Wed Sep 18, 2013 1:34 pm
freeman wrote:I have USB HUB with power supply 2A. My USB disk drive is Samsung 2.5", at 850mA. Raspi has 800mA power Suplay.
When connected Disk to HUB and to Raspi, i see strange messages from kernel on screen. Disk drive is working (i hear "ssss"). Raspi is freezing and not working. When i have plug off power from Raspi, it works continuesly, powered from USB UHB. Then after few tryies, blank screen, no reainbow screen at boot. I had to disconnect and put offline for 20 minutes, after that Raspi work ok, without hub and disk. What to do?
Screenshot is on my Raspi web server (
http://freeman.myftp.org/?p=84)
I think your USB hub is "the problem", given your comments and that it looks very similar to these:
http://www.cpmspectrepi.webspace.virgin ... rtHub.html
As you've discovered hubs of that type allow any PSU connected to "back power" via their USB bus lead. In your case this means that the Pi's PSU and the Hubs PSU are "fighting each other" to power the hub and any attached devices eg. your USB disk drive, leading to "instability" etc.. You need a better quality hub, that does not "back power" and is capable of powering the Pi and HDD via its ports. Note that standard hubs can only provide 500mA per port so it also needs either to have a higher current "charging port" or you'll need to use a Y cable for your drive. Better still, if your drive has its own power socket, get a suitable PSU to power it independently.
Trev.
