gmc
C code for MCP3008
Sat Aug 31, 2013 3:50 pm
Thought I'd just post this here - took me ages to find a working C library, but this one works great.
Hopefully it will help someone else out.
http://gpcf.eu/projects/embedded/adc/
I originally used a c++ one but needed to go back to C.
If you want a C++ library this works as well. (I could never get the Adafruit one working)
http://hertaville.com/2013/07/24/interf ... i-using-c/
gordon@drogon.net
Re: C code for MCP3008
Mon Sep 02, 2013 2:26 pm
gmc wrote:Thought I'd just post this here - took me ages to find a working C library, but this one works great.
wiringPi has a built-in for this chip:
#include <wiringPi.h>
#include <mcp3004.h>
#define BASE 100
#define SPI_CHAN 0
  wiringPiSetup() ;
  mcp3004Setup (BASE, SPI_CHAN) ; // 3004 and 3008 are the same 4/8 channels
  for chan = 0 ; chan < 8 ; ++chan)
    x = analogRead (BASE + chan) ;
... etc.
-Gordon
gmc
Mon Sep 02, 2013 2:35 pm
wow - even easier.
Time to recode!
Thanks.
gmc
Fri Sep 13, 2013 4:08 pm
Trying to get the wiringpi working and am struggling.
In the above code what variable do the following represent:
#define BASE 100
#define SPI_CHAN 0
gordon@drogon.net
Fri Sep 13, 2013 4:15 pm
gmc wrote:Trying to get the wiringpi working and am struggling.
#define BASE 100
#define SPI_CHAN 0
In this instance, the SPI_CHAN is fairly obvious - it's the SPI channel (0 or 1) that the peripheral is connected to. The BASE is the new pin base for the chip. So the inputs to the chip are on pins 100 through 107. wiringPi creates these new pins for you when you call the setup function.
value = analogRead (100) ;
will read the first port on the chip.
-Gordon
gmc
Fri Sep 13, 2013 5:46 pm
Odd - tried that. Its not reading the values. I know the setup is correct as I have another c which uses different libraties and its retrieving values with it.
Anything glaringly obvious?
#include <stdio.h>
#include <stdlib.h>
#define BASE 200
#define SPI_CHAN 0
int main(void)
  int chan;
  int x;
printf ("Raspberry Pi wiringPi test program\n") ;
 if (wiringPiSetup () == -1)
    exit (1) ;
  mcp3004Setup (BASE, SPI_CHAN); // 3004 and 3008 are the same 4/8 channels
  for (chan = 0 ; chan < 8 ; ++chan) {
  printf("%d\n", x);
   return 0 ;
05hicklingmr
Tue Dec 17, 2013 11:16 am
gmc wrote:Odd - tried that. Its not reading the values. I know the setup is correct as I have another c which uses different libraties and its retrieving values with it.
#include <stdio.h>
#include <stdlib.h>
#define BASE 200
#define SPI_CHAN 0
int main(void)
  int chan;
  int x;
    exit (1) ;
  printf("%d\n", x);
   return 0 ;
hey! did you get anywhere with this... ui am also struggling with analogread on the wiringpi library...
gmc
Tue Dec 17, 2013 11:21 am
Nope - unfortunately never got the code working. I'm still at a loss as to why it doesn't work.
joliverl
Tue Dec 17, 2013 1:55 pm
did you try to run:
gpio load spi
gpio -x mcp3004:100:0 aread 100
This will at least give you the assurance that the wiring is correct. You need to have wiringpi installed.
J
joliverl
Tue Dec 17, 2013 9:16 pm
check this post for a working solution.
http://www.raspberrypi.org/phpBB3/viewt ... 05#p470705
martid95
Thu Mar 13, 2014 9:58 am
Hi to everyone :) I'm having the same problem as you using MCP3008. I tried to use "mcp3008.h" from gpcf.eu but it doesn't work. I get exit status 139 on gpio_init(clock, "out"). Is there someone who can help me?
Otherwise I found a library for MCP3004 on wiringPi, someone can tell me what should I modify on that library to make it work with 3008??
I'm getting crazy.... thanks in advance ( and sorry for my English)
thomasemil
Wed May 31, 2017 12:15 pm
mcp3004 works for me
// includes the wiringPI_api
// includes C standard library
#include <stdio.h>
//BASE is a new pin base for the chip of the analog pins
#define BASE 100
// chose the SPI_channel
#define SPI_CHAN 0
#include "mcp3004.h"
Int main()
	// starts the wiringPi_api
	If (wiringPiSetup() == -1)
	return 1;
/*********all*of*this*is *for*the*mcp300X************/
	int chan;
	int mcp_answer;
	//if you use a mcp3008 write canche it in the setup
	mcp3004Setup(BASE, SPI_CHAN);
	while (1)
// with chan can you set what analog channels you want to read
                   for ( chan = 0; chan < 4 ;chan++)
                  	 mcp_answer = analogRead( BASE + chan);
		 printf(“%d”, mcp_answer);
// return 0 breaks the loop
return 0;
calvinjarrod
Mon Jun 26, 2017 4:39 pm
This code worked for me. I had a little trouble until I connected CE0 on the RPi to SC on the MCP3008 chip. I've read through the SPI library info on Gordon's website. How would you change the code to read from two channels on the chip?
thomasemil
Mon Jun 26, 2017 8:34 pm
calvinjarrod wrote: How would you change the code to read from two channels on the chip?
The code should work for multiple channels , i didn't tried because i only needed one, but i got 4 different values for sure. So i don't see a problem there.
But i will try the other channels if you want to, just post a reply and let me know.
Sry i dont know if i got you question right.
