spacebob
Pi locks up while Bitcoin mining
Wed Sep 11, 2013 5:38 pm
So I've been bitcoin mining on my Pi just fine for about a month but recently the Pi has started locking after mining for about 2 hours. My SSH connection dies and I can no longer ping the pi. I was able to catch a screen shot of the error I see
I'm running on the latest Raspian image and the USB miners are on a powered DLink USB hub.
I think that my SD card is crap (SanDisk 16GB Class 10). What leads me to believe this is that sometimes the the Pi will corrupt the SD card during the "Processing Packaging List" part of running
sudo apt-get update && sudo apt-get upgrade
jdb
Re: Pi locks up while Bitcoin mining
Wed Sep 11, 2013 9:32 pm
What mining hardware are you using?
Please post a sudo lsusb -v and full dmesg output.
Rockets are loud.
https://astro-pi.org
spacebob
Wed Sep 11, 2013 10:08 pm
I am using 5 ASICMiner USB Block Eruptors connected to a DLink Hub (DUB-H7). Like I said before, I ran with the setup fine for a month but recently it has started locking up while mining.
pi@raspberrypi ~ $ sudo lsusb -v
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9512
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      1 Single TT
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             3
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0100 power
   Port 3: 0000.0503 highspeed power enable connect
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            3.06
  iManufacturer           3 Linux 3.6.11+ dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 bcm2708_usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
Bus 001 Device 008: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x10c4 Cygnal Integrated Products, Inc.
  idProduct          0xea60 CP210x UART Bridge / myAVR mySmartUSB light
  bcdDevice            1.00
  iManufacturer           1 Eligius
  iProduct                2 Block Erupter Sapphire (Black)
  iSerial                 3 ECIM-10000191
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      iInterface              2 Block Erupter Sapphire (Black)
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 009: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            1.00
  iSerial                 3 ECIM-10000207
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  (Bus Powered)
Bus 001 Device 010: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            1.00
  iSerial                 3 ECIM-10000189
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  (Bus Powered)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x05e3 Genesys Logic, Inc.
  idProduct          0x0610 4-port hub
  bcdDevice           77.32
  iManufacturer           0
  iProduct                1 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
  wHubCharacteristic 0x00e0
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bHubContrCurrent    100 milli Ampere
 Hub Port Status:
   Port 2: 0000.0103 power enable connect
   Port 3: 0000.0103 power enable connect
   Port 4: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice           77.32
  iManufacturer           0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             4
    Port indicators
 Hub Port Status:
   Port 1: 0000.0103 power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 006: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            1.00
  iManufacturer           1 Silicon Labs
  iProduct                2 CP2102 USB to UART Bridge Controller
  iSerial                 3 0001
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              2 CP2102 USB to UART Bridge Controller
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  (Bus Powered)
Bus 001 Device 007: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  bcdDevice            1.00
  iSerial                 3 0001
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
  (Bus Powered)
pi@raspberrypi ~ $
pi@raspberrypi ~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.6.11+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13
.1+bzr2458 - Linaro GCC 2012.08) ) #541 PREEMPT Sat Sep 7 19:46:21 BST 2013
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] cma: CMA: reserved 16 MiB at 1b000000
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 114688
[    0.000000] free_area_init_node: node 0, pgdat c0545b54, node_mem_map c05f0000
[    0.000000]   Normal zone: 896 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 113792 pages, LIFO batch:31
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113792
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=
0xe bcm2708.serial=0x5e7fca3c smsc95xx.macaddr=B8:27:EB:7F:CA:3C sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base
=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 r
oot=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 448MB = 448MB total
[    0.000000] Memory: 432220k/432220k available, 26532k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xdc800000 - 0xff000000   ( 552 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04ef844   (5023 kB)
[    0.000000]       .init : 0xc04f0000 - 0xc05111f0   ( 133 kB)
[    0.000000]       .data : 0xc0512000 - 0xc0546560   ( 210 kB)
[    0.000000]        .bss : 0xc0546584 - 0xc05ef738   ( 677 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000971] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060124] pid_max: default: 32768 minimum: 301
[    0.060616] Mount-cache hash table entries: 512
[    0.061439] Initializing cgroup subsys cpuacct
[    0.061494] Initializing cgroup subsys devices
[    0.061527] Initializing cgroup subsys freezer
[    0.061556] Initializing cgroup subsys blkio
[    0.061698] CPU: Testing write buffer coherency: ok
[    0.062020] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.062159] Setting up static identity map for 0x3a5238 - 0x3a5294
[    0.063641] devtmpfs: initialized
[    0.075137] NET: Registered protocol family 16
[    0.081588] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.082662] bcm2708.uart_clock = 0
[    0.084028] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.084081] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.084116] mailbox: Broadcom VideoCore Mailbox driver
[    0.084205] bcm2708_vcio: mailbox at f200b880
[    0.084317] bcm_power: Broadcom power driver
[    0.084354] bcm_power_open() -> 0
[    0.084379] bcm_power_request(0, 8)
[    0.585066] bcm_mailbox_read -> 00000080, 0
[    0.585103] bcm_power_request -> 0
[    0.585127] Serial: AMBA PL011 UART driver
[    0.585250] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.916642] console [ttyAMA0] enabled
[    0.940876] bio: create slab <bio-0> at 0
[    0.945780] SCSI subsystem initialized
[    0.949848] usbcore: registered new interface driver usbfs
[    0.955438] usbcore: registered new interface driver hub
[    0.961027] usbcore: registered new device driver usb
[    0.967367] Switching to clocksource stc
[    0.971664] FS-Cache: Loaded
[    0.974823] CacheFiles: Loaded
[    0.989760] NET: Registered protocol family 2
[    0.995042] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.002776] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    1.009566] TCP: Hash tables configured (established 16384 bind 16384)
[    1.016165] TCP: reno registered
[    1.019417] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.025313] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.031954] NET: Registered protocol family 1
[    1.036830] RPC: Registered named UNIX socket transport module.
[    1.042876] RPC: Registered udp transport module.
[    1.047599] RPC: Registered tcp transport module.
[    1.052345] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.059464] bcm2708_dma: DMA manager at f2007000
[    1.064243] bcm2708_gpio: bcm2708_gpio_probe c051fdf8
[    1.069694] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.078902] audit: initializing netlink socket (disabled)
[    1.084499] type=2000 audit(0.940:1): initialized
[    1.217313] VFS: Disk quotas dquot_6.5.2
[    1.221682] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.230760] FS-Cache: Netfs 'nfs' registered for caching
[    1.237418] NFS: Registering the id_resolver key type
[    1.242694] Key type id_resolver registered
[    1.246898] Key type id_legacy registered
[    1.251251] msgmni has been set to 876
[    1.257240] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.265067] io scheduler noop registered
[    1.269022] io scheduler deadline registered (default)
[    1.274346] io scheduler cfq registered
[    1.289141] Console: switching to colour frame buffer device 82x26
[    1.299297] kgdb: Registered I/O driver kgdboc.
[    1.305944] vc-cma: Videocore CMA driver
[    1.311283] vc-cma: vc_cma_base      = 0x00000000
[    1.317431] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.324202] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.339504] brd: module loaded
[    1.348924] loop: module loaded
[    1.353749] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[    1.362663] Loading iSCSI transport class v2.0-870.
