usx8
Pi wont boot
Mon Aug 26, 2013 5:30 am
Hi, I'm new here and I hope this is the right area. The other day I bought a new SD card for my RPi (16gb class 10) and formatted it. I then put noobs on it and tried to get it to work. I formatted and extracted the files onto the card 3 times and I could not get it to boot. I was using the composite out, and I tried with ethernet connected and disconnected, as well as usb devices connected and disconnected. After seeing that the noobs SD was not working, I checked the wiki to see if the card was compatible, it was so why it doesn't work is a mystery to me. However, I also have another SD card with Rasbmc on it. This has worked for months, no problems, but after trying the new card, this one no longer works. I tried unplugging all peripherals and ethernet (through composite again). The error message I was getting was:
kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
A quick search of the forum said that by changing part of the code (in the cmdline.txt)
mmcblk0p2
to
mmcblk0p6
my problem would be solved, however this just changed the message to
kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,6)
So now both of my SD cards do not work, and I have no idea why. Basically I'm looking for
What went wrong with the new card?
What went wrong with the Rasbmc card?
How do I install raspbian on the new card? (16gb one, with or without noobs)
How do I fix the Rasbmc one?
If any more information is needed just let me know!
shabuboy
Re: Pi wont boot
Wed Aug 28, 2013 8:57 pm
Yesterday I built my first Raspbmc and it worked fine for about 8-10hrs. then late last night, got the same error.
Ideas anyone?
Genius23008
Re: Pi wont boot
Thu Aug 29, 2013 8:23 pm
This can be caused by your SD card.
Class 4 cards work best with the Pi (anything higher is sometimes problematic).
By the way, changing the code for me stops my Pi from booting...?
abishur
Re: Pi wont boot
Fri Aug 30, 2013 1:40 pm
I don't suppose this was a kingston 16GB Class 10 micro SD card was it?
http://elinux.org/RPi_SD_cards#Working_ ... g_SD_cards
If not, I mainly see this issue with a corrupted SD card and more often than not it's caused by too high an overclock. If that's the case than re-installing it without overclocking would fix the issue. Once confirmed slowly increase the overclock until you get the issues again and you'll know the max overclocking your pi can handle :-)
Dear forum: Play nice ;-)
