packstlaurent
Ugly green horizontal lines
Fri Aug 30, 2013 7:21 pm
I'm just testing the camera module recently bought.
But with dark scene i obtain poor quality image with ugly green horizontal lines :
Here is the default command used :
I've tried many option with no result
I've got a 1a power supply.
Is there a problem with my hardware ?
Any idea ?
Thanks in advance,
Pack
eddieluo
Re: Ugly green horizontal lines
Sat Aug 31, 2013 12:59 am
Same problem here.
Sat Aug 31, 2013 10:25 am
What's it like under normal illumination?
packstlaurent
Sat Aug 31, 2013 3:14 pm
With a good illumination, the image seems to be ok.
I'm really thinking about a hardware problem with the camera module.
Pack
packstlaurent
Sat Aug 31, 2013 3:28 pm
I've just testing with 5PM light (which is pretty good), and green line too.
packstlaurent
Sat Aug 31, 2013 4:09 pm
I've changed the rapsberry pi card to another one (same sd card, same camera module).
I obtained this message :
raspistill Camera App v1.1
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 400, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
What does it mean ?
Thanks,
Pack
maui
Sat Aug 31, 2013 5:21 pm
Firstoff it means you have the old raspistill / raspivid version
do a
sudo apt-get install rpi-update
sudo rpi-update
you should see "raspistill Camera App v1.2" now
ffelagund
Mon Sep 02, 2013 10:24 am
Perhaps it's caused by an insufficient power supply (something similar happened to me). Try with a more powerful PSU
Mon Sep 02, 2013 11:21 am
packstlaurent wrote:I've changed the rapsberry pi card to another one (same sd card, same camera module).
Opacity 255
What does it mean ?
Thanks,
Pack
Have you set the GPU split correctly?
packstlaurent
Tue Sep 03, 2013 7:16 pm
maui wrote:Firstoff it means you have the old raspistill / raspivid version
do a
sudo rpi-update
Thanks you. That's much better !
I continue my tests...
Pack
Return to “Camera board”