[    1.369825] usbcore: registered new interface driver smsc95xx
[    1.377272] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.589518] Core Release: 2.80a
[    1.594055] Setting default values for core params
[    1.600151] Finished setting default values for core params
[    1.812071] Using Buffer DMA mode
[    1.816676] Periodic Transfer Interrupt Enhancement - disabled
[    1.823777] Multiprocessor Interrupt Enhancement - disabled
[    1.830607] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.836243] Dedicated Tx FIFOs mode
[    1.842041] dwc_otg: Microframe scheduler enabled
[    1.842457] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.848716] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.857320] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.864181] Init: Port Power? op_state=1
[    1.869370] Init: Power Port (0)
[    1.874035] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.882259] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.890849] usb usb1: Product: DWC OTG Controller
[    1.896953] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    1.904090] usb usb1: SerialNumber: bcm2708_usb
[    1.910667] hub 1-0:1.0: USB hub found
[    1.915857] hub 1-0:1.0: 1 port detected
[    1.921381] dwc_otg: FIQ enabled
[    1.921398] dwc_otg: NAK holdoff enabled
[    1.921406] dwc_otg: FIQ split fix enabled
[    1.921472] Module dwc_common_port init
[    1.921691] Initializing USB Mass Storage driver...
[    1.928057] usbcore: registered new interface driver usb-storage
[    1.935463] USB Mass Storage support registered.
[    1.941570] usbcore: registered new interface driver libusual
[    1.948902] mousedev: PS/2 mouse device common for all mice
[    1.956532] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[    1.963739] bcm2835-cpufreq: switching to governor powersave
[    1.970679] bcm2835-cpufreq: switching to governor powersave
[    1.977618] cpuidle: using governor ladder
[    1.982976] cpuidle: using governor menu
[    1.988141] sdhci: Secure Digital Host Controller Interface driver
[    1.995555] sdhci: Copyright(c) Pierre Ossman
[    2.001198] sdhci: Enable low-latency mode
[    2.051660] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.062109] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.071555] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.084194] usbcore: registered new interface driver usbhid
[    2.091212] usbhid: USB HID core driver
[    2.101207] TCP: cubic registered
[    2.108031] Initializing XFRM netlink socket
[    2.115856] Indeed it is in host mode hprt0 = 00021501
[    2.122461] NET: Registered protocol family 17
[    2.141700] Key type dns_resolver registered
[    2.147836] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.172193] registered taskstats version 1
[    2.183548] mmc0: read SD Status register (SSR) after 2 attempts
[    2.202045] Waiting for root device /dev/mmcblk0p2...
[    2.210966] mmc0: new high speed SDHC card at address e624
[    2.232055] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[    2.239572]  mmcblk0: p1 p2
[    2.361533] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.370693] Indeed it is in host mode hprt0 = 00001101
[    2.582329] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.591785] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.601553] hub 1-1:1.0: USB hub found
[    2.606931] hub 1-1:1.0: 3 ports detected
[    2.891830] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.971566] EXT4-fs (mmcblk0p2): recovery complete
[    2.980496] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.991827] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.000802] devtmpfs: mounted
[    3.005852] Freeing init memory: 132K
[    3.012521] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.020988] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.033948] smsc95xx v1.0.4
[    3.096500] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb
:7f:ca:3c
[    3.191703] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.313703] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610
[    3.322349] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.331925] usb 1-1.3: Product: USB2.0 Hub
[    3.338748] hub 1-1.3:1.0: USB hub found
[    3.347563] hub 1-1.3:1.0: 4 ports detected
[    3.641946] usb 1-1.3.1: new high-speed USB device number 5 using dwc_otg
[    3.743641] usb 1-1.3.1: New USB device found, idVendor=05e3, idProduct=0610
[    3.761576] usb 1-1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.779871] usb 1-1.3.1: Product: USB2.0 Hub
[    3.796377] hub 1-1.3.1:1.0: USB hub found
[    3.804769] hub 1-1.3.1:1.0: 4 ports detected
[    3.891981] usb 1-1.3.2: new full-speed USB device number 6 using dwc_otg
[    4.008271] usb 1-1.3.2: New USB device found, idVendor=10c4, idProduct=ea60
[    4.023927] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.048840] usb 1-1.3.2: Product: CP2102 USB to UART Bridge Controller
[    4.061581] usb 1-1.3.2: Manufacturer: Silicon Labs
[    4.067952] usb 1-1.3.2: SerialNumber: 0001
[    4.172019] usb 1-1.3.3: new full-speed USB device number 7 using dwc_otg
[    4.288384] usb 1-1.3.3: New USB device found, idVendor=10c4, idProduct=ea60
[    4.304601] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.318751] usb 1-1.3.3: Product: CP2102 USB to UART Bridge Controller
[    4.326957] usb 1-1.3.3: Manufacturer: Silicon Labs
[    4.333359] usb 1-1.3.3: SerialNumber: 0001
[    4.432042] usb 1-1.3.1.1: new full-speed USB device number 8 using dwc_otg
[    4.537548] udevd[154]: starting version 175
[    4.551844] usb 1-1.3.1.1: New USB device found, idVendor=10c4, idProduct=ea60
[    4.560697] usb 1-1.3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.600606] usb 1-1.3.1.1: Product: Block Erupter Sapphire (Black)
[    4.623947] usb 1-1.3.1.1: Manufacturer: Eligius
[    4.639937] usb 1-1.3.1.1: SerialNumber: ECIM-10000191
[    4.741959] usb 1-1.3.1.2: new full-speed USB device number 9 using dwc_otg
[    4.868412] usb 1-1.3.1.2: New USB device found, idVendor=10c4, idProduct=ea60
[    4.886765] usb 1-1.3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.922187] usb 1-1.3.1.2: Product: Block Erupter Sapphire (Black)
[    4.930001] usb 1-1.3.1.2: Manufacturer: Eligius
[    4.936493] usb 1-1.3.1.2: SerialNumber: ECIM-10000207
[    5.032018] usb 1-1.3.1.3: new full-speed USB device number 10 using dwc_otg
[    5.168423] usb 1-1.3.1.3: New USB device found, idVendor=10c4, idProduct=ea60
[    5.184126] usbcore: registered new interface driver usbserial
[    5.201563] usb 1-1.3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.241659] usb 1-1.3.1.3: Product: Block Erupter Sapphire (Black)
[    5.249452] usb 1-1.3.1.3: Manufacturer: Eligius
[    5.261691] usbcore: registered new interface driver usbserial_generic
[    5.269947] USB Serial support registered for generic
[    5.281564] usb 1-1.3.1.3: SerialNumber: ECIM-10000189
[    5.321614] usbserial: USB Serial Driver core
[    5.328307] usbcore: registered new interface driver cp210x
[    5.360236] USB Serial support registered for cp210x
[    5.400739] cp210x 1-1.3.2:1.0: cp210x converter detected
[    5.501971] usb 1-1.3.2: reset full-speed USB device number 6 using dwc_otg
[    5.655662] usb 1-1.3.2: cp210x converter now attached to ttyUSB0
[    5.707648] cp210x 1-1.3.3:1.0: cp210x converter detected
[    5.912141] usb 1-1.3.3: reset full-speed USB device number 7 using dwc_otg
[    6.004324] Registered led device: led0
[    6.065939] usb 1-1.3.3: cp210x converter now attached to ttyUSB1
[    6.198041] cp210x 1-1.3.1.1:1.0: cp210x converter detected
[    6.401960] usb 1-1.3.1.1: reset full-speed USB device number 8 using dwc_otg
[    6.715909] usb 1-1.3.1.1: cp210x converter now attached to ttyUSB2
[    6.823780] cp210x 1-1.3.1.2:1.0: cp210x converter detected
[    6.952312] usb 1-1.3.1.2: reset full-speed USB device number 9 using dwc_otg
[    7.125852] usb 1-1.3.1.2: cp210x converter now attached to ttyUSB3
[    7.179284] cp210x 1-1.3.1.3:1.0: cp210x converter detected
[    7.311983] usb 1-1.3.1.3: reset full-speed USB device number 10 using dwc_otg
[    7.436359] usb 1-1.3.1.3: cp210x converter now attached to ttyUSB4
[   10.346418] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   10.765386] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   19.850090] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   20.365092] bcm2835-cpufreq: switching to governor ondemand
[   20.365124] bcm2835-cpufreq: switching to governor ondemand
[   22.393393] CIFS: no cache= option specified, using "cache=loose". This default will change to "cache=strict" in 3.7.
