jbeale
espeak speech synthesizer warning messages
Tue Oct 15, 2013 5:24 pm
I installed the 'espeak' text-to-speech synthesizer which works to generate (mostly) recognizable speech. But each time I try it I get a long list of warning messages from ALSA lib and others, even though it does work. Is this normal, or do I have some mis-configuration?
[email protected]:~/sksense$ espeak --version
eSpeak text-to-speech: 1.46.02  06.Jan.12  Data at: /usr/lib/arm-linux-gnueabihf/espeak-data
[email protected]:~/sksense$ espeak "hello"
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
M5
Re: espeak speech synthesizer warning messages
Fri Nov 15, 2013 3:10 pm
I have the same problem. I have been searching for an answer but I can’t find anything yet.
Is this normal or am I missing something?
Can anyone suggest anywhere to look to find an answer?
This is the error I get
[email protected] ~ $ espeak "Hello."
Douglas6
Fri Nov 15, 2013 4:57 pm
This is a bit of a shot in the dark, since my Pi is not available, but I solved a similar(?) problem by editing /usr/share/alsa/alsa.conf and changing the following line (comment-out the first, add the second):
#pcm.front cards.pcm.front
pcm.front cards.pcm.default
Possibly followed by
sudo alsa reload
Gotta admit though, I don't (and probably never will) "get" ALSA
Fri Nov 15, 2013 8:45 pm
Douglas6 wrote:This is a bit of a shot in the dark, since my Pi is not available, but I solved a similar(?) problem by editing /usr/share/alsa/alsa.conf and changing the following line (comment-out the first, add the second):
I've had that in my alsa.conf for months and it doesn't make any difference to the stupid and meaningless stream of messages.
The easiest way to suppress that collection of meaningless stuff is 'espeak "Hello" 2>/dev/null'
Or forget espeak and try this (which needs an Internet connection to work)
#!/bin/bash
say() { local IFS=+;/usr/bin/mplayer -ao alsa -really-quiet -noconsolecontrols "http://translate.google.com/translate_tts?tl=en&q=$*"; }
say $*
This is a doctor free zone.
Douglas6
Sat Nov 16, 2013 1:06 am
DougieLawson wrote: I've had that in my alsa.conf for months and it doesn't make any difference to the stupid and meaningless stream of messages.
Well, it does decrease it by one :)
M5
Wed Nov 27, 2013 12:42 pm
Thanks for the feedback.
I’ve been looking through different forums, but can’t find an answer.
I am having a go at building an RPi robot like the one in issue 132 of Linux User.
So I think I’ll stay with eSpeak as it won’t always have a network connection, and use the “2>/dev/null”.
Thanks again
