BertoMejia
BerryBoot Ready Squashed Images
Mon Sep 16, 2013 4:33 am
Let's start a list Squashed images ready to add to Berryboot. Berryboot is a very handy and easy to use bootloader, but the selection of operating systems it comes with is lacking. I am sure many people would love to be able to easily install Xbian, Raspbmc, RetroPi, and many others.
So, Here is the image I have, I will add more as I find more or as other's post them.
PiMame 0.7.9 - https://mega.co.nz/#!UFNmRDZY!5Ybs57Hi3 ... KEKk5BkVu4 & http://www.filedropper.com/pimame-squashed_1 & https://www.dropbox.com/s/erh0h83ekmltk ... uashed.img
RetroPie - http://www.mrvestek.com/hosted/RetroPieBB.img & & https://docs.google.com/file/d/0B5tZOR5 ... sp=sharing (thanks to ChaosAffect & MrVestek)
RetroPie 2.3 - https://drive.google.com/file/d/0B78Vh0 ... sp=sharing & & https://mega.co.nz/#!J0lREYpa!59fIeD2EQ ... ioGeTJNIos (thanks to jer1691)
Rasbain Release 3.10 Date 01/07/2014
https://drive.google.com/file/d/0BxjeHm ... sp=sharing (thanks to Holyman83)
Kali Linux Release 1.0.6a.
To install squashfs images, Berry boot suggests for you to "Put your SquashFS formatted image on a USB stick, go to the “Operating system installer”, hold down your mouse button over “Add OS” and select “Install from USB stick”"
However, when I tried to do that, Berryboot would not recognize my memory stick and gave me an error that said "Insert a USB stick or other external medium first, and try again." When trying to figure out how to solve this, I found a faster way. Instead, simply copy the squashed image to the /media/berryboot/images/ folder. You should see other images already installed here. (If you don't see any, try booting into another image you have installed and look again.) Once you copy the files there, just reboot, and the new os will appear in Berryboot.
Berto
benbrockn
Re: BerryBoot Ready Squashed Images
Sun Dec 29, 2013 2:55 pm
Hey, while searching on how to implement RetroPie into Berryboot, I found this post. I'm about to try it out:
http://www.raspberrypi.org/phpBB3/viewt ... 78&t=54488
I hope more people will contribute to this forum, having it all right here would be great.
BertoMejia
Sat Feb 01, 2014 5:22 pm
Thanks Ben. I added this to the list. I hope more people contribute too. Unfortunately, it doesn't seem that many people are using BerryBoot with their own images.
Berto
event
Wed Feb 19, 2014 1:23 pm
Also I have tried a few guides on how to convert. img to .squashfs, but it has not worked :evil: . If you've figured out how to do it, explain it well, please.
In particular, I have been following this "http://kll.engineering-news.org/kllfusi ... icle_id=45" and this "http://engineerdemos.blogspot.it/2012/0 ... 2714029461", but apparently I'm still missing something, or I'm wrong something.
BertoMejia
Wed Feb 19, 2014 4:51 pm
Angry face :evil: indeed. I used http://forum.xbian.org/thread-477.html & http://forum.xbian.org/thread-280.html, but I had very little luck. I got PiMame to work, but I was never able to get any of the others to work. Sorry I can't help more.
I started this thread because I thought we could get a big list of working images and making it easier for the people having trouble with the squashing.
If you do get the image you want to use to work, please post it here to help others.
Berto
De4dm4n
Pidora or Starcraft 1
Tue Apr 22, 2014 2:24 am
I am currently trying to get Pidora working on Berry Boot mainly because I have found a post that someone managed to get starcraft 1 working on that operating system. If there are any other ways to get it to work or someone who can explain how to make a squash file particularly on a windows 7 computer of Pidora I would like to know. The only reason I don't use Noobs is because I only have an 8 GB SD card so it is impossible to install all the operating systems I want to on it. So using Berry Boot where is can install directly to my hard Drive is quite useful.
De4dm4n
Sun Apr 27, 2014 8:17 pm
Do you think you could resquash a newer version of these files? the emulators are a bit old
BertoMejia
Mon Apr 28, 2014 5:23 am
My RPi broke, and I can't get anyone to honor the warranty. So, I don't have any newer squashed images. Hopefully, others will have newer versions.
Berto
holyman83
Sat May 24, 2014 9:42 pm
I was able to find I site that gave me all the code I needed to make a working Squashfs images. Thanks to supreeth bharadwaj at http://www.techknowblogging.com. Here is the link to the page the only problem is his single quote is a special character that notepad can read but the terminal can not. http://www.techknowblogging.com/2013/12 ... yboot.html. I'll put the code below. You need two thing installed first Kpartx and squashfs-tools. then you have to download the image you want to squash.
 # installs kpartx and squashfs-tools
sudo apt-get install kpartx squashfs-tools
# This opens your image file.
#Change the DownloadedImage.img to what your image file name is.
sudo kpartx -av DownloadedImage.img
# After opening the image it will give you at least two /dev/mapper/loop#p#.
# You want the bigger of the partitions (Normally p2).
# In this case it was loop 1 is the image and I want partition 2 because it is the bigger of the two.
# sudo mount /dev/mapper/loop1p2 /mnt
# Change # to the loop number the previous command reported.
sudo mount /dev/mapper/loop#p2 /mnt
# This is what make the image writable on berryboot
# This line should work as is.  It edits the file fstab on the image folder etc
sudo sed -i 's/^\/dev\/mmcblk/#\0/g' /mnt/etc/fstab
# This line is what takes the mounted image and converts it the a squashfs image.
# Note if you do this from the raspberry pi it will take several hours (dependent on the original image size).
# Change NewBerryBoot.img to the desired image name.
sudo mksquashfs /mnt NewBerryBoot.img -comp lzo -e lib/modules
# This unmounts the image you mounted at the beginning.
sudo umount /mnt
# This closes the image we opened at the beginning.
# Change the DownloadedImage.img to what your image file name is.
sudo kpartx -d DownloadedImage.img
Here are the two that I have done:
5/13/15 fixed a typo in the code I found.