[   22.479383] CIFS VFS: default security mechanism requested.  The default security mechanism will be upgraded from ntl
m to ntlmv2 in kernel release 3.3
[   23.622750] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:507900k SS
pi@raspberrypi ~ $
jdb
Wed Sep 11, 2013 10:13 pm
Have you previously run rpi-update before it started crashing?
As a next test step that you can do, can you add slub_debug=FPUZ to /boot/cmdline.txt and reboot, then leave it mining? The Pi will be slower but it will catch (and be very noisy in dmesg about) memory corruption.
Rockets are loud.
spacebob
Wed Sep 11, 2013 10:16 pm
Yes, multiple times following a fresh reboot.
spacebob
Wed Sep 11, 2013 11:33 pm
I added slub_debug=FPUZ to /boot/cmdline.txt and started mining again. Once the Pi crashes what do I need to supply? Is there a log file somewhere? Once the error happens the entire Pi locks up and a reboot is needed.
jdb
Thu Sep 12, 2013 7:01 am
In theory, the Pi should not crash. If it does, then usually after reboot the /var/log/syslog file should contain most of the dmesg buffer.
Of course, take a photo of the screen before rebooting - the crashdump may be of use.
Rockets are loud.
RaTTuS
Contact: Twitter YouTube
Thu Sep 12, 2013 7:48 am
looks like cgminer is running out of RAM
try a later version ?
what gpu RAM split do you have ?
Covfefe
jdb
Thu Sep 12, 2013 9:24 am
RaTTuS wrote:looks like cgminer is running out of RAM
It's a kernel OOPS, not an OOM. The fact that it crashed somewhere inside kmalloc (fairly deep inside the kernel memory allocation routines) suggests that something broke the internal structures of the memory allocator. Usually a buggy kernel driver (or broken hardware) is the cause.
Rockets are loud.
spacebob
Thu Sep 12, 2013 11:27 am
I'm using the latest version of cgminer as I post this (3.4.2). I did go back to 3.3.4 and tried that but I would still get the same error
I haven't changed the RAM split from the default.
I've left it mining over night and it's still mining away just fine. So what exactly does adding slub_debug=FPUZ to /boot/cmdline.txt do anyway? Could my SD Card be crap since it'll get corrupted when doing an apt-get update?
jdb
Thu Sep 12, 2013 11:29 am
It adds additional checks for memory (RAM) corruption issues.
https://www.kernel.org/doc/Documentation/vm/slub.txt
There should be something in dmesg by now - can you post (or pastebin) what's in it?
Rockets are loud.
spacebob
Thu Sep 12, 2013 11:33 am
oot=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait slub_debug=FPUZ
[    0.001164] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060125] pid_max: default: 32768 minimum: 301
[    0.062613] Mount-cache hash table entries: 512
[    0.067352] Initializing cgroup subsys cpuacct
[    0.067423] Initializing cgroup subsys devices
[    0.067521] Initializing cgroup subsys freezer
[    0.067579] Initializing cgroup subsys blkio
[    0.068288] CPU: Testing write buffer coherency: ok
[    0.069259] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.069410] Setting up static identity map for 0x3a5238 - 0x3a5294
[    0.074907] devtmpfs: initialized
[    0.131174] NET: Registered protocol family 16
[    0.138178] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.143149] bcm2708.uart_clock = 0
[    0.154399] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.154465] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.154502] mailbox: Broadcom VideoCore Mailbox driver
[    0.154886] bcm2708_vcio: mailbox at f200b880
[    0.155291] bcm_power: Broadcom power driver
[    0.155336] bcm_power_open() -> 0
[    0.155362] bcm_power_request(0, 8)
[    0.656048] bcm_mailbox_read -> 00000080, 0
[    0.656086] bcm_power_request -> 0
[    0.656112] Serial: AMBA PL011 UART driver
[    0.656716] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.989514] console [ttyAMA0] enabled
[    1.165135] bio: create slab <bio-0> at 0
[    1.176866] SCSI subsystem initialized
[    1.182169] usbcore: registered new interface driver usbfs
[    1.188241] usbcore: registered new interface driver hub
[    1.194379] usbcore: registered new device driver usb
[    1.206511] Switching to clocksource stc
[    1.211824] FS-Cache: Loaded
[    1.215796] CacheFiles: Loaded
[    1.278482] NET: Registered protocol family 2
[    1.286515] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.294270] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[    1.301087] TCP: Hash tables configured (established 16384 bind 16384)
[    1.307662] TCP: reno registered
[    1.310938] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.316805] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.324354] NET: Registered protocol family 1
[    1.331763] RPC: Registered named UNIX socket transport module.
[    1.337734] RPC: Registered udp transport module.
[    1.342538] RPC: Registered tcp transport module.
[    1.347261] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.355300] bcm2708_dma: DMA manager at f2007000
[    1.360451] bcm2708_gpio: bcm2708_gpio_probe c051fdf8
[    1.366873] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    1.379628] audit: initializing netlink socket (disabled)
[    1.385465] type=2000 audit(1.230:1): initialized
[    1.600055] VFS: Disk quotas dquot_6.5.2
[    1.605403] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.632605] FS-Cache: Netfs 'nfs' registered for caching
[    1.647307] NFS: Registering the id_resolver key type
[    1.652711] Key type id_resolver registered
[    1.656921] Key type id_legacy registered
[    1.662179] msgmni has been set to 876
[    1.673587] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.682021] io scheduler noop registered
[    1.685981] io scheduler deadline registered (default)
[    1.693705] io scheduler cfq registered
[    1.721949] Console: switching to colour frame buffer device 82x26
[    1.733091] kgdb: Registered I/O driver kgdboc.
[    1.741533] vc-cma: Videocore CMA driver
[    1.746881] vc-cma: vc_cma_base      = 0x00000000
[    1.753041] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.759760] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.815105] brd: module loaded
[    1.844581] loop: module loaded
[    1.850772] vchiq: vchiq_init_state: slot_zero = 0xdb000000, is_master = 0
[    1.860563] Loading iSCSI transport class v2.0-870.
[    1.871884] usbcore: registered new interface driver smsc95xx
[    1.879045] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.092019] Core Release: 2.80a
[    2.096571] Setting default values for core params
[    2.102801] Finished setting default values for core params
[    2.315929] Using Buffer DMA mode
[    2.320581] Periodic Transfer Interrupt Enhancement - disabled
[    2.327656] Multiprocessor Interrupt Enhancement - disabled
[    2.334509] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.340222] Dedicated Tx FIFOs mode
[    2.346939] dwc_otg: Microframe scheduler enabled
[    2.347473] dwc_otg bcm2708_usb: DWC OTG Controller
[    2.353970] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    2.362828] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    2.369671] Init: Port Power? op_state=1
[    2.374893] Init: Power Port (0)
[    2.380782] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.388977] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.397605] usb usb1: Product: DWC OTG Controller
[    2.403722] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[    2.410853] usb usb1: SerialNumber: bcm2708_usb
[    2.420281] hub 1-0:1.0: USB hub found
[    2.425734] hub 1-0:1.0: 1 port detected
[    2.432811] dwc_otg: FIQ enabled
[    2.432831] dwc_otg: NAK holdoff enabled
[    2.432840] dwc_otg: FIQ split fix enabled
[    2.432884] Module dwc_common_port init
[    2.433432] Initializing USB Mass Storage driver...
