MarcusG
Looking for Splash screen to cover initial boot text
Wed Oct 02, 2013 4:53 pm
I have looked through the forums here and elsewhere, trying to find a solution that can show a simple image as a splash screen while the system is booting. I would want it just to show an image starting right after the Raspberry color screen test, and ending when Raspbian boots.
I have read about "splashy" but was unable to make it work.
I have also read about fbi, but it doesn't splash until after the text has scrolled for quite a while.
Has anyone set this up successfully?
joan
Re: Looking for Splash screen to cover initial boot text
Wed Oct 02, 2013 5:15 pm
MarcusG wrote:I have looked through the forums here and elsewhere, trying to find a solution that can show a simple image as a splash screen while the system is booting. I would want it just to show an image starting right after the Raspberry color screen test, and ending when Raspbian boots.
Well the surest way of seeing if it's possible is to emphatically point out that you can't do what you want (short of creating a custom kernel).
AndrewS
Wed Oct 02, 2013 11:24 pm
joan wrote:Well the surest way of seeing if it's possible is to emphatically point out that you can't do what you want (short of creating a custom kernel).
I've not looked into the details, but OpenELEC and RaspBMC seem to manage it okay ;)
Return to “Raspberry Pi OS”
