ctravis
Static IP and ARPwatch
Mon Aug 26, 2013 7:07 pm
Is it possible to have a static IP on a Raspbian device with ARPwatch?
I'm reading where DHCP is recommended, but I would like to utilize a static IP for SSH purposes.
Thank you to anyone who might be able to answer,
Charlie
sprinkmeier
Re: Static IP and ARPwatch
Thu Aug 29, 2013 11:57 am
If you
apt-get install avahi-daemon
then you can
ssh raspberrypi.local
If you want a static IP address sometimes the easiest way is to set up a static lease on your DHCP server.
Failing that, you can disable the dhcp-client on the Pi and set a static IP address, something like
$ cat /etc/network/interfaces
auto lo
iface lo inet loopback
# The primary network interface
auto eth0
iface eth0 inet static
    address 10.149.1.100
    netmask 255.255.255.0
    up ip route add default via 10.149.1.254
