Boreatton Scouts
Re: Qt Q
Wed May 09, 2012 4:53 pm
Quick Q - is Qt bundled in the standard SD image? I had a quick delve around but couldn't find it and realise that I do not know how to search for files and directories in linux and that the search in forums won't let me search for Qt
I am looking for Qtgui and Qtcore modules that were listed as being in Pyside.
I also need Pygame
The idea is to get puzzlebox brainstorms working if poss!
( http://www.puzzlebox.brainstorms.info )
Are they already there or do I need to get them or compile them?
Thanks all!
Max
Re: Qt Q
Wed May 09, 2012 11:28 pm
Assuming you are using the Debian image.
To install the Qt 4 libraries + python bindings:
sudo apt-get update
sudo apt-get install python-qt4
(it installs the competing python-qt4 wrapper instead of pyside, but should work as well with your application)
Boreatton Scouts
Re: Qt Q
Wed May 09, 2012 11:52 pm
Thanks Max - I'll give that a go! It'll prob be next week now as I run explorer scouts on Thurs eves and we're off to the national archery champs for the w/e...
SN
Re: Qt Q
Thu May 10, 2012 12:12 am
find DIRPATH -name SEARCH is what you're looking for
so if you want to find a file called python anywhere on the system use
find / -name python
Steve N – binatone mk4->intellivision->zx81->spectrum->cbm64->cpc6128->520stfm->pc->raspi ?
