MrPippoTN
Adding date time stamp to a jpg picture
Wed Oct 02, 2013 6:32 am
Hello.
I'm a complete beginner and I'm trying to convert my Raspberry Pi in a weather cam. I'm not interested in streaming, I'm using a camera module and some raspistill commands in order to take a picture of a landscape every 5 minutes. Then I send the picture to my website using ftp. Everything is going fine but now I need help to add a couple of informations like my website and date time stamp to a jpg picture shot.
Here's an example of what I'd like to obtain:
At the moment I use this bash script:
#!/bin/bash
TMP='/tmp'
OUTPUT_FILE='webcam.jpg'
OPTIONS='-w 800 -h 600 -q 80'
cd $TMP
raspistill -o $OUTPUT_FILE $OPTIONS
/usr/local/bin/send-ftp $OUTPUT_FILE
How can I modify it? The goal is adding to the jpeg image a colored band with my website url on the left and date and hour of the shot on the right? Any suggestion?
MrPippoTN
Re: Adding date time stamp to a jpg picture
Wed Oct 02, 2013 11:06 am
I'm sorry, as I told you, I'm a beginner and I can't make it work. Could you show me how to change my file and where to put that code, please?
Wed Oct 02, 2013 12:04 pm
Update your program running raspistill to have the -exif flag.
Install ImageMagick with
sudo apt-get install imagemagick
Try this shell script:
#!/bin/bash
for file in *.jpg ; do
   convert "$file" -font arial.ttf \
      -pointsize 72 -fill white -annotate +100+100  \
      %[exif:DateTimeOriginal] "new-${file}"
done
That reads the EXIF data in filename.jpg and writes a new new-filename.jpg (in the same directory) with the date/time as an additional visible layer.
MrPippoTN
Thu Oct 03, 2013 3:24 pm
DougieLawson wrote:Update your program running raspistill to have the -exif flag.
#!/bin/bash
done
Thank you, I'll try it tonight. Meanwhile, I've another question: and if my picture has no exif informations?
Thu Oct 03, 2013 3:25 pm
#!/bin/bash
done
The date and time should be in there if the pictures were taken with a recent RaspiStill..
Working in the Application's Team.
MrPippoTN
Fri Oct 04, 2013 6:38 am
It works, thank you. Now I can see the date in this format:
yyyy:mm:dd hh:mm:ss
Is it possible to change this? I'd like to get:
dd/mm/yyyy hh:mm
Another little question. Now I put the datestamp in the lower right corner but it is white, so it's difficult to read. Can I put a layer with a black horizontal band at the bottom of the picture?
Thank you in advance.
confuseling
Fri Oct 04, 2013 5:51 pm
date "+%d/%m/%Y %H:%M"
would work, as long as you process the image immediately after you take it.
$ man date
for more details. You could reformat the date from the EXIF data using Sed / Awk or something. But that's beyond my poor brain.
You could just draw a black box in Gimp / Inkscape or something, and use Imagemagick to compose the final image using that as a layer.
http://www.imagemagick.org/discourse-se ... =1&t=20251
Or add a border?
http://www.imagemagick.org/Usage/crop/
http://forums.debian.net
MrPippoTN
Sat Oct 05, 2013 7:08 am
I think I've done it. I used Imagemagick to compose the final image (webcam.jpg) using a layer (striscia.png)
Thank you very much!!!
These are my two files:
shot:
#!/bin/sh
OPTIONS='-w 800 -h 600 -q 80 -x'
DATE=$(date +"%d/%m/%Y")
HOUR=$(date +"%R")
cd /tmp
raspistill -o image.jpg $OPTIONS
convert pre_webcam.jpg -font Arial \
   -pointsize 14 -fill white -annotate +670+590  \
   $DATE \
   -pointsize 14 -fill white -annotate +750+590  \
   $HOUR \
   -pointsize 14 -draw "gravity southwest \
   fill white text 15,6 'Trento, 200 m s.l.m. - Raspberry Pi Cam by GeekSolution.it' " \
/usr/local/bin/send-ftp webcam.jpg
done
send-ftp:
#!/bin/sh
TMP='/tmp'
HOST="ftp.mywebsite.it"
# This is the FTP user that has access to the server.
USER='myusername'
# This is the password for the FTP user.
PASSWD='mypassword'
# It is the first argument passed to the script.
FILE="$1"
cd $TMP
ftp -n $HOST <<END_SCRIPT
quote USER $USER
quote PASS $PASSWD
cd mywebsite/folder/
put $FILE
quit
END_SCRIPT
exit 0
Aurion45
Tue Mar 04, 2014 5:25 am
MrPippoTN,
I would like to do this same as you've done below, can you please help.
Explain in greater detail, what I need to do and how?
How do you execute both Bash files? is it run in automatic mode on start of Rpi?
Explain your whole setup, please.
Andrew
MrPippoTN
Tue Mar 04, 2014 9:27 am
As I wrote at the beginning of the topic, I'm a complete beginner. I don't know anything in coding, I got some good advices that you can read here and then I studied imagemagick. Everything I did, I wrote it here.
There are links and code to copy. Please just try and eventually let me know.
Regards.
Aurion45
Tue Mar 04, 2014 9:33 am
Hi MRPippiTN,
Do I make two bash. files called one "shot.sh" the other "send-ftp.sh"
Then what I do? How to start them?
As I'm a beginner too!!!
MrPippoTN
Tue Mar 04, 2014 9:39 am
I've to confess that I don't remember. As you can see I wrote this topic last october, then I just quit this project.
Try to use Google or ask somebody else, I'm sorry.
Aurion45
Tue Mar 04, 2014 9:44 am
OK, No problem.
I'm reading about "Bash" right this minute!!
winkleink
Tue Mar 04, 2014 10:34 am
An alternative method using Python from Alex Eames
http://raspi.tv/2014/overlaying-text-an ... app-series
Twitter:Winkleink
Google+: Winkleink
Aurion45
Tue Mar 04, 2014 11:11 pm
Winklelink,
Don't understand, how to use, I'm only a beginner!!!
Trying to run the below script's got no idea what to do?
MrPippoTN,
Where did you get this from: unable to open image `striscia.png'
apocalipsis1234
Thu Jun 05, 2014 1:32 pm
Thank you... your code and project is what i was looking for somet time ago...
