bill_br
How to connect a 4.3 Touch TFT LCD
Tue Oct 15, 2013 11:43 pm
Hello everyone,
I have bought a 4.3 LCD touch from WaveShare - http://www.wvshare.com/product/4.3inch- ... -LCD-B.htm - but I am finding really hard to figure out how to connect it to my RPi. The LCD interface is 24-bit parallel. It seems it doesn's have a LCD controller built in.Does anyone could help me to find a way to connect it to my RPi, if it is possible? I have also bought the DVK511 expansion board.
Thank you
slapi
Re: How to connect a 4.3 Touch TFT LCD
Fri Oct 25, 2013 8:52 am
Same situation here.
Helping hands can get more details about the panel from the manufactures docs : http://wvshare.com/downloads/accBoard/4 ... h-LCD-B.7z. (Sorry, can't attach directly due to size limits..)
While searching for a solution i stumbled upon this cheap and simple yet flexible HDMI to parallel 3.3v interface: http://www.harbaum.org/till/dvi2par/index.shtml. As i have only noob hardware knowledge, it would be great if someone could take a look at it and check if this circuit could be used / adapted.
Thanks a lot!
klricks
Fri Oct 25, 2013 12:55 pm
bill_br wrote:Hello everyone,
Thank you
You will need an HDMI to parallel interface board - something like this:
http://www.chalk-elec.com/?page_id=1283 ... d=14647633
I have not used this ..... just 1st Google hit. The YouTube video looks good.
Note that the DVK511 is not suitable for your 24 bit display.
klricks
Fri Oct 25, 2013 1:22 pm
slapi wrote:Same situation here.
Thanks a lot!
The converter looks to be a complete DIY project. You would need to source all the parts yourself and solder them.
They did not say where to obtain the PC board? Not a project for a beginner. I have soldered many SMT components but would not be able solder the main chip without an expensive microscope.
I did not see your first link as it is a zip file. Is there a pdf link?
slapi
Sun Oct 27, 2013 9:46 am
Thanks for jumping in, klricks
That's the challenging fun stuff :lol:
Most parts are easily to find. For the TFP401A - PanelBus DVI Receiver i ordererd some free samples from http://focus.ti.com/docs/prod/folders/p ... p401a.html. I plant to mount them on some TQFP 32 48 64 80 100 to DIP convertors from ebay (at least for the prototyping). For the soldering stuff i have a fine magnifier lamp here. But I think it's a good idea to exercise TQFP soldering first on wasted pcbs.
Well, the schematic is there. I'm thinking of rebuilding it for single layer THT pcb (thus the converter).
The ZIP-Archive contains various PDF-Docs and programming samples (for whatever environment / hardware)
bill_br
Thu Oct 31, 2013 1:18 pm
Hi guys,
Thanks for your help. After a long search I found this: http://harbaum.org/till/dvi2par/index.shtml . Do you think this board would work in my case?
Thanks!
slapi
Thu Oct 31, 2013 6:49 pm
lol, that's the same link as i already posted. I think this converter works, but it is a little bit tricky to build.. (See discussion above.)
Onira
Tue Feb 04, 2014 6:30 am
I do have DVK511 as you do
but the display I bought is 2,2" LCD with touch panel
and I'm also having troubles to make it working :(
Cogito ergo sum
lsantossouza
Fri Feb 21, 2014 4:02 am
Me too. I received only a manual with instructions to make the tests. I don'tknow how I can use the 2.2 lcd display
Onira
Tue Mar 03, 2015 2:29 pm
Can anyone help?
Cogito ergo sum
