PI_ZA
GPIO button to emulate keyboard
Wed Aug 28, 2013 10:41 pm
I am trying to setup my Pi as a music player, I want to be able to attach buttons to the GPIO pins to emulate keys being pressed (namely, P; < ; > ; * ; and / ). Is there any way to do this?
JRV
Re: GPIO button to emulate keyboard
Thu Aug 29, 2013 6:50 pm
Yes, it's possible.
I made a test breadboard using 5 switches.
The switches are each attached to a digital pin
and the other lead to ground.
For the software I am using the wiringPi libraries and programming in C.
The documentation for wiringPi is located here:
http://wiringpi.com/
WiringPi uses different pin numbering, study this carefully:
http://wiringpi.com/pins/
You will also need to read these pages:
http://wiringpi.com/download-and-install/
http://wiringpi.com/reference/core-functions/
  Filename: keytest.c
Five switches are connected to pins 0 - 4,
the other lead is connected to ground.
#include <stdio.h>
#include <stdlib.h>
#include <wiringPi.h>
void setup(void)
  int i;
  if (geteuid() != 0)
    fprintf (stderr, "You need to be root to run this program. (sudo?)\n") ;
    exit(0) ;
  if (wiringPiSetup() == -1)
    printf("wiringPiSetup error\n");
    exit(1) ;
  for(i=0;i<5;i++)    //Set pins 0-4 for input, with pullup.
    pinMode(i, INPUT);
    pullUpDnControl (i, PUD_UP);
void loop(void)
  int i,c;
  int readpin[5] = {0,1,2,3,4};
  int ascii[5] = {80,62,60,47,42};
  for(i=0;i<5;i++)
    if(digitalRead(readpin[i])==LOW)
      while(digitalRead(readpin[i])==LOW); // De-bounce
      ungetc(ascii[i],stdin);              // Push value into input buffer.
      c = getchar();
      printf("%c - Ascii = %d\n",c,c);     // Or whatever you want to do with it.
      i = 5;                               // Force exit of for loop.
int main(void)
  setup();
  for(;;)
    loop();
Compile it with the command:
gcc -o keytest  keytest.c -lwiringPi
Run it with the command:
sudo ./keytest
PI_ZA
Thu Aug 29, 2013 9:55 pm
Thank You! that works, However I think I found a better way of communicating with the program.I will use Mplayer and put it in slave mode, then create a fifo to communicate with it (as per this document http://www.mplayerhq.hu/DOCS/tech/slave.txt).
I want to be able to run
mkfifo ~/Mplay
at startup and then run Mplayer in slave mode. I will (Hopefully) use a program to
Echo "P" > MPlay
on a GPIO button press. I can successfully create the fifo from a script, but when I try
mplayer -slave -quiet FILE -input file=~/Mplay
, I get
-bash: /home/pi/fif: Permission denied
Does any body have any ideas on how to achieve this?
agash
Mon Nov 25, 2013 8:29 am
JRV wrote:Yes, it's possible.
  Filename: keytest.c
#include <stdio.h>
#include <stdlib.h>
void setup(void)
  int i;
  if (geteuid() != 0)
    exit(0) ;
    exit(1) ;
    pinMode(i, INPUT);
void loop(void)
  int i,c;
  for(i=0;i<5;i++)
      c = getchar();
int main(void)
  setup();
  for(;;)
    loop();
sudo ./keytest
Hello JRV
I am very interested in implementing your solution, because I have a similar Problem. But sadly I have absolut no experience with C-Compile. I made all your steps, but when I want to compile, I receive a lot of errors:
keytest.c: In function ‘setup’:
keytest.c:14:1: error: stray ‘\302’ in program
keytest.c:14:1: error: stray ‘\240’ in program... etc. Do you know what I'm doing wrong or what I am missing?
Alex_raspberry
Wed Dec 09, 2015 3:24 pm
I tried testkey, it works fine but only in one terminal which I ran: sudo ./testkey // one terminal which I ran
in other terminals and softwares it didn't work.
how can I emulate keys(such as "Enter" ,... ) in other terminals and other softwares?
thanks
Wyahm_122
Re: PI_ZA
Sun Jan 21, 2018 12:43 pm
Instead of
Do:
Sudo mplayer -slave -quiet FILE -input file=~/Mplay
mahjongg
Sun Jan 21, 2018 1:54 pm
Adafruit has written software for exactly this, initially so you can use arcade buttons to control RETROPIE , but it will work just as well for other applications. It's simply a background program that scans the GPIO's and insert keyboard button press/release codes in the keyboard queue.
https://github.com/adafruit/Adafruit-Retrogame
deepdivered
Wed Sep 18, 2019 7:05 pm
mkfifo ~/Mplay
Echo "P" > MPlay
, I get
did you ever get this to work? I am looking into doing the same thing.
