caporeira
Analog Video Output on Raspbery
Mon Aug 26, 2013 12:53 pm
Have maybe Raspberry Pi analog video output ?
Or maybe someone know how to cheep convert digital to analog signal ?
mahjongg
Re: Analog Video Output on Raspbery
Mon Aug 26, 2013 8:36 pm
the RCA output of the PI will output analog video, if you do not connect a HDMI device.
caporeira
Tue Aug 27, 2013 9:51 am
Thank you for your answer.
I forgot add to my ask, I want to have Analog RGB signal, how do I make it ?
redhawk
Tue Aug 27, 2013 10:09 am
You will need a HDMI to RGB converter box (component or scart depending on your video equipment).
Make sure it comes with an external PSU since the Pi isn't designed to power devices directly via the HDMI port.
Richard S.
caporeira
Tue Aug 27, 2013 10:40 pm
Can you recommend the cheapest solution to have Analog RGB video signal ?
redhawk
Wed Aug 28, 2013 10:26 am
There is no cheap solution converting HDMI to analogue video is quite a complicated process.
To be honest I don't see any benefit for converting HDMI to RGB when the resolution is no better than composite video.
Granted composite isn't great but if your watching videos on and old CRT type TV the image quality should be more than adequate.
Richard S.