[    2.440388] usbcore: registered new interface driver usb-storage
[    2.447824] USB Mass Storage support registered.
[    2.454533] usbcore: registered new interface driver libusual
[    2.462768] mousedev: PS/2 mouse device common for all mice
[    2.471961] bcm2835-cpufreq: min=700000 max=900000 cur=700000
[    2.479547] bcm2835-cpufreq: switching to governor powersave
[    2.486571] bcm2835-cpufreq: switching to governor powersave
[    2.493520] cpuidle: using governor ladder
[    2.498849] cpuidle: using governor menu
[    2.504450] sdhci: Secure Digital Host Controller Interface driver
[    2.511915] sdhci: Copyright(c) Pierre Ossman
[    2.518178] sdhci: Enable low-latency mode
[    2.571039] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.581618] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.591186] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.605597] usbcore: registered new interface driver usbhid
[    2.612657] usbhid: USB HID core driver
[    2.630845] Indeed it is in host mode hprt0 = 00021501
[    2.640913] TCP: cubic registered
[    2.645586] Initializing XFRM netlink socket
[    2.660692] NET: Registered protocol family 17
[    2.667333] Key type dns_resolver registered
[    2.684585] mmc0: new high speed SDHC card at address e624
[    2.681338] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.720570] mmcblk0: mmc0:e624 SU16G 14.8 GiB
[    2.730201] registered taskstats version 1
[    2.738161]  mmcblk0: p1 p2
[    2.791473] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.802765] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.822998] devtmpfs: mounted
[    2.828149] Freeing init memory: 132K
[    2.890833] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.899305] Indeed it is in host mode hprt0 = 00001101
[    3.122165] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    3.130472] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.154682] hub 1-1:1.0: USB hub found
[    3.162204] hub 1-1:1.0: 3 ports detected
[    3.451580] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.582503] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.598140] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.623273] smsc95xx v1.0.4
[    3.721816] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb
:7f:ca:3c
[    3.851364] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[    3.984596] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0610
[    4.000788] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.009776] usb 1-1.3: Product: USB2.0 Hub
[    4.036815] hub 1-1.3:1.0: USB hub found
[    4.053173] hub 1-1.3:1.0: 4 ports detected
[    4.351513] usb 1-1.3.1: new high-speed USB device number 5 using dwc_otg
[    4.474494] usb 1-1.3.1: New USB device found, idVendor=05e3, idProduct=0610
[    4.490767] usb 1-1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.511000] usb 1-1.3.1: Product: USB2.0 Hub
[    4.534170] hub 1-1.3.1:1.0: USB hub found
[    4.550903] hub 1-1.3.1:1.0: 4 ports detected
[    4.641777] usb 1-1.3.2: new full-speed USB device number 6 using dwc_otg
[    4.770351] usb 1-1.3.2: New USB device found, idVendor=10c4, idProduct=ea60
[    4.790860] usb 1-1.3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.810824] usb 1-1.3.2: Product: CP2102 USB to UART Bridge Controller
[    4.818936] usb 1-1.3.2: Manufacturer: Silicon Labs
[    4.840962] usb 1-1.3.2: SerialNumber: 0001
[    4.941329] usb 1-1.3.3: new full-speed USB device number 7 using dwc_otg
[    5.069918] usb 1-1.3.3: New USB device found, idVendor=10c4, idProduct=ea60
[    5.084053] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.094513] usb 1-1.3.3: Product: CP2102 USB to UART Bridge Controller
[    5.102684] usb 1-1.3.3: Manufacturer: Silicon Labs
[    5.109057] usb 1-1.3.3: SerialNumber: 0001
[    5.211500] usb 1-1.3.1.1: new full-speed USB device number 8 using dwc_otg
[    5.329961] usb 1-1.3.1.1: New USB device found, idVendor=10c4, idProduct=ea60
[    5.350968] usb 1-1.3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.368731] usb 1-1.3.1.1: Product: Block Erupter Sapphire (Black)
[    5.380076] usb 1-1.3.1.1: Manufacturer: Eligius
[    5.386537] usb 1-1.3.1.1: SerialNumber: ECIM-10000191
[    5.442667] udevd[154]: starting version 175
[    5.491541] usb 1-1.3.1.2: new full-speed USB device number 9 using dwc_otg
[    5.612131] usb 1-1.3.1.2: New USB device found, idVendor=10c4, idProduct=ea60
[    5.643429] usb 1-1.3.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.679097] usb 1-1.3.1.2: Product: Block Erupter Sapphire (Black)
[    5.710676] usb 1-1.3.1.2: Manufacturer: Eligius
[    5.717005] usb 1-1.3.1.2: SerialNumber: ECIM-10000207
[    5.831465] usb 1-1.3.1.3: new full-speed USB device number 10 using dwc_otg
[    5.987290] usb 1-1.3.1.3: New USB device found, idVendor=10c4, idProduct=ea60
[    6.018325] usb 1-1.3.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.050757] usb 1-1.3.1.3: Product: Block Erupter Sapphire (Black)
[    6.058704] usb 1-1.3.1.3: Manufacturer: Eligius
[    6.098117] usb 1-1.3.1.3: SerialNumber: ECIM-10000189
[    6.276212] usbcore: registered new interface driver usbserial
[    6.320401] usbcore: registered new interface driver usbserial_generic
[    6.431591] USB Serial support registered for generic
[    6.438279] usbserial: USB Serial Driver core
[    6.536892] usbcore: registered new interface driver cp210x
[    6.601491] USB Serial support registered for cp210x
[    6.608415] cp210x 1-1.3.2:1.0: cp210x converter detected
[    6.731742] usb 1-1.3.2: reset full-speed USB device number 6 using dwc_otg
[    6.901875] usb 1-1.3.2: cp210x converter now attached to ttyUSB0
[    7.038794] cp210x 1-1.3.3:1.0: cp210x converter detected
[    7.217047] usb 1-1.3.3: reset full-speed USB device number 7 using dwc_otg
[    7.432546] usb 1-1.3.3: cp210x converter now attached to ttyUSB1
[    7.541487] cp210x 1-1.3.1.1:1.0: cp210x converter detected
[    7.721374] usb 1-1.3.1.1: reset full-speed USB device number 8 using dwc_otg
[    7.951209] usb 1-1.3.1.1: cp210x converter now attached to ttyUSB2
[    8.038491] cp210x 1-1.3.1.2:1.0: cp210x converter detected
[    8.175565] Registered led device: led0
[    8.181552] usb 1-1.3.1.2: reset full-speed USB device number 9 using dwc_otg
[    8.337547] usb 1-1.3.1.2: cp210x converter now attached to ttyUSB3
[    8.512271] cp210x 1-1.3.1.3:1.0: cp210x converter detected
[    8.701763] usb 1-1.3.1.3: reset full-speed USB device number 10 using dwc_otg
[    8.957666] usb 1-1.3.1.3: cp210x converter now attached to ttyUSB4
[   16.287687] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.123418] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   33.548819] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[   36.866344] bcm2835-cpufreq: switching to governor ondemand
[   36.866352] bcm2835-cpufreq: switching to governor ondemand
[   37.560416] CIFS: no cache= option specified, using "cache=loose". This default will change to "cache=strict" in 3.7.
