7:31 pm
Hi All,
FruityWifi is a wireless network auditing tool based in the wifi Pineapple. The application can be installed in any Debian based system adding the extra packages. Tested in Debian, Kali Linux, Kali Linux ARM (Raspberry Pi), Raspbian (Raspberry Pi).
Repository: https://github.com/xtr4nge/FruityWifi
Install: https://github.com/xtr4nge/FruityWifi/wiki/Install
Manual: https://github.com/xtr4nge/FruityWifi/wiki/Manual
Note: Minor fix for FruityWifi-1.0-SD-Raspbian.tar.gz
Edit /etc/network/interfaces and add the following line:
allow-hotplug eth0
comment or delete the following lines:
# allow-hotplug wlan0
# iface wlan0 inet manual
# wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
# iface default inet dhcp
exec: apt-get remove ifplugd
exec: update-rc.d -f squid3 remove
Thanks!
Twitter: @xtr4nge | @FruityWifi
Web: http://www.fruitywifi.com
GitHub: https://github.com/xtr4nge/FruityWifi/
xtr4nge
Re: FruityWifi (wireless network auditing tool)
Thu Jan 16, 2014 9:01 am
Controlling the FruityWifi with a Raspberry Pi, PHP, Python, 16x2 lcd + keypad.
http://www.youtube.com/watch?v=FkQw-_Wlpa0
txt3rob
Thu Jan 16, 2014 4:33 pm
you have my full attention here.
can you confirm if i install the image on to the SD card i will get on boot up the same as the youtube video?
The Raspberry Pi Hell Guy - Random Ramblings to assist me and others.
http://raspberrypihell.blogspot.com
My Github - http:/www.github.com/random-robbie/
http://www.smspi.co.uk - send free uk sms via your raspberry pi from here
xtr4nge
Mon Jan 20, 2014 10:09 am
txt3rob wrote:you have my full attention here.
Hi txt3rob,
I will release the python client to use the lcd + keypad soon.
The actual client is the web interface on the left side of the video.
In the video I show how to control the FruityWifi using the lcd + keypad.
I added the web interface on the left side to show the changed status off the services and modules in FruityWifi.
Follow the project on Twitter for updates @FruityWifi =)
regards,
xtr4nge
txt3rob
Mon Jan 20, 2014 1:03 pm
brilliant i am going to wait for the lcd part as i would love to use my lcd properly
xtr4nge
Tue Jan 28, 2014 11:18 am
txt3rob wrote:brilliant i am going to wait for the lcd part as i would love to use my lcd properly
No prob, I will let you know ;)
regards,
xtr4nge
klausneil
Mon Aug 11, 2014 5:58 pm
Hi, please anybody can help me? i try configure the captive portal in this but i can't, help me.
FruityRocks
Tue Aug 12, 2014 12:31 am
I too am having difficulty. Specifically, I can't get the wireless to start when I click "start"
ScreenShot
Above is a screenshot of my dashboard. eth0 is a standard Ethernet connection to the internet, wlan0 is a TL-WN725N USB/wifi dongle.
I had to install some drivers to get the wifi dongle to work, could that be the issue? I've modified my /etc/network/interfaces to match yours, but still have no luck.
Any help would be great, thanks,
-B
wilsonb
Sat Oct 18, 2014 5:46 am
Howdy...
Would love to get FruityWifi installed and working.
Running latest Kali on Raspberry and trying to get FruityWifi 2.0 installed and working.
It seems it installs but has problems when it gets to the webserver part and starting services.
When done , can not go to webserver in browser because service is not running.
Let me know what log files to post. (maybe a install log file?)
klausneil
Wed Jan 21, 2015 5:23 pm
Hi, anybody know how make the fritywifi as captive portal? some link?
xtr4nge
Sat Apr 11, 2015 7:38 pm
FruityRocks wrote:I too am having difficulty. Specifically, I can't get the wireless to start when I click "start"
-B
Hi FruityRocks, please update to the latest version. FruityWifi has different [AP] modes (Hostapd and Airmon-ng). Realtek chipsets are not supported by Hostapd, so you need to use Airmon-ng mode. Please note that if you use Airmon-ng mode, you will lose some functionalities like Karma and/or Mana.
If you have any problem with the setup, please open an issue on FrutiyWifi GitHub.
regards,
xtr4nge
Sat Apr 11, 2015 7:40 pm
wilsonb wrote:Howdy...
Hi wilsonb,
What is the problem? you can open an issue on FruityWifi GitHub.
regards,
xtr4nge
Sat Apr 11, 2015 7:42 pm
klausneil wrote:Hi, anybody know how make the fritywifi as captive portal? some link?
Hi klausneil,
You can modify FrutiyWifi Captive Portal module to get all the functionalities that you are looking for.
regards,