jer1691
Thu Jul 24, 2014 6:40 pm
I have a small sdhc card on my b+ and needed to Add an OS (RetroPie) to a USB Flash Drive through BerryBoot and I wanted to make sure I had the Latest Build of RetroPie, so I just made one. I know a few people might find this useful so it was worth the time :)
Date 07/24/2014
RetroPieImage_ver2.3-BerryBoot.img (squashfs) [867.6 MB]
BertoMejia
Sat Aug 02, 2014 4:55 am
Thanks jer1691, I added yours to the list.
Berto
perkas
Thu Aug 14, 2014 12:28 pm
Have you seen this?: http://sourceforge.net/projects/berrybo ... os_images/ ;)
(Extracted from http://www.techknowblogging.com/2013/12 ... yboot.html)
I'm looking for the last Raspbmc image. Do you know where to find it? :?:
Thank you!
BertoMejia
Sat Aug 16, 2014 3:21 pm
No, that is new. I'm glad they finally started to create something like that. the lack of a list of images was the reason I started this thread.
I tried using Raspbmc, but I was never able to make it work. I also looked on the web, but could not find it. It has been a while since I looked.
Berto
mattie47
Sun Aug 17, 2014 7:52 pm
jer1691 wrote:I have a small sdhc card on my b+ and needed to Add an OS (RetroPie) to a USB Flash Drive through BerryBoot and I wanted to make sure I had the Latest Build of RetroPie, so I just made one. I know a few people might find this useful so it was worth the time :)
Date 07/24/2014
Thanks for this jer1691. I see RetroPie is now in http://sourceforge.net/projects/berrybo ... os_images/ but I did use the image you created a few weeks ago, so thanks for creating it :)
kaba
Mon Jan 05, 2015 3:15 am
Good evening I'm trying to convert the hours openelec image 5 and I'm not consequindo if someone can convert and leave the link here I thank very
Chateaudur
Fri May 22, 2015 12:32 pm
Has anyone got a Volumio and Retropie 2.6 image for the Raspberry pi 2 ? That would be fantastic !
derailius
Tue May 26, 2015 7:04 am
Didn't see these anywhere so I made them:
RetroPie version 3 beta 2 For RPi1!
retropie-v3.0beta2-rpi1-squashfs.img (squashfs) (625MB)
https://mega.co.nz/#!V8R3GboK!VSZMaamI1 ... EENHCFB_mc
RetroPie version 3 beta 2 For RPi2!
retropie-v3.0beta2-rpi2-squashfs.img (squashfs) (626MB)
https://mega.co.nz/#!ZswnQRpA!Qgxz94S-P ... PZ5StaNDvs
Mequa
Thu May 28, 2015 8:53 am
I'd like to see a BerryBoot ready image for Ubuntu MATE for Raspberry Pi 2.
Htaborda
Mon Jun 15, 2015 6:23 pm
Did anybody squash a recent version of Kali (1.1.1)?
Did anybody squash RasPlex 0.6.0?
derailius
Tue Jun 16, 2015 2:44 am
Htaborda wrote:Did anybody squash a recent version of Kali (1.1.1)?
for RasPlex 0.6.0 just make a regular SD Image, boot to it, then after you're done, copy the SYSTEM file from the SD card, and rename it to RasPlex060.img or whatever, so long as .IMG is the extension; this is now your squash IMG.
edit: I just uploaded it
rasplex.0.6.0-squashfs.img (squashfs) 120MB
https://mega.co.nz/#!Ak5VBRzT!jb96n2Mm9 ... D-Yoym8bKQ
derailius
Sat Jun 20, 2015 4:04 pm
RetroPie v3 beta 4 for RPi2 (I'll make one for RPi1 if requested)
retropie-v3.0beta4-rpi2.squashfs.img 628.8 MB
https://mega.co.nz/#!ZsITjBIZ!JaEZpPk_d ... 8s6viGkfTE
Mequa
Sat Jun 20, 2015 5:59 pm
Has anyone successfully made a working BerryBoot image for the final release of Ubuntu MATE for Raspberry Pi 2?
Jumak
Mon Jul 20, 2015 5:04 am
Hey thanks for all the cool squashed images. I am new to the Linux thing but have sucessfully got berrryboot and a bunch of OS running on my Pi2 with a 1TB external harddrive. I was wondering of someone could squash the new version of retropie v3.0 RC1
squshing images seems a bit out of my league at the moment.
cheers
JB
Methanoid
Tue Jul 21, 2015 10:57 am
OP lost interest? First post not updated for some time.
Q1: Can images be updated when booted (i.e. if you boot Raspbian can you apt-get upgrade and does it save updates)?
Q2: Can the image grow or otherwise what good is, say RetroPie if you dont have space for Roms?
Q3: Is it a simple case of totalling the image sizes and making sure they are less than your SD card? I have a Pi2 that I want to run RiscOS, Ubuntu, AEROS and maybe a couple more and want to work out the SD card size I need
zanie420
Tue Jul 21, 2015 11:47 pm
I was able to make successfully make a new Raspbian image for the may update. I will upload if there is interest
2015-05-05-raspbian-wheezy_squashfs.img
How are you all making the OpenElec images? I am stumped
Return to “Other”
Who is online
Users browsing this forum: No registered users and 4 guests