[   37.699148] CIFS VFS: default security mechanism requested.  The default security mechanism will be upgraded from ntl
[   44.136316] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:507900k SS
[  109.733559] cp210x ttyUSB1: cp210x converter now disconnected from ttyUSB1
[  109.734260] cp210x 1-1.3.3:1.0: device disconnected
[  109.812092] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
[  109.812749] cp210x 1-1.3.2:1.0: device disconnected
[  109.901944] cp210x ttyUSB4: cp210x converter now disconnected from ttyUSB4
[  109.902632] cp210x 1-1.3.1.3:1.0: device disconnected
[  109.993529] cp210x ttyUSB3: cp210x converter now disconnected from ttyUSB3
[  109.994242] cp210x 1-1.3.1.2:1.0: device disconnected
[  110.080410] cp210x ttyUSB2: cp210x converter now disconnected from ttyUSB2
[  110.081100] cp210x 1-1.3.1.1:1.0: device disconnected
[ 3877.102829] =============================================================================
[ 3877.102864] BUG kmalloc-256 (Not tainted): Poison overwritten
[ 3877.102876] -----------------------------------------------------------------------------
[ 3877.102876]
[ 3877.102893] INFO: 0xc1176540-0xc1176543. First byte 0xcb instead of 0x6b
[ 3877.102925] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2386
[ 3877.102947]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[ 3877.102978]  __kmalloc+0xd0/0xfc
[ 3877.102990]  usbdev_ioctl+0x1bcc/0x1e94
[ 3877.103013]  do_vfs_ioctl+0x80/0x5d0
[ 3877.103026]  sys_ioctl+0x34/0x60
[ 3877.103048]  ret_fast_syscall+0x0/0x30
[ 3877.103064] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2386
[ 3877.103077]  __slab_free+0x40/0x2d8
[ 3877.103088]  free_async+0xac/0xf8
[ 3877.103100]  usbdev_ioctl+0x9f8/0x1e94
[ 3877.103112]  do_vfs_ioctl+0x80/0x5d0
[ 3877.103126]  sys_ioctl+0x34/0x60
[ 3877.103138]  ret_fast_syscall+0x0/0x30
[ 3877.103150] INFO: Slab 0xc0612ec0 objects=9 used=9 fp=0x  (null) flags=0x0080
[ 3877.103161] INFO: Object 0xc1176540 @offset=1344 fp=0xc11768c0
[ 3877.103161]
[ 3877.103179] Bytes b4 c1176530: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[ 3877.103193] Object c1176540: cb ab 2a fb 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  ..*.kkkkkkkkkkkk
[ 3877.103204] Object c1176550: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103216] Object c1176560: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103227] Object c1176570: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103239] Object c1176580: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103251] Object c1176590: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103262] Object c11765a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103274] Object c11765b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103285] Object c11765c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103297] Object c11765d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103308] Object c11765e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103320] Object c11765f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103331] Object c1176600: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103342] Object c1176610: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103354] Object c1176620: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[ 3877.103365] Object c1176630: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[ 3877.103378] Redzone c1176640: bb bb bb bb                                      ....
[ 3877.103390] Padding c11766e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[ 3877.103402] Padding c11766f8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[ 3877.103442] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[ 3877.103473] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[ 3877.103502] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[ 3877.103528] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[ 3877.103555] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[ 3877.103582] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[ 3877.103609] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[ 3877.103636] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[ 3877.103663] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[ 3877.103679] FIX kmalloc-256: Restoring 0xc1176540-0xc1176543=0x6b
[ 3877.103679]
[ 3877.103692] FIX kmalloc-256: Marking all objects used
[15067.359094] =============================================================================
[15067.359128] BUG kmalloc-256 (Not tainted): Poison overwritten
[15067.359139] -----------------------------------------------------------------------------
[15067.359139]
[15067.359155] INFO: 0xc124c8c0-0xc124c8c3. First byte 0x2e instead of 0x6b
[15067.359190] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2386
[15067.359213]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[15067.359244]  __kmalloc+0xd0/0xfc
[15067.359257]  usbdev_ioctl+0x1bcc/0x1e94
[15067.359278]  do_vfs_ioctl+0x80/0x5d0
[15067.359292]  sys_ioctl+0x34/0x60
[15067.359314]  ret_fast_syscall+0x0/0x30
[15067.359331] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2386
[15067.359344]  __slab_free+0x40/0x2d8
[15067.359356]  free_async+0xac/0xf8
[15067.359367]  usbdev_ioctl+0x9f8/0x1e94
[15067.359380]  do_vfs_ioctl+0x80/0x5d0
[15067.359392]  sys_ioctl+0x34/0x60
[15067.359404]  ret_fast_syscall+0x0/0x30
[15067.359418] INFO: Slab 0xc0614980 objects=9 used=9 fp=0x  (null) flags=0x0080
[15067.359429] INFO: Object 0xc124c8c0 @offset=2240 fp=0xc124c1c0
[15067.359429]
[15067.359448] Bytes b4 c124c8b0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[15067.359461] Object c124c8c0: 2e 4a 22 0c 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  .J".kkkkkkkkkkkk
[15067.359473] Object c124c8d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359484] Object c124c8e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359496] Object c124c8f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359508] Object c124c900: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359519] Object c124c910: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359531] Object c124c920: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359544] Object c124c930: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359555] Object c124c940: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359566] Object c124c950: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359578] Object c124c960: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359589] Object c124c970: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359601] Object c124c980: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359612] Object c124c990: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359623] Object c124c9a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15067.359635] Object c124c9b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[15067.359647] Redzone c124c9c0: bb bb bb bb                                      ....
[15067.359659] Padding c124ca68: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[15067.359672] Padding c124ca78: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[15067.359712] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[15067.359743] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[15067.359770] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[15067.359797] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[15067.359825] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[15067.359851] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[15067.359878] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[15067.359903] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[15067.359931] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[15067.359947] FIX kmalloc-256: Restoring 0xc124c8c0-0xc124c8c3=0x6b
[15067.359947]
[15067.359960] FIX kmalloc-256: Marking all objects used
[15851.287536] =============================================================================
[15851.287572] BUG kmalloc-256 (Not tainted): Poison overwritten
[15851.287582] -----------------------------------------------------------------------------
[15851.287582]
[15851.287598] INFO: 0xd9828540-0xd9828543. First byte 0xe5 instead of 0x6b
[15851.287631] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2385
[15851.287652]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[15851.287686]  __kmalloc+0xd0/0xfc
[15851.287700]  usbdev_ioctl+0x1bcc/0x1e94
[15851.287722]  do_vfs_ioctl+0x80/0x5d0
[15851.287735]  sys_ioctl+0x34/0x60
[15851.287756]  ret_fast_syscall+0x0/0x30
[15851.287774] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2385
[15851.287786]  __slab_free+0x40/0x2d8
[15851.287800]  free_async+0xac/0xf8
[15851.287812]  usbdev_ioctl+0x9f8/0x1e94
[15851.287825]  do_vfs_ioctl+0x80/0x5d0
[15851.287837]  sys_ioctl+0x34/0x60
[15851.287849]  ret_fast_syscall+0x0/0x30
[15851.287862] INFO: Slab 0xc0920500 objects=9 used=9 fp=0x  (null) flags=0x0080
[15851.287873] INFO: Object 0xd9828540 @offset=1344 fp=0xd98281c0
[15851.287873]
[15851.287891] Bytes b4 d9828530: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[15851.287904] Object d9828540: e5 e8 5b 51 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  ..[Qkkkkkkkkkkkk
[15851.287917] Object d9828550: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287929] Object d9828560: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287941] Object d9828570: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287952] Object d9828580: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287964] Object d9828590: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287975] Object d98285a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287987] Object d98285b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.287999] Object d98285c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288010] Object d98285d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288022] Object d98285e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288033] Object d98285f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288046] Object d9828600: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288058] Object d9828610: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288070] Object d9828620: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[15851.288082] Object d9828630: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[15851.288094] Redzone d9828640: bb bb bb bb                                      ....
