Can you tell me if i can use the checkout anyway?You attempted to reach raspberrypi.rsdelivers.com, but the server presented an expired certificate. No information is available to indicate whether that certificate has been compromised since its expiration. This means Chromium cannot guarantee that you are communicating with raspberrypi.rsdelivers.com and not an attacker. Your computer's clock is currently set to monday 23 september 2013 16:03:47. Does that look right? If not, you should correct the error and refresh this page.
Thank you so much.
