I just finished OK02 in the Baking Pi tutorial. I can now make the LED blink on and off.
So I wrote an assembly program "blink" to make the LED blink x times, where x is the value passed in r0.
I also tried transferring control to C code, since this is obviously a good step towards increased productivity.
My _start looks like this:
.section init
.globl _start
_start:
b kmainCode: Select all
int kmain()
blink(fibonacci(5));
int fibonacci(int x)
if (x == 0)
return 1;
else if (x == 1)
return 1;
else
return fibonacci(x - 1) + fibonacci(x - 2);
However, any other argument for fibonacci causes no blinks.
I'm using YAGARTO on Windows, using gcc to compile both C and assembly.
Is there anything glaringly obvious that's wrong with this code?
Is there something I should know when calling C code from assembly?