[15851.288106] Padding d98286e8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[15851.288118] Padding d98286f8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[15851.288160] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[15851.288193] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[15851.288220] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[15851.288246] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[15851.288273] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[15851.288300] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[15851.288329] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[15851.288354] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[15851.288381] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[15851.288397] FIX kmalloc-256: Restoring 0xd9828540-0xd9828543=0x6b
[15851.288397]
[15851.288411] FIX kmalloc-256: Marking all objects used
[16631.768415] =============================================================================
[16631.768451] BUG kmalloc-256 (Not tainted): Poison overwritten
[16631.768461] -----------------------------------------------------------------------------
[16631.768461]
[16631.768478] INFO: 0xc13ca1c0-0xc13ca1c3. First byte 0xaf instead of 0x6b
[16631.768511] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=14 cpu=0 pid=2384
[16631.768534]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[16631.768565]  __kmalloc+0xd0/0xfc
[16631.768579]  usbdev_ioctl+0x1bcc/0x1e94
[16631.768602]  do_vfs_ioctl+0x80/0x5d0
[16631.768615]  sys_ioctl+0x34/0x60
[16631.768636]  ret_fast_syscall+0x0/0x30
[16631.768654] INFO: Freed in free_async+0xac/0xf8 age=4 cpu=0 pid=2385
[16631.768668]  __slab_free+0x40/0x2d8
[16631.768679]  free_async+0xac/0xf8
[16631.768691]  usbdev_ioctl+0x9f8/0x1e94
[16631.768706]  do_vfs_ioctl+0x80/0x5d0
[16631.768718]  sys_ioctl+0x34/0x60
[16631.768731]  ret_fast_syscall+0x0/0x30
[16631.768743] INFO: Slab 0xc0617940 objects=9 used=9 fp=0x  (null) flags=0x0080
[16631.768754] INFO: Object 0xc13ca1c0 @offset=448 fp=0xc13cae00
[16631.768754]
[16631.768773] Bytes b4 c13ca1b0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[16631.768786] Object c13ca1c0: af 89 28 79 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  ..(ykkkkkkkkkkkk
[16631.768798] Object c13ca1d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768810] Object c13ca1e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768822] Object c13ca1f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768835] Object c13ca200: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768846] Object c13ca210: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768858] Object c13ca220: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768869] Object c13ca230: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768880] Object c13ca240: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768891] Object c13ca250: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768903] Object c13ca260: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768914] Object c13ca270: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768926] Object c13ca280: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768937] Object c13ca290: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768950] Object c13ca2a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[16631.768961] Object c13ca2b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[16631.768974] Redzone c13ca2c0: bb bb bb bb                                      ....
[16631.768986] Padding c13ca368: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[16631.768997] Padding c13ca378: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[16631.769037] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[16631.769068] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[16631.769097] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[16631.769123] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[16631.769151] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[16631.769179] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[16631.769206] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[16631.769232] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[16631.769258] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[16631.769275] FIX kmalloc-256: Restoring 0xc13ca1c0-0xc13ca1c3=0x6b
[16631.769275]
[16631.769288] FIX kmalloc-256: Marking all objects used
[21434.490169] =============================================================================
[21434.490204] BUG kmalloc-256 (Not tainted): Poison overwritten
[21434.490216] -----------------------------------------------------------------------------
[21434.490216]
[21434.490232] INFO: 0xd7107000-0xd7107003. First byte 0x42 instead of 0x6b
[21434.490264] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2388
[21434.490287]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[21434.490319]  __kmalloc+0xd0/0xfc
[21434.490331]  usbdev_ioctl+0x1bcc/0x1e94
[21434.490353]  do_vfs_ioctl+0x80/0x5d0
[21434.490366]  sys_ioctl+0x34/0x60
[21434.490387]  ret_fast_syscall+0x0/0x30
[21434.490406] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2388
[21434.490419]  __slab_free+0x40/0x2d8
[21434.490431]  free_async+0xac/0xf8
[21434.490444]  usbdev_ioctl+0x9f8/0x1e94
[21434.490458]  do_vfs_ioctl+0x80/0x5d0
[21434.490470]  sys_ioctl+0x34/0x60
[21434.490483]  ret_fast_syscall+0x0/0x30
[21434.490496] INFO: Slab 0xc08d20e0 objects=9 used=9 fp=0x  (null) flags=0x0080
[21434.490507] INFO: Object 0xd7107000 @offset=0 fp=0xd7107a80
[21434.490507]
[21434.490526] Object d7107000: 42 8e b9 6f 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  B..okkkkkkkkkkkk
[21434.490538] Object d7107010: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490550] Object d7107020: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490562] Object d7107030: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490575] Object d7107040: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490586] Object d7107050: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490598] Object d7107060: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490609] Object d7107070: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490621] Object d7107080: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490632] Object d7107090: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490643] Object d71070a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490655] Object d71070b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490667] Object d71070c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490678] Object d71070d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490691] Object d71070e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[21434.490703] Object d71070f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[21434.490715] Redzone d7107100: bb bb bb bb                                      ....
[21434.490727] Padding d71071a8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[21434.490739] Padding d71071b8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[21434.490780] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[21434.490812] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[21434.490842] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[21434.490868] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[21434.490896] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[21434.490923] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[21434.490951] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[21434.490977] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[21434.491003] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[21434.491019] FIX kmalloc-256: Restoring 0xd7107000-0xd7107003=0x6b
[21434.491019]
[21434.491033] FIX kmalloc-256: Marking all objects used
[23151.469828] smsc95xx 1-1.1:1.0: eth0: unexpected urb length 0
[25447.386187] =============================================================================
[25447.386221] BUG kmalloc-256 (Not tainted): Poison overwritten
[25447.386231] -----------------------------------------------------------------------------
[25447.386231]
[25447.386247] INFO: 0xd9b00e00-0xd9b00e03. First byte 0x34 instead of 0x6b
[25447.386282] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2385
[25447.386303]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[25447.386334]  __kmalloc+0xd0/0xfc
[25447.386347]  usbdev_ioctl+0x1bcc/0x1e94
[25447.386368]  do_vfs_ioctl+0x80/0x5d0
[25447.386383]  sys_ioctl+0x34/0x60
[25447.386405]  ret_fast_syscall+0x0/0x30
[25447.386422] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2387
[25447.386435]  __slab_free+0x40/0x2d8
[25447.386446]  free_async+0xac/0xf8
[25447.386458]  usbdev_ioctl+0x9f8/0x1e94
[25447.386471]  do_vfs_ioctl+0x80/0x5d0
[25447.386484]  sys_ioctl+0x34/0x60
[25447.386496]  ret_fast_syscall+0x0/0x30
[25447.386511] INFO: Slab 0xc0926000 objects=9 used=9 fp=0x  (null) flags=0x0080
[25447.386522] INFO: Object 0xd9b00e00 @offset=3584 fp=0xd9b00540
[25447.386522]
[25447.386540] Bytes b4 d9b00df0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[25447.386553] Object d9b00e00: 34 51 af 8a 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  4Q..kkkkkkkkkkkk
[25447.386565] Object d9b00e10: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386577] Object d9b00e20: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386588] Object d9b00e30: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386599] Object d9b00e40: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386611] Object d9b00e50: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386622] Object d9b00e60: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386635] Object d9b00e70: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386646] Object d9b00e80: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386658] Object d9b00e90: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386669] Object d9b00ea0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386681] Object d9b00eb0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386692] Object d9b00ec0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386704] Object d9b00ed0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386715] Object d9b00ee0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[25447.386727] Object d9b00ef0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[25447.386739] Redzone d9b00f00: bb bb bb bb                                      ....