Just edit chan <2 and you got your two channels.
or what do you want ?
aboutPi
Mon Nov 13, 2017 5:52 am
I have tried to use wiringPi for a MCP3008 and Potentiometer like abouve, but I did not get any value.
wiringPiSetupGpio ();
mcp3004Setup(this->MCP3008_BASE, this->MCP3008_SPI_CHAN) ; // 3004 and 3008 are the same 4/8 channels
int value = analogRead(this->MCP3008_BASE);
Otherwise using a Python Script everything works well. These are my Pin Settings:
# Konfiguration Eingangskanal und GPIOs
CH = 0  # Analog/Digital-Channel
CLK     = 18 # Clock
DIN     = 24 # Digital in
DOUT    = 23  # Digital out
CS      = 25  # Chip-Select
# Pin-Programmierung
GPIO.setup(CLK, GPIO.OUT)
GPIO.setup(DIN, GPIO.OUT)
GPIO.setup(DOUT, GPIO.IN)
GPIO.setup(CS,   GPIO.OUT)
Don't know how to solve the problem. Any idea?
gordon@drogon.net
Mon Nov 13, 2017 11:05 am
Not knowing what this->base and this->chan is, then I've no idea.
If this work at the command-line level:
  gpio -xmcp3004:777:0 aread 777
then this will work in code:
  mcp3004Setup (777, 0) ;
  value = analogRead (777 + 0) ; // Reads channel 0
  value2 = analogRead (777+7) ; // Reads channel 7
-Gordon
aboutPi
Mon Nov 13, 2017 4:24 pm
Hello Gordon,
thank you for your reply.
These are the values of the variables:
class PotController
	private:
		const int MCP3008_BASE	= 100;
		const int MCP3008_SPI_CHAN	= 0;
Running the command gpio -x mcp3004:777:0 I get 0 as result.
Any idea?
gordon@drogon.net
Mon Nov 13, 2017 4:34 pm
Hello Gordon,
class PotController
	private:
I tried the command but I received the following error:
gpio: Unknown command: -xmcp3004:777:0.
Any idea?
Needs a space between the x and the m
The base & channels look OK though - you do need the spi kernel device loaded for wiringPi though. Make sure they're loaded using the raspi-config program.
-Gordon
aboutPi
Mon Nov 13, 2017 4:43 pm
I run raspi-config as sudo and enabled SPI and disabled I2C. Then I tried the command gpio load spi, but got these error:
gpio: Unable to load/unload modules as this Pi has the device tree enabled.
  You need to run the raspi-config program (as root) and select the
  modules (SPI or I2C) that you wish to load/unload there and reboot.
  There is more information here:
      https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=97314
I tried the gpio -x mcp3004 command but the result was 0.
I will have a look, how to enable the spi and load the spi driver on my raspberry pi 3.
gordon@drogon.net
Mon Nov 13, 2017 4:49 pm
That "error" means it's 2017 and you should be using the device tree. That's why I said to use raspi-config. The only people who try to use the gpio command in that way are a small number of my customers who're still running legacy systems. No ordinary Pi user needs that these days. Don't do it.
-Gordon
aboutPi
Wed Dec 06, 2017 12:28 pm
I got some problem reading the Channel 1 (second input) on the mcp3008. Using the following Code on my SoftPot Membrane Potentiometer
(nothing connected to first input channel of the mcp3008)
wiringPiSetupSPISetup(MCP3008_SPI_CHAN, 500000);
mcp3004Setup(MCP3008_BASE, MCP3008_SPI_CHAN) ;
int value = analogRead(MCP3008_BASE + 1);
I'm getting permanent values between 946 and 949. If I press the SoftPot, connected on the second Input Pin of the mcp3008, I get a different Value. But on the complete SoftPot range I will get nearly the same value.
If I connect the SoftPot on the first input pin of the mcp3008 and using
int value = analogRead(MCP3008_BASE);
There permanent value is 0. The range on the SoftPot is now 0 to 980.
Any hint, how I could read nearly the same Range on the second input pin of the mcp3008?
Best regards
aboutPi
Wed Dec 06, 2017 1:31 pm
Now it works. Must haven been something on the wire connections.
Sorry
domr001
Thu Jan 25, 2018 2:18 pm
After a lot of hair pullingout, and and some great help from Gordon (thank you again) I have a simple complete AD program and the circuit wiring
This is the code ...
#include <stdio.h>
#include <stdlib.h>
#define SPI_CHAN 0
#define MY_PIN 12345
int main(void)
int x[8],i;
float v[8];
float k = 3.3/1024;
  wiringPiSetup() ;
  mcp3004Setup (MY_PIN, SPI_CHAN); // 3004 and 3008 are the same 4/8 channels
	for (i=0;i<8;i++)
		x[i] = analogRead (MY_PIN + i ) ;
		v[i] = k * (float)(x[i]);
	printf("AD ch: = %4d %4d %4d %4d %4d %4d %4d %4d \n",
			x[0],x[1],x[2],x[3],x[4],x[5],x[6],x[7]);
	printf("AD vd: = %2.2f %2.2f %2.2f %2.2f %2.2f %2.2f %2.2f %2.2f\n",
			v[0],v[1],v[2],v[3],v[4],v[5],v[6],v[7]);
	return 0;
This is the wiring for a MCP3008 (MCP column is IC pin no.) ...
 +-----+-----+---------+------+---+---Pi 3---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | MCP  | V | Physical | V | MCP  | Name    | wPi | BCM |
 |  10 |  12 |    MOSI |  11  | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |  12  | 0 | 21 || 22 | 1 |      | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |  13  | 0 | 23 || 24 | 1 | 10   | CE0     | 10  | 8   |
Also Pin 15, 16 --> 3.3v
Pin 9, 14 --> GND
Pin 1..8 --> Analog signals to be measured
Return to “C/C++”
