Good day;
I've been working with the Adafruit 16x2 LCD plate for the Pi for a few weeks now and just can't get the scrolling effect to work. This is my first Python project so have been learning along the way and been reusing code and tips I find on the forums to do what I need.
So my problem is that a portion of my script contains this:
#dependancies
from Adafruit_I2C import Adafruit_I2C
from Adafruit_MCP230xx import Adafruit_MCP230XX
from Adafruit_CharLCDPlate import Adafruit_CharLCDPlate
from datetime import datetime
from subprocess import *
from time import sleep, strftime
from Queue import Queue
from threading import Thread
... and then part of the main() function contains the following;
if(press == UP):
os.system("mpc volume +2")
playstation=run_cmd("mpc | head -n 1")
volumestat=run_cmd("mpc volume")
LCD_QUEUE.put(playstation+"\n"+volumestat, True)
sleep(0.25)
LCD.clear()
LCD_QUEUE.put(playstation+"\n ", True)
What I want to do is scroll the string in playstation (mpc | head -n 1 will put the current song into playstation then display on the LCD screen) So what's the proper way to scroll playstation?
Now, the file you download from git named Adafruit_CharLCDPlate.py has the following function in it;
def scrollDisplayLeft(self):
""" These commands scroll the display without changing the RAM """
self.displayshift = self.LCD_DISPLAYMOVE | self.LCD_MOVELEFT
self.write(self.LCD_CURSORSHIFT | self.displayshift)
So my quesion is how do i use scrollDisplayLeft from Adafruit_CharLCDPlate.py into my py script and use it?
My script work without errors until i add scrollDisplayLeft or variations of it. And how can i use scrollDisplayLeft in my script to scroll the the song playing with mpc when I use mpc | head -n 1
Cheers,
Re: Adafruit 16x2 LCD Scrolling effect with Python?
Ok, so i've made some progress,
After the LCD.OUTPUT I now add the command lcd.scrollDisplayLeft() but it only scrolls the text by one character and moves onto the next command/function.
Looks like I need to create a for or a while or similar loop to scroll the entire text.
It's a slow work in progress.
So i got it to work;
Here's the proof of concept as I will now have to clean it up and put it in my main program;
astring = run_cmd("mpc | head -n 1")
setscroll=len(astring)
lcd.message(astring)
scrollside(setscroll)
and then later;
def scrollside(setscroll):
for i in range (setscroll):
sleep(0.4)
The LCD does not scroll very smoothly so I'll tinker with it if it's a command issue or hardware issue. Otherwise I'm glad I fixed my own issue.
Sometimes you just need to talk about your problems.
and then later;
sleep(0.4)
Any chance you got this working I am new with programming an trying to figure out the scrolling text but really am lost on it.
Would it be possible to see your whole code so that i can attempt to understand whats going on?
You might find these instructions on my website useful, I show you how to get scrolling working on an LCD like Adafruits. My code very simply writes to the LCD each time, so I think the Adafruit code is more sophisticated, however this might help you to understand what is going on. Have a look at the two .py files!
http://andypi.co.uk/?p=284
Cheers
Andy
Cheers
Andy
Below is the full python script:
If you look at my function def sidescroll(setscroll, astring), you'll see what i do is I perform math on the variable, if the variable is greater than 16 (number of LCD characters) then sidescroll will scroll the remaining number of times.
If the variable is less than 16 then there's no reason to scroll.
It's a start for me as I am brand new to python scripting and using this project as a way to start learning at least something.
This is a Franken-script that i have found bits from the internet and added my own appendages.
