Forzaferrarileo
Rotate rpi camera
Fri Oct 04, 2013 12:46 pm
Hi , I need to rotate the camera module , but the flat doesn't like it :D
there's a way to use normal cable with the camera board?
Re: Rotate rpi camera
Fri Oct 04, 2013 1:31 pm
Can you user -hf or -vf
XAPBob
Fri Oct 04, 2013 1:58 pm
or -rot
gordon77
Fri Oct 04, 2013 2:20 pm
Can't you rotate the RPi with it ? ;)
mad-hatter
Fri Oct 04, 2013 8:59 pm
You can rotate and flip the image when you take the picture,
so it won't matter which way the camera is orientated.
The following command will take a 5 second preview with the picture
rotated 270 degrees and flipped both horizontally and vertically.
raspistill -t 5000 -p 10,10,800,600 -rot 270 -hf -vf -v
Regards
PiGraham
Fri Oct 04, 2013 9:05 pm
Forzaferrarileo wrote:Hi , I need to rotate the camera module , but the flat doesn't like it :D
Coil the flat cable so it will twist.
Yes you can get adaptor boats to connect the camera with twisted pair cable. I have some. If I remember tomorrow I'll post a link to where I bought them.
How are you rotating the camera? Pan side to side? Tilt up and down?
Forzaferrarileo
Fri Oct 04, 2013 10:26 pm
First I need to rotate side to side ( tank turret :P )
Return to “Camera board”
