Sentinelace
Advanced images? What's different?
Tue Oct 08, 2013 4:46 am
I'm a pretty heavy Linux user and am just curious what the difference is with the advanced image. I assume the noobs has a gui? and maybe the advanced is CLI?
Oakham
Re: Advanced images? What's different?
Tue Oct 08, 2013 5:31 am
There is only one official Raspbian Wheezy image, the latest release 25/09/2013.
Noobs is just any easy way to install & run mutiple Distro's, as explained here:
http://www.raspberrypi.org/archives/4100
Searching is easy, most questions have been asked before !
ghans
Tue Oct 08, 2013 8:55 am
Are you talking about the raw images ?
Those do not contain NOOBS and need a special tool to
be written to the SD card ( at least on Windows).
You can't switch between OS' if you use raw images , and you
won't have a recovery option like the one provided by NOOBS.
The provided raw images only contain a single OS.
ghans
Sentinelace
Tue Oct 08, 2013 12:28 pm
What is the purpose of multiple is options ?
klricks
Tue Oct 08, 2013 1:29 pm
The NOOBS setup allows the user to try different OS from a single SD card without having to download and re-image the SD card. Once an image is installed from NOOBS, it is no different than the raw 'advanced' image.
Return to “Raspbian”