[25447.386753] Padding d9b00fa8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[25447.386764] Padding d9b00fb8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[25447.386806] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[25447.386836] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[25447.386862] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[25447.386889] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[25447.386917] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[25447.386944] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[25447.386969] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[25447.386995] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[25447.387023] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[25447.387039] FIX kmalloc-256: Restoring 0xd9b00e00-0xd9b00e03=0x6b
[25447.387039]
[25447.387052] FIX kmalloc-256: Marking all objects used
[27089.781449] =============================================================================
[27089.781482] BUG kmalloc-256 (Not tainted): Poison overwritten
[27089.781492] -----------------------------------------------------------------------------
[27089.781492]
[27089.781510] INFO: 0xd70ec700-0xd70ec703. First byte 0x22 instead of 0x6b
[27089.781543] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2387
[27089.781565]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[27089.781596]  __kmalloc+0xd0/0xfc
[27089.781610]  usbdev_ioctl+0x1bcc/0x1e94
[27089.781631]  do_vfs_ioctl+0x80/0x5d0
[27089.781646]  sys_ioctl+0x34/0x60
[27089.781667]  ret_fast_syscall+0x0/0x30
[27089.781684] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2387
[27089.781698]  __slab_free+0x40/0x2d8
[27089.781709]  free_async+0xac/0xf8
[27089.781721]  usbdev_ioctl+0x9f8/0x1e94
[27089.781734]  do_vfs_ioctl+0x80/0x5d0
[27089.781746]  sys_ioctl+0x34/0x60
[27089.781759]  ret_fast_syscall+0x0/0x30
[27089.781772] INFO: Slab 0xc08d1d80 objects=9 used=9 fp=0x  (null) flags=0x0080
[27089.781783] INFO: Object 0xd70ec700 @offset=1792 fp=0xd70ec540
[27089.781783]
[27089.781801] Bytes b4 d70ec6f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[27089.781814] Object d70ec700: 22 2b b5 aa 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  "+..kkkkkkkkkkkk
[27089.781826] Object d70ec710: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781838] Object d70ec720: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781850] Object d70ec730: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781861] Object d70ec740: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781873] Object d70ec750: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781885] Object d70ec760: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781897] Object d70ec770: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781908] Object d70ec780: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781920] Object d70ec790: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781931] Object d70ec7a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781942] Object d70ec7b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781954] Object d70ec7c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781965] Object d70ec7d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781977] Object d70ec7e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[27089.781988] Object d70ec7f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[27089.782000] Redzone d70ec800: bb bb bb bb                                      ....
[27089.782013] Padding d70ec8a8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[27089.782025] Padding d70ec8b8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[27089.782066] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[27089.782097] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[27089.782124] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[27089.782151] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[27089.782179] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[27089.782206] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[27089.782233] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[27089.782259] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[27089.782286] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[27089.782302] FIX kmalloc-256: Restoring 0xd70ec700-0xd70ec703=0x6b
[27089.782302]
[27089.782316] FIX kmalloc-256: Marking all objects used
[31241.991564] =============================================================================
[31241.991598] BUG kmalloc-256 (Not tainted): Poison overwritten
[31241.991608] -----------------------------------------------------------------------------
[31241.991608]
[31241.991625] INFO: 0xd9aa0700-0xd9aa0703. First byte 0x68 instead of 0x6b
[31241.991657] INFO: Allocated in usbdev_ioctl+0x1bcc/0x1e94 age=10 cpu=0 pid=2385
[31241.991678]  __slab_alloc.isra.56.constprop.61+0x46c/0x4e8
[31241.991709]  __kmalloc+0xd0/0xfc
[31241.991722]  usbdev_ioctl+0x1bcc/0x1e94
[31241.991743]  do_vfs_ioctl+0x80/0x5d0
[31241.991758]  sys_ioctl+0x34/0x60
[31241.991779]  ret_fast_syscall+0x0/0x30
[31241.991797] INFO: Freed in free_async+0xac/0xf8 age=0 cpu=0 pid=2385
[31241.991810]  __slab_free+0x40/0x2d8
[31241.991821]  free_async+0xac/0xf8
[31241.991832]  usbdev_ioctl+0x9f8/0x1e94
[31241.991844]  do_vfs_ioctl+0x80/0x5d0
[31241.991856]  sys_ioctl+0x34/0x60
[31241.991868]  ret_fast_syscall+0x0/0x30
[31241.991883] INFO: Slab 0xc0925400 objects=9 used=9 fp=0x  (null) flags=0x0080
[31241.991893] INFO: Object 0xd9aa0700 @offset=1792 fp=0xd9aa0380
[31241.991893]
[31241.991912] Bytes b4 d9aa06f0: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[31241.991925] Object d9aa0700: 68 c8 bc 7d 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  h..}kkkkkkkkkkkk
[31241.991937] Object d9aa0710: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.991949] Object d9aa0720: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.991960] Object d9aa0730: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.991972] Object d9aa0740: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.991983] Object d9aa0750: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.991996] Object d9aa0760: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992007] Object d9aa0770: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992019] Object d9aa0780: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992030] Object d9aa0790: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992042] Object d9aa07a0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992054] Object d9aa07b0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992066] Object d9aa07c0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992077] Object d9aa07d0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992088] Object d9aa07e0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b  kkkkkkkkkkkkkkkk
[31241.992100] Object d9aa07f0: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b a5  kkkkkkkkkkkkkkk.
[31241.992112] Redzone d9aa0800: bb bb bb bb                                      ....
[31241.992125] Padding d9aa08a8: 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a 5a  ZZZZZZZZZZZZZZZZ
[31241.992136] Padding d9aa08b8: 5a 5a 5a 5a 5a 5a 5a 5a                          ZZZZZZZZ
[31241.992178] [<c0013b60>] (unwind_backtrace+0x0/0xf0) from [<c00bef84>] (check_bytes_and_report+0xbc/0x100)
[31241.992208] [<c00bef84>] (check_bytes_and_report+0xbc/0x100) from [<c00bf16c>] (check_object+0x1a4/0x230)
[31241.992235] [<c00bf16c>] (check_object+0x1a4/0x230) from [<c039d3c0>] (alloc_debug_processing+0x144/0x16c)
[31241.992263] [<c039d3c0>] (alloc_debug_processing+0x144/0x16c) from [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x
46c/0x4e8)
[31241.992290] [<c039d854>] (__slab_alloc.isra.56.constprop.61+0x46c/0x4e8) from [<c00c0a00>] (__kmalloc+0xd0/0xfc)
[31241.992317] [<c00c0a00>] (__kmalloc+0xd0/0xfc) from [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94)
[31241.992345] [<c0284194>] (usbdev_ioctl+0x1bcc/0x1e94) from [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0)
[31241.992371] [<c00d65ec>] (do_vfs_ioctl+0x80/0x5d0) from [<c00d6b70>] (sys_ioctl+0x34/0x60)
[31241.992399] [<c00d6b70>] (sys_ioctl+0x34/0x60) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[31241.992416] FIX kmalloc-256: Restoring 0xd9aa0700-0xd9aa0703=0x6b
[31241.992416]
[31241.992429] FIX kmalloc-256: Marking all objects used
pi@raspberrypi ~ $ slub_debug=FPUZ to /boot/cmdline.txt
jdb
Re: Pi locks up while Bitcoin mining
Thu Sep 12, 2013 12:20 pm
We have a winner!
