billb
Re: Rassberry Pi and Jack audio
Tue Nov 06, 2012 10:33 pm
I was just using default settings and getting the memory allocation error. I haven't tried the method you've posted above, but it was getting rather late and I wasn't sure if that was exactly what I needed. If you think this might all work I'll give it another try and make note of the details. Everything seems to be in place (qjackctl installed, guitarix installed) except I couldn't get jack going properly.
jannis
Wed Nov 07, 2012 9:12 am
If you mean the error with "mmap" in the output: This is due to the RPi's ALSA-driver and can be worked around using the method I described earlier.
Erwin
Wed Nov 07, 2012 9:39 am
If you install jack from the raspbian repositories it will not work. The only way I can get jack and qjackctl to work is by compiling it manually. Then it works without problems with a external usb audio card.
I tested this with a Creative Extigy and could playback without problems.
Due to a usb bug on the PI record still has some plops but this is not related to jack.
jannis
Wed Nov 07, 2012 10:02 am
Ah right, forgot about the USB-"sound card" thing. O
Assuming you want to have sound input via your "USB sound card" and sound output via the RPi's analog audio jack:
Configure jack to use your USB sound card as primary backend (via ALSA). Then use alsa_out as I posted earlier to get the sound to the RPi's analog output. jack can only use one soundcard as primary device so you really need to use alsa_out here, no matter what errors you get when running jack in default configuration.
TonyRogers
Wed Nov 28, 2012 10:13 am
There's a binary that works for me (version 1.9.8). Well it doesn't crash. I'm still setting it up. http://sam.aaron.name/2012/11/02/superc ... on-pi.html
bwims
Wed Nov 28, 2012 3:11 pm
as you seem to have done this, could you give me, as a Debian noob, the command line for getting the extigy drivers?
Thanks!
Brian Williams
Erwin
Wed Nov 28, 2012 7:25 pm
I did not install any additional drivers for the Extigy.
It can be used with the generic usb audio driver.
I also bought a 10 euro usb audio card wich seems to be working better then the Extigy.
It's a usb audio card with a CM6206 chip.
Erwin
moony
Thu Dec 27, 2012 7:34 pm
I tried TonyRogers binary but get:
pi@raspberrypi ~ $ jackd -d dummy
jackdmp 1.9.8
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2011 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
Bus-Zugriffsfehler
same bus error. With "-d alsa" it tells me, there was no such driver.
As superuser (sudo -s), I get:
root@raspberrypi:/home/pi# jackd -d dummy
jackdmp 1.9.8
Cannot lock down 82246176 byte memory area (Cannot allocate memory)
Bus-Zugriffsfehler
Are there more files, that need to be updated? Any others succeed with that 1.9.8 jackd binary?
moony
Sat Dec 29, 2012 2:53 pm
what makes probably a difference: I've got a realtime patched kernel, compiled by my self. Is there a special kernel feature jackd needs?
Erwin
Sat Dec 29, 2012 7:44 pm
I compile Jack from source, this is the only way I can get it to work.
AutoStatic
Tue Jan 01, 2013 10:39 pm
To get Jack2 working on your Rpi with an external USB audio interface:
wget http://jack-audio.10948.n7.nabble.com/attachment/15962/0/jack2_armel.diff
apt-get source jackd2
cd jackd2-1.9.8~dfsg.4+20120529git007cdc37
patch -p1 -i ../jack2_armel.diff
dpkg-source --commit
dpkg-buildpackage -rfakeroot -uc -b
cd ..
sudo dpkg -i libjack-jackd2-0_1.9.8~dfsg.4+20120529git007cdc37-5_armhf.deb jackd2_1.9.8~dfsg.4+20120529git007cdc37-5_armhf.deb
Now add the following lines to /etc/dbus-1/system.conf:
  <policy user="pi">
       <allow own="org.freedesktop.ReserveDevice1.Audio0"/>
       <allow own="org.freedesktop.ReserveDevice1.Audio1"/>
  </policy>
And restart dbus:
sudo service dbus restart
Then remount /dev/shm:
sudo mount -o remount,size=128M /dev/shm
And if you're on a headless RPi:
export DBUS_SESSION_BUS_ADDRESS=unix:path=/run/dbus/system_bus_socket
Now you can fire up JACK but not in full-duplex, only capture or playback, so use -C or -P. This is probably because the ethernet adapter is also on the same usb bus. Maybe disabling it allows JACK to run in duplex mode, haven't tried it yet.