Cheers,
#!/usr/bin/python
# radio.py, version 3.4 (RGB LCD Pi Plate version)
# September 14.3, 2013
# Edited by Dylan Leite
# Written by Sheldon Hartling for Usual Panic
# BSD license, all text above must be included in any redistribution
# based on code from Kyle Prier (http://wwww.youtube.com/meistervision)
# and AdaFruit Industries (https://www.adafruit.com)
# Kyle Prier - https://www.dropbox.com/s/w2y8xx7t6gkq8yz/radio.py
# AdaFruit - https://github.com/adafruit/Adafruit-Raspberry-Pi-Python-Code.git, Adafruit_CharLCDPlate
#dependancies
import smbus
import os
import time
import subprocess
# initialize the LCD plate
# use busnum = 0 for raspi version 1 (256MB)
# and busnum = 1 for raspi version 2 (512MB)
LCD = Adafruit_CharLCDPlate(busnum = 1)
lcd = Adafruit_CharLCDPlate()
# Define a queue to communicate with worker thread
LCD_QUEUE = Queue()
# Globals
astring = ""
setscroll = ""
# Buttons
NONE = 0x00
SELECT = 0x01
RIGHT = 0x02
DOWN = 0x04
UP = 0x08
LEFT = 0x10
UP_AND_DOWN = 0x0C
LEFT_AND_RIGHT = 0x12
# WORKER THREAD
# Define a function to run in the worker thread
def update_lcd(q):
while True:
msg = q.get()
# if we're falling behind, skip some LCD updates
while not q.empty():
q.task_done()
msg = q.get()
LCD.setCursor(0,0)
LCD.message(msg)
q.task_done()
return
# MAIN LOOP
def main():
global astring, setscroll
# Setup AdaFruit LCD Plate
LCD.begin(16,2)
LCD.clear()
LCD.backlight(LCD.ON)
# Create the worker thread and make it a daemon
worker = Thread(target=update_lcd, args=(LCD_QUEUE,))
worker.setDaemon(True)
worker.start()
hostname = "12.10.191.251 "
response = os.system("ping -c 1 " + hostname)
if response == 0:
internetradio = "load CBC"
LCD.clear()
LCD_QUEUE.put('Internet Found', True)
sleep(2)
radioSetup(internetradio)
else:
internetradio = "listall | mpc add"
LCD.clear()
LCD_QUEUE.put('Internet Lost', True)
sleep(2)
def radioSetup(internetradio):
# START THE MUSIC!
os.system("mpc clear")
os.system("mpc %s" % internetradio)
os.system("mpc play 1")
countdown_to_play = 0
# Main loop
while True:
press = read_buttons()
# LEFT button pressed
if(press == LEFT):
volumestat=run_cmd("mpc volume 0")
os.system("mpc prev")
sleep(0.5)
volumestat=run_cmd("mpc volume 100")
# RIGHT button pressed
if(press == RIGHT):
os.system("mpc next")
sleep(0.5)
# UP button pressed
if(press == UP):
volumestat=run_cmd("mpc volume | head -n 1")
LCD.clear()
LCD_QUEUE.put(volumestat, True)
sleep(0.5)
# DOWN button pressed
if(press == DOWN):
os.system("mpc volume -2")
LCD.clear()
sleep(0.5)
# SELECT button pressed
if(press == SELECT):
menu_pressed()
# If we haven't had a key press in 300 msec
# go ahead and issue the MPC command
if(countdown_to_play > 0):
countdown_to_play -= 1
if(countdown_to_play == 0):
# Play requested station
os.system("mpc play")
delay_milliseconds(99)
update_lcd.join()
# READ SWITCHES
def read_buttons():
buttons = LCD.buttons()
# Debounce push buttons
if(buttons != 0):
while(LCD.buttons() != 0):
delay_milliseconds(1)
return buttons
def delay_milliseconds(milliseconds):
seconds = milliseconds / float(1000) # divide milliseconds by 1000 for seconds
sleep(seconds)
# RADIO SETUP MENU
def menu_pressed():