Use-after-free somewhere in the kernel. I suspect the cp210x driver because there have been no other reports from people using serial port adapters that they've had kernel OOPSes.
We recently changed the kernel memory allocator to SLUB for increased performance (incidentally also allowing this sort of debugging) which meant that this bug, which has probably always been there, has crawled into the open.
Rockets are loud.
https://astro-pi.org
spacebob
Thu Sep 12, 2013 12:35 pm
So this is a kernel bug, more specifically a bug in SLUB?
I guess now it's just a waiting game for the bug to be fixed in a newer kernel.
Thanks for the help btw. Awesome support!
jdb
Thu Sep 12, 2013 12:40 pm
I'd say it's most likely to be a bug within the upstream cp210x driver. I may end up buying one or more of these devices that has this chipset in in order to find out what it really is.
For now, you can probably just let SLUB keep catching the errors. You can probably omit U and Z from the debug options and it'll still work (and be a bit faster).
Rockets are loud.
spacebob
Thu Sep 12, 2013 12:44 pm
Good to know. Thanks. I'll also remove the U and Z from the debug options from SLUB. I do notice that there is about 2x as much processor usage with it on.
In the mean time I'm going to try a use a different memory card since my current one gets currupted so often (e.g. probably 1 in 10 times when running apt-get update)
spacebob
Thu Sep 12, 2013 2:14 pm
Another interesting development. The author of cgminer says that it doesn't use the cp210x driver. It uses libusb. What is using cp210x and causing it to crash?
https://bitcointalk.org/index.php?topic ... msg3137080
jdb
Thu Sep 12, 2013 3:31 pm
Interesting.
There is plenty of probing done by cp210x in the dmesg log, so I would have assumed it was still in control. Perhaps that's why the disconnect messages follow a couple of minutes later. With it unbound from the devices it's out of the picture.
The annoying thing is that the stack trace is suspiciously shallow, bottoming out at usbdev_ioctl (which I assume is how libusb "talks" to USB devices). There is plenty that goes on in that function, including creation and freeing of URBs/control message requests.
If you're willing to try it, then you can do (as root, not through sudo) echo "Y" > /sys/module/usbcore/parameters/usbfs_snoop. This will create a *ridiculous* amount of spam in dmesg, and probably fill up your SD card, but when you next get a complaint from SLUB it should tell us the last thing libusb called.
Rockets are loud.
spacebob
Thu Sep 12, 2013 3:49 pm
If it'll help you diagnose the issue then I guess I could give it a try.
To prevent filling up the SD card could I start up cgminer, let it run for about 45 minutes (since it looks like the first error happens after an hour), then execute echo "Y" > /sys/module/usbcore/parameters/usbfs_snoop?
jdb
Thu Sep 12, 2013 6:13 pm
The problem is that the occurrences of memory corruption are very infrequent compared to the actual number of times that libusb will call the kernel. You may get the first one after 45 minutes, the next after 10 etc. Like I said, probably filling your SD card up in the meantime.
I would issue the command immediately after you start cgminer and just bite the bullet.
Rockets are loud.
masmullin
Sun Sep 15, 2013 4:26 am
Hi Bob. i had a very similar issue to what you were seeing. I have a rpi with 7 asic miners. The pi would freeze aprox every 7 minutes with all 7 going. If I removed 3 miners my uptime got into the 2 hour range. I've been going strong for the past 4 hours after taking a few steps
So here's what I did
1) switched to Arch
2) stopped mining as root, and instead mine as a lower privileged user
3) set up a watchdog to reboot the pi if it freezes (it hasn't frozen however).
4) switched my USB hub from one that provides 2.4A total power (in fact my hub is the same D-LINK as yours) , to one that supplies 3.5A total power
4) use only 6 asic miners (take less power than the hub's maximum)
Because I have cgminer set up to run at bootup, setting up a watchdog is very useful so that even if the pi does freeze, I only lose 40seconds of mining time
I'm not sure if the switch to arch, or the switch to an unprivileged user helped with the crashes
My USB hub can supply a maximum of 3.5A. Each asic can draw 0.51... thus 7 asics is "slightly" higher than the usb. 7 asics was MUCH higher than the original hub.
My thinking is that the overdrawing of power was causing a short power outage in some of the asics, thus the usb ioctl wasn't malloc/freeing properly as they kept popping in and out of service.
Here is what I suggest you do
1) mine using only 3 asics for a bit... see if the problem returns
2) set up a watchdog + starting cgminer at bootup. So long as you are only rebooting once every 30min or less, the downtime shouldn't cost you very many hashes.
Let me know:)
spacebob
Sun Sep 15, 2013 11:24 am
Thanks for the suggestions masmullin. I have tried mining with just 1 miner plugged into the hub and the pi with still lock up. There doesn't seem to be a correlation with how long it takes to crash and how many miners are being used.
Looking over at this post https://bitcointalk.org/index.php?topic=253749.0 Plugging 7 miners in the DLink hub is too many. It sounds like most people are successful with only 6. Since I am only running with 5 I don't think I am running into any power issues.
When I say the Pi locks up I mean it REALLY locks up. No keyboard input works and I cannot even ping the pi. So I don't think setting up a watchdog process would help.
Using jdb's suggestion and adding slub_debug=FP to /boot/cmdline.txt has pretty much solved the issue. I have been mining non-stop for 3 days now with no issues. I think this means it's most likely a software bug.
dennis123
Tue Sep 24, 2013 5:09 pm
My experience is as follows:
Image, raspbian, is upgraded, followed by slimming down:
http://wiki.stocksy.co.uk/wiki/Raspberr ... mming_Down
memory split has NOT been slimmed.
cgminer-3.1.1 runs 9-block erupters , 6A P/S, on the old model pi with 256M ram for at least days without incident. The same is true of a new model pi running 2-block erupters.
cgminter-3.4.3 will only run for a few hours before locking up the new model pi with 2-block erupters. Two lockups observed before changing back to cgminer-3.1.1 .
RaTTuS
Mon Sep 30, 2013 9:50 am
spacebob wrote:...
this will get your RPi to reboot - it's what the watchdog does
[the watchdog will reboot the machine unless some process stops it .... that process is running all the time]
Covfefe
spacebob
Mon Sep 30, 2013 3:18 pm
RaTTuS wrote:
spacebob wrote:...
I guess what I mean is I'm not sure if any code is still running on the Pi. Since I cannot even ping the Pi once it locks up I'm assuming that the kernel is not executing at all.
But like I said above, adding slub_debug=FP to /boot/cmdline.txt has completely solved the issue for me. Since adding that my Pi have never locked up.
