Hallz
Ethernet to VGA
Fri Oct 11, 2013 8:42 am
Hey, I was wondering if any one had a clue as to if you could use a ethernet to vga cable to send video to a monitor [that only has vga input]. I won't have access to my pi for a couple of days, so I figured I would ask on here. I attached a picture of the cable. Thanks for your time!
Ethernet to VGA
photo (1).JPG (31.16 KiB) Viewed 2127 times
mahjongg
Re: Ethernet to VGA
Fri Oct 11, 2013 9:30 am
It wont work, the PI has no hardware to generate VGA output, so no simple cable will ever work.
By the way, this probably isn't a "ethernet to VGA cable", no such things exists, at least no such cable exists (if there is a complete computer system in the middle that converts ethernet signals to VGA that's a different thing).
Also this isn't a VGA connector at all, a VGA connector has three rows of pins, a total of 15, this one has nine pins, so its probably just an RS232 cable ending in a specific RJ-45 connector, which is used for other things than ethernet too.
ghans
Re: Ethernet to VGA
Fri Oct 11, 2013 9:33 am
That won't work.
Also recent VGA cables have three pin rows , so this might not be VGA at all.
ghans
hippy
Re: Ethernet to VGA
Fri Oct 11, 2013 12:19 pm
Seems to be a Cisco console cable ... http://itknowledgeexchange.techtarget.c ... sole-cable
gmc
Re: Ethernet to VGA
Fri Oct 11, 2013 12:22 pm
Yip - its console cable.
VGA has 3 rows of pins.
wikusvandemerwe
Re: Ethernet to VGA
Mon Oct 14, 2013 6:21 pm
Definately a cisco console lead.
...It's been a long time since "lol" really meant just that. :lol:
...we try to engage with the prawn, on behalf of MNU, and on behalf of Humans.
HarveyC
Re: Ethernet to VGA
Wed Oct 16, 2013 12:37 pm
This cable will also work with some modems as it is a 9-pin female to Ethernet adapter. Also I know that at Maplin they sell 9-pin female to 9-pin male cables(http://www.maplin.co.uk/nikkai-pure-connectivity-serial-null-modem-9-pin-female-to-9-pin-female-3m-97740). ;)
blackbox
Re: Ethernet to VGA
Wed Mar 05, 2014 6:56 pm
As other have pointed out the cable you have is an de9 to rj45 nullmodem cable.
What you need is an HDMI to VGA converter.
http://www.ebay.com/itm/New-HDMI-Male-t ... 46180758d0