# global STATION
MENU_LIST = [
'1. Display Time\n&IP Address ',
'2. System\nShutdown! ',
'3. System\nReboot! ',
'4. Restart\nScript ',
'5. Exit\n']
item = 0
LCD.clear()
LCD_QUEUE.put(MENU_LIST[item], True)
keep_looping = True
while (keep_looping):
# Wait for a key press
# UP button
if(press == UP):
item -= 1
if(item < 0):
item = len(MENU_LIST) - 1
LCD.clear()
# DOWN button
elif(press == DOWN):
item += 1
if(item >= len(MENU_LIST)):
item = 0
LCD.clear()
# SELECT button = exit
elif(press == SELECT):
keep_looping = False
# Take action
if( item == 0):
# 1. display time and IP address
display_ipaddr()
elif(item == 1):
# 2. shutdown the system
LCD.clear()
LCD_QUEUE.put('Shutting down\nLinux now! ... ', True)
LCD_QUEUE.join()
output = run_cmd("mpc clear")
output = run_cmd("sudo shutdown -hy 0")
LCD.clear()
LCD.backlight(LCD.OFF)
exit(0)
elif(item == 2):
#3. System Reboot
LCD.clear()
LCD_QUEUE.put('Rebooting\nLinux now! ... ', True)
LCD_QUEUE.join()
output = run_cmd("sudo shutdown -ry 0")
LCD.clear()
exit(0)
elif(item == 3):
#4 script restart
main()
else:
LCD.clear()
# DISPLAY TIME AND IP ADDRESS
def display_ipaddr():
show_eth0 = "ip addr show eth0 | cut -d/ -f1 | awk '/inet/ {printf \"e%15.15s\", $2}'"
ipaddr = run_cmd(show_eth0)
i = 29
muting = False
keep_looping = True
# Every 1/2 second, update the time display
i += 1
#if(i % 10 == 0):
if(i % 5 == 0):
LCD_QUEUE.put(datetime.now().strftime('%b %d %H:%M:%S\n')+ ipaddr, True)
# Every 3 seconds, update ethernet or wi-fi IP address
if(i == 60):
i = 0
# Every 100 milliseconds, read the switches
# Take action on switch press
# UP button pressed
if(press == UP):
output = run_cmd("mpc volume +2")
if(press == DOWN):
output = run_cmd("mpc volume -2")
# LEFT or RIGHT toggles mute
elif(press == LEFT or press == RIGHT ):
if muting:
#amixer command not working, can't use next line
#output = run_cmd("amixer -q cset numid=2 1")
# mpc_play(STATION)
# work around a problem. Play always starts at full volume
delay_milliseconds(400)
else:
#output = run_cmd("amixer -q cset numid=2 0")
output = run_cmd("mpc stop" )
muting = not muting
def run_cmd(cmd):
p = Popen(cmd, shell=True, stdout=PIPE, stderr=STDOUT)
output = p.communicate()[0]
return output
def sidescroll(setscroll, astring):
LCD.clear()
astring=run_cmd("mpc | head -n 1")
if " - " in astring:
a, b, = astring.split(' - ')
print "a =" + a
print "b =" + b
elif "streamtheworld" in astring:
b, a, = astring.split('streamtheworld.com:3690/')
print "b =" + b
print "a =" + a
a = " "
setscroll=len(a)
setscroll2=len(b)
LCD_QUEUE.put(a+"\n"+b, True)
sleep(0.5)
if setscroll >= 17:
setscroll = setscroll - 17
sleep(0.4)
LCD.clear()
elif setscroll2 >= 17:
setscroll2 = setscroll2 - 17
for i in range (setscroll2):
sleep(0.4)
LCD.clear()
else:
print "working"
if __name__ == '__main__':
main()
Cheers,
I've got a strange problem with my LCD connected to the Raspberry. It turns "zeroes" and "slashes" and "?" when I plug in a headphones to it. Clear command cannot be executed as well, I tried to reset it and it works ok for a while and then again it turns to that strange output. Any help or direction to where should I start the troubleshooting is much appreciated.