Jeremy
RPi and real-time, low-latency audio: http://wiki.linuxaudio.org/wiki/raspberrypi
RPi audio repository: http://rpi.autostatic.com/
RPi and audio blog: https://autostatic.com/tag/raspberrypi/
AutoStatic
Wed Jan 02, 2013 11:01 pm
I now see this has been posted before with a similar patch: http://www.raspberrypi.org/phpBB3/viewt ... 38&t=26019
It also explains a bit why things are going wrong. Also more info on a recent thread on the JACK mailinglist: http://jack-audio.10948.n7.nabble.com/J ... 15962.html
moony
Thu Jan 17, 2013 8:32 pm
I tried to apply the patch, for that git commit, but it failed with "Hunk #1 FAILED at 33.". Does anyone have a working binary of jackd for me I could try?
AutoStatic
Sun Jan 20, 2013 8:26 pm
moony wrote:I tried to apply the patch, for that git commit, but it failed with "Hunk #1 FAILED at 33.".
Which git commit? And how did you apply the patch?
moony wrote:Does anyone have a working binary of jackd for me I could try?
http://downloads.autostatic.com/rpi/jackd2
theoB610
Thu Jan 31, 2013 5:37 pm
How do you get the 1.9.8 version from another source?
Apparently /usr/portage does not exist.
AutoStatic
Thu Jan 31, 2013 9:12 pm
moony wrote:what makes probably a difference: I've got a realtime patched kernel, compiled by my self.
I'm trying to build one myself but can't get it to boot. Care to share your .config? Thanks in advance :)
Jeremy
AutoStatic
Thu Jan 31, 2013 9:14 pm
theoB610 wrote:How do you get the 1.9.8 version from another source?
It should also work with a newer version of JACK, the patch is quite easy to adapt to a newer version. I wouldn't be surprised if the current would apply cleanly to a newer version.
theoB610
Fri Feb 01, 2013 10:36 am
Cool. And how do you apply the patch?
AutoStatic
Fri Feb 01, 2013 11:05 am
cd /jackd2-source-dir
theoB610
Fri Feb 01, 2013 5:13 pm
Autostatic:
pi@raspberrypi ~ $ cd /jackd2-source-dir
bash: cd: /jackd2-source-dir: No such file or directory
pi@raspberrypi ~ $ patch -p1 -i ../jack2_armel.diff
patch: **** Can't open patch file ../jack2_armel.diff : No such file or directory
What's happening? This is on jackdmp 1.9.9
When I try to run jannis' fix it stops after
JACK server starting in non-realtime mode
EDIT:
Just ran with -v (verbose), and it froze after
Jack: JackDriver::ClientNotify ref = 1 driver = freewheel name = freewheel notify = 18
Jack: JackSocketServerChannel::Execute : fPollTable i = 1 fd = 5
with the second line of this repeating over until I get bored and kill it with Ctrl-C.
Any way of getting round this?
AutoStatic
Fri Feb 01, 2013 7:05 pm
theoB610 wrote:Autostatic:
Where did you download and untar the source of JACK 1.9.9? Or did you get it from git? You have to cd into the source directory and then apply the patch that has to be one directory higher. You could also put the patch inside the JACK source directory but then you have to run:
patch -p1 -i jack2_armel.diff
I'd also advide to dry run the patch first to check if it applies cleanly:
patch --dry-run -p1 -i /path/to/your/jack2_armel.diff
theoB610 wrote:When I try to run jannis' fix it stops after
EDIT:
The line repeating means JACK is running. Or does it really freeze? Can you connect anything to JACK?
theoB610
Fri Feb 01, 2013 7:52 pm
Ok I totally got the wrong end of the stick with that :lol: :oops:
Does running jannis' command give a gui?
AutoStatic
Fri Feb 01, 2013 8:04 pm
theoB610 wrote:Does running jannis' command give a gui?
No, alsa_in and alsa_out are CLI utilities. Same goes for the JACK daemon, that doesn't have a GUI either. Well, it has some GUI frontends (QjackCtl, Patchage) but those are not officially part of the JACK project.
theoB610
Fri Feb 01, 2013 10:26 pm
In that case it was probably working. Oops.
So how do I connect my stuff etc? Do I have to go back to Qjackctl?
moony
Sun Feb 03, 2013 1:01 am
@AutoStatic: jack2 git commit:95a1162d6aecc91882e4d8b01ba7fb12f6d29d1c
with the binary packages, you've posted, I get also errors.
As normal user: "jackd -r -d dummy" or "jackd -r -d alsa" I get "bus error".
Same commands with sudo: "Cannot lock down 82278944 byte memory area (Cannot allocate memory)" for both.
