gaggio wrote:
- I recently installed a clean archlinux-hf-2013-07-22.img, but the same problem was there with the previous install, and the system is regularly updated
What was the first image you installed? Have you always had this problem or did it just start recently? I ask because I have had good luck with earlier images and not later ones, for my ssh.
And sometimes I do have to restart ethernet manually from a keyboard.
One possible solution is to have some sort of script that runs after rebooting, that would bring up the connection if it does not come up automatically.
gaggio wrote:
- I don't have netctl configured, actually I haven't configure anything regarding the network.
You might take a look at what netctl profiles are in your /etc/netctl directory. Make sure that the one that is there fits your circumstances. If you have a static IP address, then you need to use a static ethernet profile. Copy the one from /etc/netctl/examples to /etc/netctl, make it the only one there, giving it whatever name you like, and make sure it has the correct static address in it.
gaggio wrote:
- didn't know about sync before reboot, I maybe have to read more about it, but it doesn't seem to be needed nowadays
Hmm, where did you get that idea? It is always wise to sync before reboot as far as I know, not worth the risk of not doing so. Have you run fsck on your partitions? Are they clean?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
